Old 16th November 2010, 17:39   #61
DWind's Avatar
Thanked: 168 Times
Originally Posted by SafeDrive View Post
If I were to start from Chennai around 05:00 a.m., is there a nice place from where I can have breakfast by around 07:30? Also which are the nice petrol stations on the way? I would like to fill up once in between.
I had done Ooty-Chennai couple of months back. Would suggest taking Krishnagiri-Salem-Avinashi-Annur-Metupalyam (bye-passing Coimbatore). If you start at 5:00 am you can try the Deepam (Pallikonda) or at Vellore. I started for Coimbatore at around 5 AM and had breakfast at Chola The restaurant. It is just after Vaniyambadi as you go from Chennai. The food is good and not as pricey as A2B. Also, it is less crowded. The only drawback is it comes in your opposite side. Look for the restaurant immediately after the exit for Tiruppur branches off after leaving Vaniyambadi. If you reach the toll then it means you have missed it.
For fuel, you can either try the A2B Thoppur (COCO) or fill it at Salem.
DWind is offline   Reply With Quote
Old 16th November 2010, 17:51   #62
Thanked: 96 Times
Exit for Tirupathur and not Tiruppur, AFAIK
ajithbr is offline   Reply With Quote
Old 16th November 2010, 18:58   #63
ampere's Avatar
Thanked: 8,759 Times
Yes and more popularly, exit for Yelagiri hills.
Old 16th November 2010, 20:05   #64
cLJ
Don't use the Tirupathur/Jolarpat road to Salem, it is in very bad condition at many stretches and time consuming. It would always be better to come through Krishnagiri.
CLJ
cLJ is offline   Reply With Quote
Old 17th November 2010, 12:36   #65
SafeDrive's Avatar
Thanked: 47 Times
Thanks. How long did you take to reach Ooty?
SafeDrive is offline   Reply With Quote
Old 17th November 2010, 13:44   #66
ampere's Avatar
As HVK mentioned Mettupalayam-Ooty road is blocked. Go via Kotagiri.
Old 17th November 2010, 15:24   #67
Thanked: 7 Times
there was a news on papers yesterday that the meetupalayam-coonoor-ooty road has been thrown open.
here is the article for the same:
The Hindu : States / Tamil Nadu : Normalcy restored on Ooty-Coonoor National Highway
leylander is offline   Reply With Quote
Old 17th November 2010, 16:32   #68
ampere's Avatar
Thanks for that update. So things are limping back to normal. I heard its raining pretty heavy there.
Old 17th November 2010, 19:24   #69
DWind's Avatar
Thanked: 168 Times
While going I went to Pollachi first for a day and then went to Ooty. For return I started at 9:30 AM from Ooty reached Annur at 11 AM , Salem at 1 PM (Lunch and fuel fill up - time taken 50 mins) reached Krishnagiri at 3:15 PM had a puncture at Pachakuppam (after Ambur ) lost 20 mins here, reached Vellore at 5:00 PM to reach Chennai (Virugambakkam) at 7PM.
Old 14th November 2012, 17:05   #70
rock18's Avatar
Thanked: 54 Times
Default re: Chennai - Coimbatore - Ooty : Route Queries
I am planning to visit masinagudi from Chennai next week.
Please advise the best possible route.I will be travelling with my wife and 2yr old daughter.
Planning to use two of the below routes:
Route1:
Chennai - Krishnagiri - Dharmappuri - Thoppur - Mettur - Ammapettai - Athani - Sathyamangalam-Punjur-Bandipur-Masinagudi.
As per the map.this route passes through dense satyamnaghalam forest.so drive must be scenic as well as chances of wildlife sightings.correct me if i am wrong.
Route 2:
Masinagudi-Kothagiri-Mettupalayam-Avinashi-Perundurai-Salem-Attur-Ullunurpet-Tambaram.
Route 3:
Masinagudi-Mysore-Bangalore-Chennai.
I read in another thread that ullundurpet to Avinashi has become a 4lane highway now.
