Old 8th November 2008, 09:55   #91
adc
adc's Avatar
Thanked: 2,100 Times
Default Manali-Leh Route Profile
The profile in graphic form, also shift all the discussion regaridng leh 2009, the route, and the schedules to this thread, to have all info at one thread.
http://www.team-bhp.com/forum/team-b...nterested.html (Team Bhp At Leh. Anyone Interested?)
adc is offline   Reply With Quote
Old 8th November 2008, 11:33   #92
Thanked: 252 Times
That's a nice one adc!
How about asking the mods to merge the two threads? Will already cross the better part of a dozen pages!
Old 15th June 2015, 14:09   #93
nikhilj's Avatar
Default Re: Can a Civic make it to the Himalayas?
People have been ranting about the Civic's low ground clearance, here and beyond, but interestingly Civic has an above average clearance for an Indian Sedan. Most Sedans in India have a clearance between 155mm (Sonata, Accord), and 175mm (Altis).
Even the Gypsy has a GC of 175mm. So, "Ground Clearance," per se isn't the Civic's problems, the problem perhaps lies in its suspension or its wheelabse-to-GC ratio perhaps.
TBHP Mod Anshuman took his 2010 Laura to Ladakh, and reported facing no serious troubles or damage. By that logic, any car with the Laura's GC and wheelbase-to-GC ratio, and a similar suspension should coast the kucha & pukka roads of the Himalayas.
Interestingly, the 2009-13 Laura had a GC of 164mm, or about 4% less than the Civic. But yes, the Civic had a longer wheelbase (2700mm) than that of the Laura (2578mm).
So, in order to get the same wheelbase-to-GC ratio as the Laura, the Civic must have a GC of 172mm.
Raising the GC by 2mm (and some more, to add underbody production like that of the Laura's) doesn't seem like too much of a task.
In fact, just changing the tyres (not even wheels) one size up, from 195/65 R15 to 205/65 R15 would add 6.5mm to the GC, enough to add underbody protection (3mm Steel) and still have the remaining clearance match up to the Laura's WB-to-GC ratio.
With these stats in consideration, I guess Civic CAN be taken to the mighty Himalayas to the valleys of Kashmir and the deserts of Ladakh!
If I'm wrong on the above explanation or stats, please do correct me. Honestly speaking, even I find these stats (picked off Carwale.com) hard to digest.
Have had a Civic (170mm GC) and an SX4 VXi (170MM GC, according to Carwale) both in my house, and the Civic DID seem FAR more low-slung than the SX4.
nikhilj is offline   (2) Thanks Reply With Quote
Old 15th June 2015, 14:16   #94
prakhar1998's Avatar
Thanked: 495 Times
The ground clearance in itself isn't a problem for the civic. However, when loaded, the ground clearance changes drastically. The car is too softly sprung. On the other hand, Anshuman's Laura's suspension is much stiffer, and doesn't reduce the ground clearance despite being loaded. Additionally, cars wit softer suspensions tend to get impacted more by larger potholes and speed breakers too.
prakhar1998 is offline   Reply With Quote
Old 15th June 2015, 14:18   #95
tsk1979's Avatar
Thanked: 15,683 Times
Its not about stats. Its about vehicle design. The sump of the civic is extremely vunerable, and unless you go for metal protection plates, there is a good chance of getting stranded.
So do take your civic, but only after you have a complete protection plate for underbody.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 16th June 2015, 16:27   #96
nikhilj's Avatar
Yes, underbody plates are kind of a necessity, IMHO, for such driving.
But, my comment, was primarily over Civic's "apparently low" ground clearance.
nikhilj is offline   Reply With Quote
Old 16th June 2015, 22:11   #97
laluks's Avatar
Thanked: 7,927 Times
There is already a Civic which went to Ladakh, through Zojila pass. Also yet another expected this year
Why I did not take my Civvy was since my routes were too adventurous for the Civic, and not a plane jane ride to get a click at KLa .
laluks is offline   Reply With Quote
Old 22nd August 2016, 15:17   #98
Thanked: 226 Times
Well a Civic and a City did get to Pangong and Khardung La this year too
http://www.team-bhp.com/forum/street...ml#post3985735 (Ladakh Taxi Mafia now wants to completely ban outside vehicles (including private cars))
coolkurt is offline   Reply With Quote
Old 22nd August 2016, 18:02   #99
laluks's Avatar
Originally Posted by coolkurt View Post
I was mentioning about this Civic Coolkurt
Old 22nd August 2016, 21:12   #100
Thanked: 226 Times
This is too much torture for the Civic. There's no engine guard, it's got low GC so this is equivalent to punishing the car. Not advisable. Although I'd love to do this just for the sake of trying it. But then I love my Civic too much :P
Old 22nd August 2016, 22:10   #101
Nikhilb2008's Avatar
Thanked: 5,101 Times
It's difficult but not even close to impossible to warrant such a thread
Exhibit A and B
Nikhilb2008 is offline   (2) Thanks Reply With Quote
Old 23rd August 2016, 08:34   #102
laluks's Avatar
Way back in 2007/2008 with pagal nullah in full fury taking a Civic would have been history, nowadays with tarmac almost everywhere the thread itself is irrelevant, like many many things in history
Probably we can close this thread also
laluks is offline   (1) Thanks Reply With Quote
Old 26th August 2016, 13:38   #103
Thanked: 226 Times
That depends. You can't be over adventurous with the Civic. Will have to stick to standard fare. For eg, you'll have to stick to visiting Leh - Nubra on one day. Get back to Leh. Then do Leh - Pangong and so on.
Routes like Nubra to Pangong directly will be tough. Going through Agham village, dealing with the shyok river on routes where the small roads have been washed off will be impossible. The loose sand, gravel will make the already low GC even dangerously lower.
Government will make safety norms more stringent, but no plans to make airbags mandatory Tushar The Indian Car Scene 39 9th September 2016 14:27
2009 make car - Registered as 2010 make? MAS Indian Car Dealerships 16 5th November 2009 10:48
