Old 6th August 2014, 16:57   #361
aneezan's Avatar
Thanked: 181 Times
Default re: Bangalore - Kanyakumari NH7 : Route Queries
Originally Posted by hamster View Post
Returned back from an uneventful trip to Nagercoil.
Did the same Bangalore-Nagercoil-Bangalore trip last week. Started from Bangalore on 26th July. The decision to go was made late morning on 26th. Hence we could start only at 11:00AM from Whitefield. Reached home in Nagercoil at 9:15pm. Average speed as per MID was 68kmph.
During the return, I started at 6:00 AM, and reached Whitefield at 3:30PM. Average speed was 78kmph. But more stops in between. Breakfast was at Sree Saravana Bhavan near Kovilpatti and lunch at Adyar Ananda Bhavan.
Overall, like yours, it was an UN-eventful trip. Previously, i have seen accidents and wrecked cars, but not this time.
aneezan is offline   (1) Thanks Reply With Quote
Old 6th August 2014, 17:25   #362
Thanked: 100 Times
Originally Posted by pramodpk View Post
The bypass to the Sarjapur town was blocked 3 months back when I returned from Kerala. I am planning another trip on Aug 14th. Should I avoid the Sarjapur - Bagalur route?
I saw that the byepass was blocked in my onward journey.
I had taken the byepass only once and decided never to take that route.
For me, I have been taking this route only during early mornings(before 07:00 AM) towards Bagalur and late nights(after 10PM) towards Bangalore.
Hence, there was never a requirement to use the byepass route.
Here is the route I take :
http://goo.gl/maps/7T1W9
While going towards Bagalur, after crossing the Sarjapur Bus Stand on the left, will hit a T junction, where I take a right and the first left after that. That road is a bit narrow with houses and shops on both the sides. This road joins at the byepass entry while coming on the other side.
Since I pass at odd hours, have never encountered any issues.
An alternative option would be take the bagalur-chikka-tirupathi-hopeform route. The chikkatirupathi turn is just before Sarjapur. Refer to the NH207 route in the same map.
Hope it helps
Aneezan,
So we were at the same place almost at the same time. Glad to know that your journey was also uneventful.
True regarding the accidents. In my previous trips used to see atleast a couple of accidents, one minimum in the Thoppur ghats. THis time it was NIL.
Believe I took more time than you.
Last edited by hamster : 6th August 2014 at 17:29. Reason: Added another response.
hamster is offline   (1) Thanks Reply With Quote
Old 6th August 2014, 17:51   #363
mpksuhas's Avatar
Thanked: 3,372 Times
What hamster is mentioning is this road I guess. This as mentioned by Hamster has a narrow stretch, it becomes a bit tricky if any bigger vehicles comes. I faced the issue when travelling an evening last month.
The proper route to cross Sarjapur (this route) was closed last month, from the look of it I don't think it will be ready by now.
Also, apart from this there was road work between Bagalur - Hosur, I guess this is what Aneezan mentioned. This is regular road work, nothing which requires dropping this route altogether.
mpksuhas is offline   (1) Thanks Reply With Quote
Old 6th August 2014, 18:34   #364
ampere's Avatar
Thanked: 8,760 Times
Guys, if you are starting from Whitefield, ITPL, Varthur, then take 207 right from there itself. Dont go via Sarjapur.
Dont take the Varthur road to Sarjapur either.
This is what I mean: Route Link
This goes past Sarjapur town. End to end 207.
ampere is offline   (1) Thanks Reply With Quote
Old 6th August 2014, 22:23   #365
Thanked: 284 Times
I always use NH 207 to bypass Banglore.
There is a small single road of 4kms occasionally pot holes manageable from ChikkaTirupathi
to the road from Malur -Hosur road than taking the NH 207 completely upto Hosur via Sarjapur.
This cuts short the travel time.
I usually take this road lorry traffic is troublesome as you have to get down the road to
give way to oncoming traffic.
gajadonga is offline   Reply With Quote
Old 7th August 2014, 09:10   #366
aneezan's Avatar
Thanked: 181 Times
I haven't taken that route. I usually take a right and take the Sarjapur-Atibele Road. The frustrating part comes when I have to dish out money at the toll.
