Go Back   Team-BHP > Buckle Up > Street and Travel Experiences > Route / Travel Queries
Route / Travel Queries Guidance on the best routes and other travel related queries
Thread Tools
Old 23rd November 2008, 08:39   #1 (permalink)
joshuakeys's Avatar
Exclamation Need help for road trip from hyderabad to Jim corbett national park.
hi Bhpians,
we guys are planning for a trip from hyderabd to jim corbett by the end of Jan 09 or begining of feb 09. we are 4 of us & two drivers. I need help regarding the routes,places to stay & expences. would appriciate if the map is provided. can we buy a road map? if yes where do we get in hyderabad. please throw some light on this topic. You guys have been a great help for my mahabaleshwar trip. Exact information & Accuratu Route, Expect the same kind of response.
Thanks in advance.
joshuakeys is offline   Reply With Quote
Old 23rd November 2008, 12:02   #2 (permalink)
sudev's Avatar
I would advise that you pick up Eicher road map of India. This is one of the best resources.
Second in planning you route is Delhi a must? You could divert from Agra to Aligarh and thence to Moradabad and Ramnagar (Corbett is just after this) Saves you tons of traffic and endless jams plus would be shorter. Atleast on upward leg of the journey.
Third plan to be in Ramnagar at noon by latest (leaving time for contingencies) if you plan to stay in side the forest area. No entry late in the evening as all traffic inside is stopped at sundown. That said plan previsou night at Agra and you can achieve this.
Hyderabad --> Agra: Guru's here can tell you better although roughly it should be Nagpur/Sagar/Jhansi/Gwalior/Agra. I have no idea of road conditions. Or there could be some other alternative.
__________________
Sudev
sudev is online now   Reply With Quote
Old 23rd November 2008, 12:22   #3 (permalink)
gd1418's Avatar
Joshua, have you tried locating your route on mapmyindia? If not, then it is here - MapmyIndia - maps, directions, and local search across India - just search, print and go!
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 23rd November 2008, 12:30   #4 (permalink)
Eddy's Avatar
This might help you once you get to Delhi
Travel Guide to Jim Corbett National Park : Delhi-Corbett - India Travel Forum, BCMTouring.com
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 53K Kms
Ford Ikon Flair Sep 04 - 70K Kms
Eddy is online now   Reply With Quote
Old 23rd November 2008, 14:40   #5 (permalink)
hvkumar's Avatar
The shortest route to Corbett would be on NH7 via Adilabad, Nagpur, Seoni to Laknadon, then NH27 via Narasinghpur, Sagar, Lalitpur, Jhansi to Gwalior, then NH3 via Morena and Pholpur to Agra. From Agra, you can go via Hathras to Moradabad, and from Moradabad to Ramnagar and Corbett.
However, problem areas are as follows:
- NH7 widening work from Hyderabad to Nagpur
- Terrible roads on NH27 from Laknadon to Lalitpur
- Bad roads from Lalitpur to Gwalior
- Avoidable roads between Agra and Moradabad
The alternative route is via Bombay which is very long but extremely fast since it will take you on NH9 to Pune, the expressway to Bombay, NH8/NH76/NH79 from Bombay-Thane all the way to Delhi via Surat, Baroda, Ahmedabad, Udaipur, Chittorgarh, Bhilwara, Kishangarh, Jaipur, Delhi, Hapur, Gajraula, Moradabad.
I have discussed the 2 routes in an earlier thread, maybe you can search out the forum, you will also get comparative distances and time plans there.
Will be happy to work out the route details further. I have been to Corbett, but from Bombay and via GUjarat, Rajasthan and Delhi, not through the Central India route.
In any case, please see the following log books for some guidance:
H V Kumar - Driving Log Books - KUMAR'S DRIVING LOG BOOKS Kashmir to Kanyakumari, Dec 2002
This one has the route from Hyderabad to Agra via Adilabad, Laknadon, Sagar, Jhansi, Gwalior, but in the reverse North-South direction.
H V Kumar - Driving Log Books - KUMAR'S DRIVING LOG BOOKS Uttaranchal, North India, Oct 2006
This one has the route from Bombay to Corbett via Baroda, Ahmedabad, Udaipur, Jaipur and Delhi
I would avoid the trip in January because it will be very foggy at that time - thgis means very tough driving conditions for half the day, and also reduced sightings in the Park itself. Besides, this is also the peak foreign tourist season in that area. Mid-Feb would be preferred.
__________________
Kumar
2005 Mahindra Scorpio 2.6
1999 Daewoo Matiz SE
1994 Mahindra Commander
1986 TVS Suzuki AX100
hvkumar is offline   Reply With Quote
Old 24th November 2008, 03:02   #6 (permalink)
joshuakeys's Avatar
Hvkumar thanks a lot for the information above. your suggestions & information helped me a lot for my privious trip to mahabaleshwar. I wanted to know how much distance will it take if we go Via delhi & how much will it be Via Mumbai. after reaching there what about the stay? how much will it cost for a stay? can we stay inside the forest, heard about the rooms in dakila, but sounds very expensive. needed some information, please help
Old 24th November 2008, 07:40   #7 (permalink)
sudev's Avatar
One: As HVK says January is not ideal time. In that respect April/May are much better (though hotter) for seeing wildlife.
Two: The huts inside the reserve area are not expensive but getting a booking is a chore. Done through Director Project Tiger at Ramagar. Any one having address details?
There are so many resort outside the forest periphery ranging for all budgets. Starting from Tourist corporation hostels to luxury resorts.
__________________
Sudev
Old 24th November 2008, 09:29   #8 (permalink)
hvkumar's Avatar
Hyderabad-Agra via Nagpur and Sagar is around 1,350 kms.
The route via Bombay to Agra (via Jaipur) will be very long, nearly 2,200 kms.
As sudev mentions above, there are several hotels on the fringes of the sanctuary on the road between Ramnagar (closest town to the WLS) and Dangarhi Gate (the entry to Dikhala). I have myself stayed in the Corbett Camp which is n5 kms from the Bijrani Gate (and Ramnagar). If you search for hotels on the net, you will find ample choices.
AS far as getting into the FRH at Dikhala is concerned, it is very difficult, and the Forest Dept has the standard practice of saying all rooms are full. They also reserve rooms for VVIPs and that reduces the numbe rof rooms further. Your best bet is to stay at one of the hotels. Please bear in mind that getting into the WLS through the 4 gates (Bijrani, Jirna, Dangarhi and one more (cant recollect name) is a difficult exercise since they allow only limited number of Gypsies into the jungle at the designated times and these are often "full" even before the Q starts.
__________________
Kumar
Thread Tools
A Trip to Jim Corbett Bala_R Travelogues 24 9th November 2009 19:34
Delhi - Jim Corbett abhinav.gupta88 Route / Travel Queries 22 2nd October 2009 22:09
Chaukori - Pangot - Jim Corbett National Park trip in summer 09 abk Travelogues 10 25th September 2009 21:03
Different Shades of Green-A Trip To Jim Corbett National Park deky Travelogues 32 17th March 2009 20:02
Jim Corbett & Naukuchiatal Country Road Travelogues 21 22nd August 2008 17:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