Please suggest the fastest and best route.
rock18 is offline   Reply With Quote
Old 14th November 2012, 17:50   #71
shankar.balan's Avatar
Thanked: 5,331 Times
Fast and smart route is Bangalore, Mysore, Bandipur, Mudumalai, Masinagudi, Sigur, Ooty, Kotagiri, Mettupalayam, Annoor, Avanashi, Salem and out through to Madras. Roads are great on this route.
Plenty of wildlife in Bandipur and Mudumalai. Good season for spotting too.
shankar.balan is offline   (1) Thanks Reply With Quote
Old 14th November 2012, 18:54   #72
ampere's Avatar
Originally Posted by rock18 View Post
Route1:
If you can avoid Chennai-Krishnagiri and take the Uludurpet option, thats worth it. Due to 6 lane conversion, there are quite many diversions.
So I would suggest Tindivanam-Uludurpet-Salem for both parts of the journey.
Now Salem to Masinagudi you have an option to go via Oooty/Gudalur or
take Sathyamangalam ghats.
If you take the Ooty option:
Salem-Perundurai-Avinashi-Annur-Mettupalayam-Ooty-Gudalur-Masinagudi
(Be aware that in most cases you will not be allowed descend down the 36 hair pin bends route. You will be asked to take the longer route via Gudalur)
If you take the sathyamangalam:
Salem-Bhavani-Athani-Sathyamangalam-Dimbam-Chamarajanagar-Gundlupet-Bandipur-Mudumalai-Masinagudi.
This I think should take shorter time, because you get drive lesser distance on the ghats. But having said that you have a 26 hairpin bends on the
Dimbam ghats and its possible that a truck break-down on one of these bends which can cause delay. The route is very good condition however.
Or just for the fun take one route while going and the other while coming!
ampere is offline   (1) Thanks Reply With Quote
Old 14th November 2012, 21:15   #73
rock18's Avatar
Thanked: 54 Times
Thanks for the route advise.That's the reason why i am going to masinagudi instead of Ooty.
Is there any reason why we are not allowed to descend? is it because the roads are very steep that they are giving preference to the vehicles climbing?
Should i have to climb ooty and descend down immediately??. That's too much of ghat driving in day.
If i type Tambaram to masinagudi in google maps,it shows a 3rd route. i.e once we pass sathyamangalam,there is a place called punjur and it takes a diversion from there instead of going to chamarajanagar,it goes to a place called talavadi and then straight to bandipur.
Is this road good? looks much shorter.
Thanks a lot for replying.I have a few doubts regarding the route(see bold).
Old 14th November 2012, 21:40   #74
ampere's Avatar
Its a narrow road and I think they give preference to climb
Since you go via Gudalur, it should not be a steep climb down. Should be possible in day. But the pain is crossing Conoor and Ooty.
First of firsts :Since you said Tambaram, please take the Uludurpet route to come to Salem.
Secondly I am not sure if access to Talavadi is allowed. Its a forest range. You can confirm with others. I am not too sure about it.
Old 14th November 2012, 23:41   #75
luvurride's Avatar
Thanked: 298 Times
The best will be Krishnagiri-Hosur-NICE Road-Exit at Kanakapura Road-Kanakapura-Kollegal-Chamrajnagar-Gundlupet-Masinagudi.
This will be excellent and scenic once you get onto Kanakapura road. Not too much ghats, less traffic, good tarmac and probably the fastest. The downside is there aren't any decent eateries. You have to plan your food stops before getting onto NICE Road or Nijaguna in Chamarajnagar. There are also quite a few resorts once you exit from NICE to Kanakapura road.
luvurride is offline   (1) Thanks Reply With Quote
Chennai-Mumbai-Chennai route queries jeevmenon Route / Travel Queries 89 7th November 2017 14:40
Coimbatore to Wayanad : Route Queries kippu Route / Travel Queries 27 9th January 2017 10:32
Chennai to Coimbatore : Route Queries Sideways Route / Travel Queries 117 27th November 2016 15:40
Chennai- Trichy-Coimbatore - Chennai -Route query Prem Ganesh Route / Travel Queries 14 22nd November 2013 14:22