I will try the above route suggested by ampere. However, what is worrying me is the stretch till 207 ie. the Sarjapur/Bagalur road.
aneezan is offline   Reply With Quote
Old 7th August 2014, 09:35   #367
pramodpk's Avatar
Thanked: 465 Times
I have taken this route once while returning but this is almost 15 KMs longer than the other route. Also, I would not take this route early in the morning as there are some isolated stretches. The route is very scenic though.
I usually go inside the town and do not take the bypass as there is no traffic early in the morning. Also, the narrow stretch is very small around 300 mts.
pramodpk is online now   Reply With Quote
Old 7th August 2014, 13:00   #368
ampere's Avatar
+1. Even I will always prefer taking the standard route and starting early. It always works better this way. The alternative is to be used only when:
- When starting later in day
- When one is bypassing Bangalore
Old 7th August 2014, 13:08   #369
aneezan's Avatar
Thanked: 181 Times
I too agree. I usually start very early in the day, either 4:00 or 5:00AM. The standard route works better.
I remember I took the interior route very early sometime in December, when it was cold and very foggy. I couldn't see a much in-front of me. It scared me to bits.
Old 7th August 2014, 16:54   #370
suresh_gs's Avatar
Thanked: 1,194 Times
How about this route via sarjapur, Berikai to Shoolagiri
http://goo.gl/maps/ykghd
suresh_gs is offline   Reply With Quote
Old 7th August 2014, 17:08   #371
ampere's Avatar
Typically I wont advice too much of interior roads, when with family. They are good for exploring when alone or with friends.
@gajadonga has tried this route. Some sections from Berikai to Shoolagiri are broken. Else its just about average. In fact I think he tried Berikai-Malur instead of Bagalur.
Old 7th August 2014, 17:31   #372
mpksuhas's Avatar
^ I dont think Berigai route will help in saving much time since-
1. There are no much deviations after Hosur due to road widening, infact in most part it is 6 lane till Krishnagiri.
2. Even if you take Berigai route you will have to join NH7 before Krishnagiri toll (which takes some time to clear during peak time).
mpksuhas is offline   Reply With Quote
Old 8th August 2014, 19:12   #373
sarathlal's Avatar
Thanked: 2,049 Times
Normally for the Bangalore to Tvm runs, I use to start between 3-5 AM from Bangalore.
But on all the occasions, had to struggle through the Nagercoil traffic in the evening.
To try and avoid that, am planning to do a 1 PM start from Bangalore this time, after lunch.
This would mean, I can reach Muppandal by 11 PM, so the traffic would be less and can reach Trivandrum by around 1.30 AM.
Is this timing better to negotiate off the Nagercoil traffic?
sarathlal is offline   Reply With Quote
Old 8th August 2014, 23:39   #374
arun_josie's Avatar
Thanked: 4,332 Times
After 10:00 PM, it would be a easy pass through nagercoil. And even reaching Trivandrum won't take much time.
arun_josie is online now   (1) Thanks Reply With Quote
Old 9th August 2014, 13:50   #375
sarathlal's Avatar
Thanks. Was bit hesitant on taking this timing, as am unaware of the driving conditions during night time over the Madurai - Tvm stretch with a little boy on board .
Bangalore - Madurai - Kanyakumari - Rameshwaram : Route Queries kaushik_s Route / Travel Queries 95 14th December 2015 17:23
West coast route query Bangalore-mangalore-Kanyakumari-Bangalore hemanth.anand Route / Travel Queries 26 6th December 2014 11:19
Bangalore - Nagpur NH7 (or now NH44) in one day! XH_Vee Travelogues 37 25th December 2011 18:14
Bangalore - Kodai - Madurai - Kanyakumari (NH7 Lifeline) pramod Travelogues 121 22nd June 2010 18:59
Bangalore to Krishnagiri - is NH7 broken? Gandhi Route / Travel Queries 12 31st January 2010 22:06
