Old 29th October 2013, 17:52   #736
Thanked: 119 Times
Originally Posted by amazer2013 View Post
Hey waxeloquent, Thank you for the pointer about hiring driver at munnar. Im driving to munnar next month and can surely use this information. Can you please share the contact info? I tried sending PM but for some reason it says you have blocked pms. I might hire from munnar to udumalpet. Thanks
Sorry Amazer, have PMed you the driver detail. Cheers
Waxeloquent is offline   (1) Thanks Reply With Quote
Old 4th November 2013, 12:22   #737
Default re: Bangalore to Munnar : Route Queries
Hi All,
I'm visiting Palani and Munnar on 15th Nov 2013. For my onward journey, I'll be driving to Munnar from Palani side. So I'll have to take the Udumalpet - Marayoor - Munnar route.
But my return journey would be directly to Bangalore. Can anyone kindly suggest which would be a better option out of the below routes:
1. Munnar - Marayoor - Udumalpet - Dharapuram - Karur - Salem - Bangalore
2. Munnar - Chinnakanal - Theni - Periyakulam - Batlagundu - Dindigul - Salem - Bangalore.
I would not mind taking slightly longer route for better roads.
There was a landslide on the Munnar Theni road a few days ago. It held up traffic for quite some time. The Marayoor Udumalpet route does not have landslide problems, but you might drive past wild elephants.
If you do not mind narrower roads than the 4-lane, I have another route I can suggest:
Munnar - marayoor - Udumalpet - Coimbatore - Annur - Sathyamangalam - Dimbam - Chamraj nagar - Kollegal - Kanakapura - Bangalore
Except Coimbatore - Annur, the traffic is very low on this route, and it is a lovely drive. You can maintain 90-100km speed most of the way, adn it is a rather beautiful drive. Road condition is good and there are no tolls.
The 4-lane from Salem to Bangalore is in pretty bad shape at present with a lot of diversions and the road surface is pretty lousy, not to mention heavy traffic.
Food... you will get at Sathyamangalam, then at Chamrajnagar. Not many eateries on this route. It should take you 5-6 hours from Coimbatore to Bangalore, so if you have lunch at Coimbatore, you can be in Bangalore for dinner, with a tea break on the way.
Happy driving!
paulprv is offline   (1) Thanks Reply With Quote
Old 4th November 2013, 13:00   #738
rameshnanda's Avatar
Thanked: 815 Times
No need to go to Coimbatore too. Best route would be Udumalpet-Palladam-Avanashi-Sathyamangalam. Coimbatore traffic is best avoided.
rameshnanda is offline   (1) Thanks Reply With Quote
Old 4th November 2013, 13:03   #739
Thanked: 119 Times
I returned to Bangalore from Kerala on 31 Oct via pollachi-perudurai-salem-hosur. Yes there are a couple of minor deviations/diversion, otw the 6 lane work is over almost. The traffic is heavy only from Hosur and with Diwali long
weekends are over. If one does not mind the toll, this Salem-Dharmapuri-Hosur-Bangalore is a good one. Even the
Krishnagiri-Hosur 6 laning should be done in 1H 2014. The flyover near Leyland Hosur with checkpoint is the major
bottleneck as far as I experienced. Cheers
Old 4th November 2013, 16:19   #740
ksm
Hi All,
I like the route via Theni and Chinnakanal as long as you are driving day time. This route might be of thick fog at one or two places hence suggest as a morning route. Also, I heard some road widening work is in progress, may be someone can comment on the current situation.
ksm is offline   (1) Thanks Reply With Quote
Old 4th November 2013, 16:39   #741
Thanked: 119 Times
As of 24 Oct, Theni-Bodi-Bodimettu-Chinnakanal was open only before 8am and after 6pm. Suggest you check that
out before taking that route.
Old 4th November 2013, 16:47   #742
Thanked: 592 Times
Two ways to bypass Coimbatore, but both have small bottlenecks with 2-3 kms of rough roads.
1) Palladam-Avinashi-Sevur-Puliampatty-Sathy. Reports from @SureshS a couple of weeks ago indicates good roads, but a railway overbridge under construction somewhere just before Avinashi (Most probably at Vanjipalayam I'd think) forces you to go through a deviation with some bad roads.
