| Route / Travel Queries Guidance on the best routes and other travel related queries |
| | Thread Tools |
| | #241 (permalink) |
| BHPian Join Date: Apr 2009 Location: Chennai
| Nainar, you have a very valid point. So it will be good if you keep your headlights in low beam when you have intention of following the guy ahead. If you keep your headlights in high beam for sure you are causing lot of trouble to the guy in front of you (you are blinding him). Very less stress for sure and have followed this technique many times when I want to relax a little bit. |
| | #242 (permalink) | |
| BHPian Join Date: Jan 2008 Location: Hyderabad
| Quote:
__________________ Swift VXi | |
| | #243 (permalink) | ||
| BHPian Join Date: Mar 2006 Location: mumbai
| Quote:
I HATE tailgaters.... Most of them get the middle finger in the mirror treatment and either i speed away or slow down to crawling speeds. Sometimes sudden acceleration/braking and swerving works well Quote:
It helps if you treat all other road users as uneducated and compensate for their lack of skills. I believe this is called defensive driving? Last edited by bblost : 5th November 2009 at 09:32. Reason: back 2 back posts, please use multi quote instead. | ||
| | #244 (permalink) |
| Senior - BHPian Join Date: Dec 2006 Location: Bendakaluru
| Tailgating in the night with 7-8 seconds distance is fine and sometimes overly cautious. It really helps when you have an experienced driver in front and one who knows the road conditions like the back of his palm. It saves a lot of time and energy and stress levels are also in check. But, to each his own.
__________________ Money is not everything in life, but make sure to make a hell lot of it, before you speak such nonsense!! Last edited by prince_pervez : 5th November 2009 at 09:28. |
| | #245 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| I don't think I would call a 7-8 second gap "tailgating" --- although these things are strictly speed-relative. Whether it is fine or not rather depends on whether the person you are following thinks it is fine, and on what happens when they slam their brakes on. The added hypnotic effect of night driving, the greater difficulty of judging distance, and the likelihood of tiredness mean that distances at night should be much much greater than in the day. Remember, also that even if your response times are not diminished by tiredness, those of the guy in front of you may be. As to having an experienced driver in front: unless it is your friend, how are you ever going to know that? |
| | #246 (permalink) | |
| BHPian Join Date: Aug 2007 Location: Bangalore
| Quote:
So, please do not tailgate, how ever cool and relaxing that technique may be. The risks outweigh this comfort. Nainar | |
| | #248 (permalink) | |
| Quote:
Some drivers use this signalling (wrongly) when driving through thick fog. | |
| | #249 (permalink) | |
| Quote:
Nainar | |
| | #250 (permalink) | |||
| Quote:
![]() Quote:
1) Let the driver ahead of the caravan know that I am going to stop at the shoulder of the road so you too stop. 2) In a tunnel to make known the distance at all times not only after the brake lights have been lit after braking.
__________________ Money is not everything in life, but make sure to make a hell lot of it, before you speak such nonsense!! Last edited by prince_pervez : 6th November 2009 at 12:31. | |||
| | #251 (permalink) | ||
| Quote:
![]() And is'nt switching on the headlights/parking lights switch on the tail lights also, which is a better option than hazard light? Nainar | ||
| | #252 (permalink) | ||||
| Quote:
| | #253 (permalink) |
| Senior - BHPian | Tailgating is simply not recommended. Maintain visual contact if you are following someone but stay good distance away. For reference check the spy novels and movies on following someone without being discovered. I do not know about experience or lack of it, but a good driver is easy to spot. The vehicle will travel in a smooth line maintaining a constant distance from the edges of the road, the vehicle will not swing from one part of the road to the other, any changes in direction will be smooth (to avoid potholes, stones, obstacles etc.). He will not tailgate. He will plan his overtaking and overtake neatly i.e. move to the right after ensuring that there is no traffic then accelerate neatly and not cut back in too fast. Good/bad, experienced/inexperienced does not really matter, if you are comfortable following him and your styles of driving and speeds match you may follow him. Signalling language changes from region to region (a bit like the local language), it is best to observe the traffic patterns and signalling behaviour and interpret them without reference to what they do in the Americas or Europe. Drivers switching on hazard lights when driving is because they think they have to extract every penny's worth out of the gadgets in the car. There are only two situations in which hazard lights can be used - (1) car is stationery and in distress and, (2) there is a serious hazard ahead (traffic pile up, road washed away, water flowing over the road, ice on road or landslip. Every other usage of hazard lights on a moving vehicle is wrong. I have seen Indicab drivers (who else!) drive through an intersection with hazard lights on to indicate that he is going straight, his logic: since both indicators are on, they cancel each other out meaning I am going straight. Personally, I do not mind ambulances using their hazard warning lights in conjuntion with their flashing lights and siren and think it is justified. What Thad wrote is the correct way of signalling to the vehicles in a convoy to stop. (Not the turning around and gesticulating but the slowing down and using left indicator). Cheers,
__________________ Live to drive! (For commuting - take a bus) Last edited by Ravveendrra : 6th November 2009 at 18:25. |
| | #254 (permalink) | |
| Quote:
*Your analysis of the good driver in front is very informative. Such a driver will observe lane discipline, but without cutting in and out fast. When one follows such a vehicle , and the driver changes lane, one knows there is a good reason and can act accordingly. Of course, the cow they are driving around may have moved by the time we get there! *I wasn't really serious. Of course, if they are your friend, you just call them up on the mobile. ... Or send them as SMS! ![]() | |
| | #255 (permalink) | |
| Newbie Join Date: Oct 2009 Location: Hyderabad
| Quote:
I believe, this should be the primary rule for anyone driving on highways
__________________ Harish -1998 Kinetic Marvel -2005 Honda Unicorn -2008 Zen Estilo VXI | |
| Thread Tools | |
Similar Threads | ||||
| Day Driving or Night Driving? | sudheermenon | Street and Travel Experiences | 232 | 13th November 2009 16:00 |
| Fast driving is not rash driving - Delhi HC | tsk1979 | Shifting gears | 17 | 27th March 2009 15:49 |
| Expected Posting Etiquette | Administrator | Announcements | 0 | 2nd December 2008 19:15 |
| Frustration / Anger / Basic etiquette | rkavthekar | Street Experiences | 7 | 23rd September 2008 11:11 |
| Driving Etiquette in different countries | appuchan | The International Automotive Scene | 5 | 17th May 2007 21:26 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
