Old 29th April 2017, 10:42   #31
Thanked: 2,998 Times
Default Re: Delhi-Hardwar route info (& other details)
I would be starting from Jaipur around 5 am.
No time is early when you are coming from Jaipur - Delhi in morning. Roads and more importantly Tolls are chock-a-block early morning with 99 % of Truck traffic. It will be better if you start little late around 7-8. There is no way you can beat morning rush of Manesar -Gurgaon and then Delhi unless you start by 3 Am or so. If you don't have any work at Delhi, follow route suggested by SS-Traveller and start around 7 or later.
Turbanator is offline   (1) Thanks Reply With Quote
Old 5th May 2017, 16:21   #32
Originally Posted by Nohonking View Post
Dear shriram81,
I keep driving between Gurgaon and Haridwar(my hometown), so let me share with you that there is no easy way to bypass Delhi. Starting at 5am from Jaipur is a good decision, so should reach Gurgaon by 9 am (peak hour traffic). Then your route should be like this:
- Reach Gurgaon
- Continue on NH8
- Dhaula Kuan
- Take the loop towards ring road Moti Bagh
- Continue via AIIMS, NDSE, Lajpat Nagar, Ashram and then stay on ring road(keep left) to reach Sarai Kale Khan
- Turn right on NH24 (Nizamuddin Bridge)
- Cross Yamuna and head till Delhi-UP border comes (just as you will drive down the flyover at Ghazipur poultry)
- Turn left(you are in UP) and continue till Mohan Nagar
- Turn right (Metro construction is underway, so you actually need to take a compulsory left and then make a U
- After driving for about 5km, turn left towards Meerut and continue for about 140km till you enter Uttarakhand (district Haridwar).
There are however, some other ways too with in Delhi(and may be a bit better with traffic), but I do not want to confuse you so have advised you the easiest way. Anyways, traffic is everywhere!
Hope this helps. Thanks.
Cheers,
Simmi
Thanks Nohonking..
This is very well explained and indeed very helpful. I know no one can escape from Delhi traffic, however I appreciate the detailed route you have suggested..
shriram81 is offline   (1) Thanks Reply With Quote
Planning Delhi-Vaishno Devi. Please Suggest route Other destinations arunforu1 Route / Travel Queries 17 10th September 2013 00:57
Hardwar / Rishikesh Trip ramkya1 Route / Travel Queries 5 16th October 2009 09:26
Pune to Ooty, Route details and Info. abhijitaparadh Route / Travel Queries 14 30th July 2007 16:25
