Closed Thread
Old 23rd January 2009, 22:01   #1
Default Which GPS maps are best for India?
Folks, I am going on a trip to Manali soon and currently researching who has the best GPS maps available for the Shimla/Manali/Dharmshala areas in Northern India. I am looking for general real time tracking with the built in GPS receiver, I am not looking for navigation.
I have Nokia maps loaded on my 5800, but its mostly only for the 8 big cities in India. Has anyone tried google maps or yahoo maps? Are they any good for India? Please advice, thanks!
xxaarraa is offline
Old 24th January 2009, 01:05   #2
tsk1979's Avatar
Thanked: 16,421 Times
If you are not into routing, then you can use mgmaps to download google maps and use them. They are pretty decent, and free too
tsk1979 is offline
Old 24th January 2009, 01:50   #3
Thanked: 212 Times
Very much the case, I use them since many months. You can also use Yahoo India maps (in.maps.yahoo.com), and these being based on mapmyindia are generally more detailed outside metros and big cities than google maps. Google is improving all the time, though.
I have also used mgmaps for routing and navigation, but that's in US. It uses google for the routing and driving directions. One day google will add driving directions for the India map, and then mgmaps will get even better for users in India :-)
lancer_rit is offline
Old 24th January 2009, 12:12   #4
Abes's Avatar
Thanked: 57 Times
Default OpenStreetMap
I found this on the web, OpenStreetMap, where one can use, share and contribute to free open source street maps. Detailed Information could be found at OpenStreetMap - Wikipedia, the free encyclopedia
Since I own a Garmin device, I found the cloudmade (CloudMade Downloads) interesting as they have Garmin Map Files
Abes is offline
Old 24th January 2009, 15:03   #5
rkbharat's Avatar
Thanked: 613 Times
Most of the mapping companies like satguide or mapmyindia does not have a very good maps for Himachal, specially navigation, which anyways does not works on hills.
For tracking puspose, Google nad Yahoo maps are the best, but unfortunately none of them is perfect for all the areas in Himachal. Yahoo has best maps as compared to Google, in Himachal.
I suggest you use MGMAPS and download, zoom level 13 for all Himachal and zoom level 17 for main places Shimla, Manali, Dharamshala etc.
and download for both Yahoo and google, should be around 500 mb of spaces required for all.
You can refer to steps I documented here, but its more specific to WM6.
http://www.team-bhp.com/forum/1109162-post681.html
be aware that in.maps.yahoo.com is localized for language. So might see Punjabi, if you download Ludhiana map. Safest bet is maps.yahoo.com.
rkbharat is offline
Old 24th January 2009, 16:18   #6
Thanked: 212 Times
rkbharat, maps.yahoo.com didn't have the details for India that in.maps.yahoo.com has when I actively compared all online maps available for India including maybe 6-8 months back. I just took a look now, and that situation seems to have changed. OTOH, could you confirm if the level of detail on maps.yahoo.com for India is same as in.maps.yahoo.com ?
BTW, I think I posted this in one of the threads earlier. I reported the vernacular language maps issue in the mgmaps forum, and this was fixed with v1.39.17. So, my in.maps.yahoo.com maps are rendered in English since many months :-) IIRC, the map URL needed a language specifier once Yahoo India added local language support - it defaults to the language of the map area, I guess.
Also, mgmaps has been made opensource a short while back. If some has Java MIDP knowledge, and they could contribute to mgmaps development esp since the author is quite busy with professional work from what I understand.
Cheers,
Old 24th January 2009, 18:16   #7
rkbharat's Avatar
Thanked: 613 Times
Details are 98% same, I found some of the POI are bit on the wrong position in maps.yahoo.com. Other both are almost same.
Also basically when you download the maps using mapcacher.com, it downloads the localized map. No idea how I set he language. so I downloaded from US version. good for me.
rkbharat is offline
Old 24th January 2009, 18:27   #8
mmmjgm's Avatar
Thanked: 21 Times
I use google maps for the Nokia E90, great job, very accurate, (works without network thanks to built in GPS in the phone) Tracks rural areas as well within India.
