Old 9th January 2017, 17:00   #196
Thanked: 389 Times
Default Re: Delhi To Jaisalmer : Route Queries
I am just back from my Gurgaon - Jodhpur - Jaisalmer - Bikaner - Mandawa - Gurgaon trip. HAd a lot of fun - update on the road conditions.
Gurgaon - Jodhpur
Took the Gurgaon - Jaipur - Ajmer - Beawar - Jodhpur route.
Amazing roads all along. Had initially planned to stop at Ajmer and then continue to Jodhpur next day - but ditched that plan and continued to Jodhpur the same day.
This route does have a lot of toll - around Rs. 400 worth.
Jodhpur - Jaisalmer
Took Jodhpur - Osian - Phalodi - Pokhran - Jaisalmer route
Between Pokhran and Jaisalmer road repair work is going on - and the road condition is bad.
Other than that stretch - the roads are good.
Jaisalmer - Bikaner
Took the route - Jaisalmer - Pokhran - Phalodi - Bikaner
Bikaner - Mandawa
Took the route - Bikaner - Ratangarh - Fatehpur - Mandawa
Fatehpur to Mandawa the roads are horrible (around 10-15km stretch) other than that good roads
Mandawa - Gurgaon
Took the Mandawa - Jhunjhunu - Chirawa - Loharu - Jhajjhar - Gurgaon route
Good roads. There are some small stretches with bad roads -- but not horrible, did not need to slow down as i was in a Scorpio.
But they are single roads - don't have divider in between. However, i think better than taking NH8 as it avoids all the traffic on NH8
Thanks.
sach.sri is offline   Reply With Quote
Old 25th July 2017, 13:22   #197
Tanmay K's Avatar
Thanked: 182 Times
Can one expect Jaisalmer to be packed with tourists (from NCR and Gujarat) over the Independence Day weekend next month (August 12-15)?
Tanmay K is offline   Reply With Quote
Old 1st August 2017, 14:07   #198
fine69's Avatar
Thanked: 883 Times
Jaisalmer is a far-off destination for most folks in NCR and most do not even go to Jaisalmer on the first day so expect less crowd from NCR. Jaipur would see maximum influx given the significantly less travel time.
However, Gujarat border is about 300 kms but don't forget, most Gujarat tourists would flock to Mount Abu and Udaipur instead because freedom to drink (which is a major agenda of vacation for people from Gujarat) and less distance.
I think you should be good but please keep a tab on the weather because if its hot, you just can't enjoy Jaisalmer.
fine69 is offline   (1) Thanks Reply With Quote
Old 1st August 2017, 14:23   #199
Thanked: 2,522 Times
Maybe talk to a few hotel owners? Should give you an idea about the rush. Even if there is availability for the first day, the dunes maybe crowded.
Dry Ice is offline   (1) Thanks Reply With Quote
Old 14th November 2017, 23:32   #200
Route from Jodhpur to Jaisalmer:
Option-1: Jodhpur - Osian - Phalodi - Pokhran - Jaisalmer
Option-2: Jodhpur - Dechu - Pokhran - Jaisalmer
Kindly suggest best option.
fiesta is offline   Reply With Quote
Old 28th November 2017, 13:32   #201
rk_sans's Avatar
Thanked: 778 Times
Folks, What's the best route from Jaipur to Jaisalmer and Jaisalmer to Jodhpur ?
rk_sans is offline   Reply With Quote
Old 28th November 2017, 19:15   #202
ranjitp1's Avatar
Thanked: 1,794 Times
The best route is Jaipur-Kishangarh-Beawar-Bar-Jodhpur-Dechhu-Pokharan-Jaisalmer
https://goo.gl/maps/4WQWKcGkHMy
Jaipur-Jodhpur should take you around 6-7hours and Jodhpur-Jaisalmer will take you around 5hours.
ranjitp1 is offline   (1) Thanks Reply With Quote
Old 28th November 2017, 20:32   #203
rk_sans's Avatar
Thanked: 778 Times
Thanks a lot Ranjitp.
Do we have to go through Jodhpur to reach Jaisalmer ?
Old 28th November 2017, 20:50   #204
ranjitp1's Avatar
https://goo.gl/maps/LCSYoQXJwdA2 this is the bypass.
ranjitp1 is offline   Reply With Quote
Old 21st December 2017, 16:37   #205
Thanked: 240 Times
i am doing a Faridabad-Jaisalmer-Faridabad trip in my Honda mobilio. Plan to start at 0230 on 23rd December in morning and reach ajmer maximum by 0800 hrs and to jaisalmer by 1400-1600 hrs. Need confirmation from other members if taking the ajmer-jodhpur route would be good. Distance is not an issue. Congestion free road is a priority. please suggest
su1978 is offline   Reply With Quote
Old 13th May 2018, 14:04   #206
harpreetsubhi's Avatar
Thanked: 101 Times
Hello, I'm also planning some trip from Faridabad to Jaisalmer. Can you please share your experience? Though I do not think I will be able to drive 800+ kms in a single day. Your guidance will be of great help.
harpreetsubhi is offline   Reply With Quote
Old 6th June 2018, 08:16   #207
Thanked: 32 Times
Two routes.. and depending on when you want to stop.. you can take either.
If you want to drive more on the first day, take the route that goes via Bikaner. You can halt at Bikaner. Will be a 8-9 hour drive depending on how many stops you take.
The other is to stop at Jaipur and drive more on the second day. Via Naguar reach Jaisalmer.
Both ways, road conditions are similar - good. I would take the Bikaner route though and that way you can explore the town too.
acquillew is offline   Reply With Quote
Delhi - Kullu - Manali - Delhi : Route Queries kingofmyworld Route / Travel Queries 135 5th June 2018 18:42
Delhi - Mathura - Agra - Jaipur - Ajmer - Delhi : Route Queries ranjitp1 Route / Travel Queries 23 22nd December 2016 13:21
Year end trip to Rajasthan: Delhi-Bikaner-Jaisalmer-Jodhpur-Delhi akp Travelogues 42 20th March 2016 21:21
Bangalore - Delhi - Srinagar - Delhi - Bangalore : Route Queries micrographics Route / Travel Queries 8 27th November 2015 14:47
Route from Mumbai to Jaisalmer.... nix1976in Route / Travel Queries 7 25th November 2009 11:21
