Old 14th November 2008, 04:34   #1
Count's Avatar
Default Hairpin bends on Yercaud route
I am a relatively new driver and more so when it comes to highway driving. In all I might have driven about 1000-1500 km on the highways. City driving around 10000 km over 2 years. Comfortable in city driving. I drive a Hyundai Getz GLS.
I am planning for a weekend trip to Yercaud and after reading the travelogues, I realized there are numerous hairpin bends on the route after Salem.
My question to the more experienced folks here is:
1. Do you think that the hairpin bends on this section can be tackled by some of my experience? I have done the hairpin bends on the Nandi hills section without any problem.
2. Any advice/tips while doing the Salem-Yercaud ghat section and on the hairpin bends.
Thank you
Count
Count is offline   Reply With Quote
Old 14th November 2008, 09:24   #2
hvkumar's Avatar
Thanked: 3,354 Times
It is a very mild ghat, not at all a problem.
hvkumar is offline   Reply With Quote
Old 14th November 2008, 09:26   #3
Thanked: 30 Times
Not a problem at all. If you are going during day then you can see lot of monkeys .
Hairpin bends are not very sharp do advice to keep the car in 2nd at most 3rd(not recommended) gear while climbing and while descending 1st or max 2nd gear ! Never switch off your engine while coming down
aka_iitd is offline   Reply With Quote
Old 14th November 2008, 09:32   #4
Thanked: 244 Times
Also stick to your lane while negotiating the bends, I mean take the full curve while turning and dont just cut across. Drive slow as the bends are almost like U-Turns.
Old 14th November 2008, 10:12   #5
GreenmachinE's Avatar
Thanked: 21 Times
I visit Yercaud at least twice a month. The ghat road is relatively mild,nothing really scary. With 10,000 km under your belt,you should have no problem negotiating Yercaud. As pointed out by other members, watch out for monkeys ( just fun to watch . They are very alert and are not a traffic hazard), 2 wheelers coasting down at insane speeds and pedestrians. Stick to your lane and always play defensively at blind curves. Lorry and buses have the right of way and always yield for uphill traffic. And if you chance to encounter a heavy vehicle at a hairpin bend, always take the inside line as they have to take the out side line even if it means driving US style.
Also never coast down on neutral, avoid night journeys and remember to fill up fuel. There is a bunk but occasionally they run out of petrol.
If possible try to visit during week days as weekends tend to be crowded. I would avoid all the popular "tourist spots" and visit remote places like killiur falls, bears cave etc. The climate now is excellent, clear skies and cold temp.
GreenmachinE is offline   Reply With Quote
Old 14th November 2008, 21:21   #6
magesh_kumar's Avatar
the hairpin bends will be easy for you to negotiate. but beware of the 2 wheelers. monkeys will be a problem if you stop on the ghat road. i don't advice stoping while on ghat road. there will be some steep climbs in remote areas but havign 10000 kms under your belt it be not a problem for you
magesh_kumar is offline   Reply With Quote
Old 14th November 2008, 22:16   #7
Count's Avatar
Thank you all for your suggestions. Really appreciate it!
Old 14th November 2008, 23:02   #8
possible share your yercaud trip - once you are done. wishes.
shapath is offline   Reply With Quote
Old 14th November 2008, 23:42   #9
Swifty2008's Avatar
Hey Count,
Few tips:
1). When you start climbing, use 2nd or 3rd gear.
2). Honk and go slow on the turns
3). Try to top-up your tank before you start the climb.
4). When you start coming down, try to be in 2nd or 3rd gear. This will assist you with engine braking.
Have safe drive.
Do take pictures and delight us with your trip experience.
Swifty2008 is offline   Reply With Quote
Old 15th November 2008, 00:07   #10
nishant_kingpin's Avatar
Any hairpin bends on any stretches can be tackled with ease if you are regimental in terms of gear usage as well as stick to your lane what ever the case. As some BHPians have been suggesting the 2nd gear is a good pick.
Also when you can’t see the road, mild honking is advised apart from slowing down to the lower revs of the engine. Drive with confident caution.
Share your travel experience and have fun
nishant_kingpin is online now   Reply With Quote
Old 16th November 2008, 20:38   #11
Count's Avatar
Sure, will post my travel experiences/pics here. Will be traveling sometime in January first week. Thanks again for all the help and advice!
Old 17th November 2008, 00:10   #12
Path_Finder's Avatar
Just an additional suggestion to use while coming down hill:
Drive in the same low gear as you would have used while going uphill. Use engine breaking effectively and less of clutch.
Path_Finder is offline   Reply With Quote
Old 16th November 2009, 15:41   #13
trtraj's Avatar
Thanked: 103 Times
Default DO not trail to the heavy vehichles
IMO, Please do not trail the heavy vehicles, They may move to the extreme in the turning which may look scary for you so, Keep a safe distance between vehicles...
10000 Kms of driving is more than enough.. I climbed the 1st mountain when i was just 800 Kms driven on road, But that was the safest mountain i have seen ever (Tirupati).
Bon Voyage !! Post some snaps...
trtraj is offline   Reply With Quote
Old 16th November 2009, 15:52   #14
shishir_bn's Avatar
Thanked: 104 Times
With all the above information and safeguarding techniques don't forget to take the snaps and don't forget to upload in the forum after you take it and don't forget to write your expereince( i think i have used tooo many DON"Ts here)
shishir_bn is offline   Reply With Quote
Old 16th November 2009, 16:02   #15
beejay's Avatar
Thanked: 109 Times
This is most important.
Also, be a bit careful while you are stationary on an incline and need to move forward from there.
beejay is offline   Reply With Quote
Chennai - Yercaud : Route Queries saurabh711 Route / Travel Queries 77 4th August 2017 11:59
Best route - Yercaud to Coorg? convivial Route / Travel Queries 15 22nd June 2013 19:11
Timeout at Yercaud - Bangalore to Yercaud - 2 days Trip bvenkysubbu Travelogues 8 5th June 2013 20:15
Ooty - my first on MY LINEA, probably the first LINEA TO CLIMB famous 36 hairpin bent vinay.pillai Travelogues 56 13th September 2009 21:25
yercaud - hogenakkal route maju Route / Travel Queries 4 15th August 2008 17:07
