Old 29th November 2010, 18:17   #76
nairrk's Avatar
Thanked: 31 Times
I think GM is giving a wrong route !!
After Tirunelveli, why should one take that kind of diversion instead coming straight to Nagercoil (good road) and then drive through Thuckalay, Marthandam, Kaliakkavilai, Parassala, Neyyattinkara, TVm (all these are small town).
The route proposed by GM especially pechiparai, keeriparai, Thiruvarambu all small places and nobody know how the roads will be..? (unless you want to see pechiparai dam?). Suggest maintain the major highway instead of taking such diversions....
nairrk is offline   Reply With Quote
Old 29th November 2010, 19:18   #77
Thanked: 105 Times
Default NH45 to NH7
For the drive from Chennai to TVM what is the best place to cut from nh45 to NH7. The way i understand is i can stay on NH45 B till i get close to madurai and then i have to get to NH7. I have driven this route once but there was friend with me and i was able to do this easily. I passed through a route which was single lane and had lots of toll bridges. However when i drove back from tvm to chennai i missed the route and finally ended going thru dindigul to chennai and this was quite a pain. Folks who take this route often. Please help out.
vishnurp99 is offline   Reply With Quote
Old 29th November 2010, 19:45   #78
ampere's Avatar
Thanked: 9,077 Times
Yes you need to stick to 45B till Madurai and then change to NH7 till Nagarcoil. (well the road breaks into 47 in between. NH7 goes all the way to KK).
Old 30th November 2010, 10:46   #79
Thanked: 142 Times
The single lane road you are referring is the Madurai Byepass from the NH45B side. To get onto this road while you are coming from Trivandrum watch out for the sign board which says "Trichirapalli, Rameswaram & Madurai Airport" take a right here and you are onto the byepass. To know if you are on right track or not the point at which you take a right you cross over the railway track. I am marking in Google Maps for your reference. It is not so difficult to find out.
Chennai - Trivandrum : Route Queries-madurai-byepass.jpg
pypkmsrikanth is offline   (1) Thanks Reply With Quote
Old 30th November 2010, 13:39   #80
hvkumar's Avatar
Thanked: 3,361 Times
Very easy to locate this turn off point. When you are coming from south side (Tirunelveli), you will first see the turn off to Tirumangalam town. 2 kms from this point you will reach the T Junction, where you turn off right to take the old Madurai bypass to reach Trichy.
hvkumar is offline   Reply With Quote
Old 30th November 2010, 15:43   #81
Mr Hvk . 2 questions.
1)Do you suggest this route as the better one from TVM to chennai Via Trichy.
2) In case if someone wants to touch Madurai ..then what would be your suggestion. kindly provide detail . Thanks.
shapath is offline   Reply With Quote
Old 30th November 2010, 15:52   #82
hvkumar's Avatar
Shapath, yes, if you are going to Chennai from TVM< it is best to take the old bypass from the junction after Tirumangalam and take NH45B via Viralimalai to Trichy and then join NH45 from there.
If you want to go into Madurai city, keep going straight after Tirumangalam. Some 3-4 kms after that junction, the new Madurai bypass (on NH7) will veer off to the right, and you keep going down, you will enter Madurai city. If you want to go to the Madurai temple, you can go all the way till the NH49 junction (identified by the Best Western Germanus hotel to the right), turn right there and easily reach the temple.
Leaving Madurai, you can go through the city and reach NH45B.
Old 30th November 2010, 16:02   #83
SafeDrive's Avatar
Thanked: 48 Times
Hi, I did this route in July. It's ane asy go now - the route is pretty well marked with sign boards. All you need to do is know the names of the major towns on this route and you've got it made.
Word of caution though - avoid Nagercoil to TVM during peak time. It is really bad.
SafeDrive is offline   Reply With Quote
Old 2nd December 2010, 17:20   #84
Thanked: 105 Times
@pypkmsrikanth,hvkumar,ampere Thanks for the information regarding the turnoff point. When i come from Chennai is there a landmark for the turnoff point into the madurai byepass?
Approximately how many kms is this turnoff point from chennai?
Old 10th December 2010, 14:03   #85
Thanked: 105 Times
Default re: Chennai - Trivandrum : Route Queries
Is it a good idea to take the NH208 to travel from madurai to tvm. I am planning to drive from chennai to TVM and am considering taking this instead of the nagercoil route. Any inputs would be appreciated. Is the NH 208 a ghat road or single lane etc?
Old 10th December 2010, 14:23   #86
hvkumar's Avatar
I don't think it is worth it. From Kollam, NH208 also crosses several small towns and then it is a narrow twisty ghat from Punalur onwards. You may as well consider the Trivandrum-Tenmala-Tenkasi route.
Old 10th December 2010, 14:37   #87
Thanked: 105 Times
Is the nagercoil road the best option then or the tenmala/tenkasi route? I plan to start early morning around 6 by chennai. I will probably reach nagercoil around 5 then which is peak traffic. are there any other alternatives?
Old 10th December 2010, 14:44   #88
hvkumar's Avatar
I think it best to stick to the Nagercoil route. Budget for 2 hours to drive the 80 kms from Thovalai (where the 4-laned NH7 goes away to KK) to Trivandrum via Nagercoil.
Old 13th December 2010, 11:08   #89
sbkumar's Avatar
Thanked: 96 Times
For average drivers it can take up to 3+ hours easily. The traffic on this stretch is increasing with every passing day and over taking is almost impossible. The only saving point was that the roads were good. I am not sure about that too after heavy rains over the past fortnight.
sbkumar is offline   Reply With Quote
Old 13th December 2010, 11:50   #90
nairrk's Avatar
Thanked: 31 Times
We drove Trivandrum to Kanyakumari on 7th of December and it took about 2.5hours to reach KK and there was light rain in some areas (started 8pm from TVM and reached KK at 11PM with 30minutes break for Dinner).
Bangalore - Chennai - Bangalore : Route Queries madan80 Route / Travel Queries 2985 18th June 2018 11:54
Trivandrum to Bangalore : Route Queries gkrishk Route / Travel Queries 520 9th June 2018 12:10
Chennai-Mumbai-Chennai route queries jeevmenon Route / Travel Queries 89 7th November 2017 14:40
Chennai-Guruvayoor-Trivandrum-Kanyakumari-Chennai rameshnanda Route / Travel Queries 33 25th September 2011 22:55
