Old 18th August 2008, 14:31   #16
DWind's Avatar
Thanked: 168 Times
Yep! The road is before Avinashi on NH 47. The road goes till Utukuli RS and then turns right and goes to Tiruppur, if you do not take the second left after right turn. BTW not sure if the overbridge on the Perundurai-Kangeyam road is completed (it was not last year). If not, this route can be used.
DWind is offline   Reply With Quote
Old 21st August 2008, 00:18   #17
Thanked: 60 Times
For drive experience and scenery and time saving, this is an option
Mysore - Nanjungad - Bandipur - Mudumalai - Kalhatty Ghat - Ooty - Kotagiri - Mettupalayam - Annur - Somanur - Palladam - Tharapuram - Palani - Kodaikanal
This saves 2 hours time by avoiding Coimbatore where traffic is becoming worse like Bangalore. I use this route frequently between my guest houses in mudumalai and kodaikanal. I have done this route in Indigo, Innova, Scorpio. Innova was the best ride so far.
balan is offline   Reply With Quote
Old 21st August 2008, 19:47   #18
DWind's Avatar
Thanked: 168 Times
Default Is there a Level Crossing?
Thanks Balan!. Would be using it for my Mysore Pollachi travel to either avoid Tiruppur or Coimbatore (and Coimbatore-Pollachi road) traffic. But is there a level crossing near Somanur?
Cheers!
~DWind
Old 25th August 2008, 11:35   #19
Thanked: 60 Times
Default level crossing at somanur
Cheers!
~DWind
There is a level crossing at somanur but you can divert through a small underbridge. Ask the locals and they will point out or follow the local vehicles. In my times crossing this level crossing, I have been caught only once and I used the diversion
best regards
bala
Old 6th November 2008, 16:50   #20
Default Chennai - Palani
Guys,
I am doing a Chennai-Palani trip this weekend with family.
Tentative route plan: Chennai-Krishangiri-Dharmapuri-Mettur-Bhavani-Perundurai-Kangeyam-Dharapuram-Palani
I know the conditions till Perundurai but haven't done the Perundurai-Palani stretch . Can someone provide me inputs on the road conditions and is it safe ? Based on this i will decide on taking this route or the usual Chennai-Villupuram-Trichy-Dindigul-Palani route.
Also can you give me a rough time estimate to complete this route ?
Plan is to start from Chennai early in the morning on Saturday and return back to Chennai on Sunday evening/night.
Mission_Safari is offline   Reply With Quote
Old 6th November 2008, 21:11   #21
hvkumar's Avatar
Thanked: 3,354 Times
107 kms from Perunthurai to Palani via Chennimalai, Gangeyam and Dharapuram. 2-3 hours time to drive. Road is 2 lane, but good. Safety is not an issue.
hvkumar is offline   Reply With Quote
Old 6th November 2008, 21:36   #22
Thanks for clarifying HVK.
Old 28th August 2009, 14:53   #23
nithz's Avatar
what might be the total distance in this route
nithz is offline   Reply With Quote
Old 31st August 2009, 15:45   #24
Thanked: 60 Times
Not exactly sure
Roughly
Mysore nanjungad bandipur mudumalai ooty 136 KM
Ooty Kotagiri Metupalayam - 55 KM
Metupalayam Annur Somanur Palladam - 60 KM
Palladam Dharapuram - 40 KM
Dharapuram Palani - 40 KM
Palani Kodaikanal - 60 KM
Roughly 400 KM. Plan to have a break at Dharapuram for lunch or what ever. There is a new restaurant now. Or break at Ooty at kurinji or nahar or Blue hills
Best regards
Bala
Old 31st August 2009, 19:02   #25
nithz's Avatar
Thanks for the info balan ,but what about the chamarajnagar -dimbam-sathi-perunthurai road ?what will be the distance ?i think this route will be shorter than ooty route from mysore.correct me if i am wrong .
Old 1st September 2009, 09:46   #26
Thanked: 140 Times
If you are taking this route it would still make sense to go up to Annur and then turn onto Somanur - Palladam - Dharapuram - Palani. But keep in mind that the roads from Chamrajnagar to Hasanur is in bad shape and you would end up repenting taking that route. Post Tamil Nadu border the roads are in great shape all the way.
pypkmsrikanth is offline   Reply With Quote
Old 12th September 2009, 18:21   #27
Thanked: 28 Times
folks,
Any update on road conditions on mysore-nanjangund-chamrajnagar-dhimbam-sathy.
Is there any time barrier to cross over? like closed after 6 pm etc.
PRADEEP KUMAR is offline   Reply With Quote
Old 20th March 2015, 14:44   #28
srinivaspai's Avatar
Thanked: 22 Times
Default Re: Route from Mysore to Kodaikanal
anyone can update on Mysore-Kodai route?
My plan is to go via Chamrajnagar-dhimbam-sathy-kangayam-Dharapuram-palani-Kodai
How is the surface? any better options available?
srinivaspai is offline   Reply With Quote
Old 20th March 2015, 17:39   #29
Thanked: 586 Times
Not sure if you need to go to Kangeyam. Sathy-Puliampatti-Sevur-Avinashi-Palladam-Dharapuram-Palani-Kodai may perhaps be shorter.
Roads till Palladam are very good, not sure about the road conditions after that. But most Tamilnadu State highways are generally maintained well, so I think they should be fairly good also.
For Mysore-Chamarajnagar it may be better to go via T.Narsipur instead of Nanjangud since the Mysore-Nanjangud sector is quite slow with heavy traffic and
not too great a road surface. Even the Nanjangud-CRNagar road had quite a few rough sections close to Nanjangud when I travelled that way last.
kala is online now   (1) Thanks Reply With Quote
Old 21st March 2015, 10:33   #30
ampere's Avatar
Thanked: 8,598 Times
+1 to what Kala said. You should continue on 209 and head to Avinashi. Take the road to Mangalam and there on to Palladam-Dharapuram-Palani-Kodai.
ampere is offline   (1) Thanks Reply With Quote
Mysore - Yeswantpur - Airport - Mysore : Route Queries madaboutCARS Route / Travel Queries 18 25th December 2015 11:02
Palio: Pune-Mysore-Kodaikanal-Munnar-Banglore-Pune pawan_pullarwar Travelogues 66 22nd October 2009 09:31
Mysore-Hosa agrahara-Shravanabelagola-Srirangapatna-Mysore pmvelu Travelogues 4 2nd March 2008 22:09
Mysore-Madikeri-Bhagamandala-Talacauvery-Mysore pmvelu Travelogues 5 12th February 2008 21:23