Nokia maps do not have B & C cities, major cities are fine, but out on the highway and on kuttcha Google maps is the best. Google maps works while tracking your moving position as well, it was accurate to +/- 2 feet. very neat !
I have yet not experienced Mapmyindia or equivalent on the move. May be you may need to upload their firmware for India. By and large, google maps is the best IMHO, I am not a power user for this as the battery of the phone goes in 4 hours (standby) as against 48+ hours.
mmmjgm is offline
Old 24th January 2009, 21:53   #9
As per my understanding, Google Maps were not working with Mgmaps.
Only Yahoo is working. Is there any version which supports Offline google maps ?
dskumar is offline
Old 24th January 2009, 22:45   #10
tsk1979's Avatar
I use OSM too, but himachal is not very well mapped, the main highways are there, thats about it. However I think mgmaps does work with google maps as well as yahoo maps and you have to select the tiles to download, and you can have them on your cell
tsk1979 is offline
Old 24th January 2009, 23:12   #11
Thanked: 212 Times
Offline google maps does work with mgmaps. I have it running on my N95 since last 1.5+ years :-)
Ok some history - google had served a notice on author of mgmaps (since they started copying mgmaps and similar apps and came up with Google maps for mobile). So, Cristian (mgmaps author) was required to remove explicit support for Google maps from the phone menu for map types. However, he added a 'custom' map option in which you can add the right URL for Google and be able to browse Google maps online. Also, you are able to cache Google map tiles offline and use them though this may violate Google Map terms. Very strangely, Google didnot serve a similar notice to j2memaps which continues to support Google maps explicitly.
Oh, I see now. Using the latest mgmaps versions, allows online access to Yahoo India maps get the English language maps. The offline map download utility needs to be changed to use the modified URL as well, which may not be the case. This should be a trivial fix in the perl script or the GUI program (easier for the perl script). mapcacher.com just generates a .map file with rectangle coordinates for which map tiles need to be downloaded.
For bhpians interested in mgmaps, you could browse these links
Mobile GMaps :: Index
Mobile GMaps - Map Tile Caching tools
Map Creation Tool for MGMaps
Old 25th January 2009, 12:54   #12
Thanked: 58 Times
Default N73 mgmaps
Will mgmaps works in N73 music edition. Please suggest
sam003 is offline
Old 25th January 2009, 13:56   #13
Thanked: 212 Times
Sure. You would need a bluetooth GPS receiver to be paired to your phone. For the phone support in mgmaps, you can lookup their website, and also the download page.
Old 23rd July 2009, 13:03   #14
wildon's Avatar
Thanked: 1,061 Times
Default Gps Unit With Maps
Guys, I'm looking forward to purchase a good GPS unit with maps. Can anyone of you suggest a good one. Most of my travel comes in Karnataka, Kerala , Tamilnadu and Andhra Pradesh. Which manufacturer provides the better maps for these south states. Please suggest?
Is there is any alternate method of getting customized maps from google india maps or yahoo india maps
wildon is offline
Old 23rd July 2009, 15:14   #15
MileCruncher's Avatar
Thanked: 357 Times
If you have a GPS enabled phone with a data connection then you can buy the software from Map My India MapmyIndia iNav : GPS navigation for mobile phones! Nokia, Blackberry, HTC, ASUS GPS phone navigation software all India
Btw wanted to know from Garmin / MapmyIndia users whether they have detailed road mapping for J&K or not.
MileCruncher is offline
Closed Thread
The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc) speedonline Gadgets, Computers & Software 3608 3rd July 2018 11:23
Where to find India's Maps for Garmin GPS maxj2005 Gadgets, Computers & Software 179 20th September 2015 06:11
Sygic Maps Vs MMI maps, what's the difference? rkbharat Gadgets, Computers & Software 38 1st July 2014 07:43
Using Google & Yahoo India Maps on standalone GPS Device Haste Gadgets, Computers & Software 9 30th September 2008 19:59
Google maps mobile 2.0 - poor man's GPS tachobells Gadgets, Computers & Software 4 1st December 2007 11:19