2) Palladam-Karanampatti-Karumathampatti-Annur-Sathy. Here again there was a railway overbridge being constructed near Somanur and the associated deviations through bad roads is a minor issue.
But either of these bypasses should save you time overall. Unless it is between 10PM and 7AM, crossing Coimbatore can take quite a bit of time otherwise.
As per recent reports the Theni-Chinnakkanal road is still not open to traffic during daytime due to road work. So I think it'd be better to take the Marayoor route till that road gets fixed.
kala is offline   (1) Thanks Reply With Quote
Old 6th November 2013, 12:13   #743
Thanked: 82 Times
Thank you people, for your invaluable inputs. There has been unanimous discouragement for the Chinnakanal-Theni route from many on the forum. Also, some of my sources indicated that the route near Chamarajanagar and Kollegala are not good. Not too sure of this, so I have finalized the route as below:
This way I can even avoid the bit of off-road deviation required in the Avinashi route. It might be a bit longer, but nonetheless reliable. I'm not very adventurous
I don't know the road condition between Udumalpet - Karur via Dharapuram, so any light on that will help.
amazer2013 is offline   Reply With Quote
Old 6th November 2013, 12:29   #744
ampere's Avatar
Thanked: 8,826 Times
Its good road. You can also do :
Dhapuram-Kangeyam-Peundurai-Salem
Old 6th November 2013, 15:16   #745
Thanked: 592 Times
Yeah, some sources also tell me the same thing and advice me to avoid that route when I tell them I take NH209 on my trips to Wayanad. And when asked about whether they have driven on that route in the recent past, they say "No, but my friend drove on that route 4 years ago and the road was horrendous !"
Anyway that kind of an perception among the general public suits people who enjoy driving on that route very well. Can't even imagine how chaotic that road would get if even 10 % of the Ooty / Wayanad / Coimbatore / Cochin traffic on the conventional routes decide to switch to NH209 !!
kala is offline   Reply With Quote
Old 8th November 2013, 19:50   #746
Thanked: 82 Times
Hello once again people,
There have been some change of plans and I'll have to include Thekkady also in my itinerary. Since many have expressed that road condition is bad on Munnar - Chinnakanal route, which is the next best route to reach Munnar from Thekkady?
Old 8th November 2013, 21:49   #747
Thanked: 592 Times
I thought the work ongoing was only on the Bodimettu-Theni ghats section only ? In which case you should be OK - the route to Thekkady deviates from the Munnar Theni highway at Pooppara which is quite some distance before you reach Bodimettu.
I could be wrong here. I haven't travelled that way for quite a while now, so not sure about the road conditions even on the other stretch. But the impression I got from the messages here was that the problem with bad roads / ongoing construction was only further down on the NH.
Old 9th November 2013, 15:11   #748
Thanked: 82 Times
Thanks Kala. Can I get confirmation from someone who has driven this route recently?
Old 9th November 2013, 18:42   #749
Thanked: 119 Times
Yes what Kala has said is right. At Pooppara you take the right fork to head to Udumbanchola- Nedumkandam en route to
Thekkady. The left is the one leading to Bodimettu and Bodi to Theni.
Old 9th November 2013, 19:18   #750
Thanked: 592 Times
Hi - what I wasn't sure about was the condition of the road from Munnar to Thekkady via Pooppara (and whether there was any blockage between Pooppara and Munnar) since I haven't gone that way in the recent past.
Since you had travelled on that route recently you are probably the best person to clarify that. Would you suggest that road to get to Thekkady from Munnar or is some other route (say via Idukki / Kattappana) better ?
Bangalore - Chennai - Bangalore : Route Queries madan80 Route / Travel Queries 2892 14th February 2018 21:15
Cochin - Munnar : Route/Climate Queries govigov Route / Travel Queries 16 28th December 2015 16:15
Bangalore - Delhi - Srinagar - Delhi - Bangalore : Route Queries micrographics Route / Travel Queries 8 27th November 2015 14:47
Getting drenched in Munnar (Bangalore to Munnar and Kannur) longdriveblusky Travelogues 12 20th November 2012 15:44
Kodaikanal - Munnar - Waynad route queries sumannandy Route / Travel Queries 49 12th October 2012 16:06
