Old 25th May 2009, 12:55   #1
Thanked: 7 Times
Default Route Info Needed : Bangalore to Viruthachalam(TN)
Dudes,
I need to travel on 28 th March, to Viruthachalam ( TamilNadu ) from Bangalore for a marriege. I need you guys to help me about the route and it is little bit urgent too.
One route I knew is bangy-> krishnagiri-> Thiruvannamalai-> thirukovilor-> panrutti-> viruthachalam.
I would like to know any other short/best routes available to viruthachalam.
Also I would like to know current status of the road conditions in the route I mentioned above.
Your help would be greatly appretiated.
Thanks.
double is offline   Reply With Quote
Old 25th May 2009, 14:39   #2
Thanked: 31 Times
Panruti is a little bit of roundabout. The other option is to take the right into NH45 once you hit it on the way from Thirukoyilur - Panruti. However this road is being 4 laned.
You take NH45 and after about 25 kms (not very sure) take left towards Mangalampet and Virudachalam. Check out mapmyindia.com.
Roads from Krishnagiri towards Thiruvannamalai are in ok condition. After the rains its a little bit dodgy at places. Watch out for some sharp curves. Ask in Thiruvannamalai for the route towards Thirukovilur. You would need to take a right from Thiruvannamalai but where the right is any amount of writing will not help. Best is to ask a cop.
csentil is offline   Reply With Quote
Old 25th May 2009, 17:53   #3
Thanked: 142 Times
You could also do Bangalore - Salem - Attur - Thalivasal - Veppur - Vridachalam. It could be longer by about 20 kms but you would get good roads upto Salem. If somebody can confirm the conditions of Salem - Veppur stretch then you could consider this.
pypkmsrikanth is offline   Reply With Quote
Old 26th May 2009, 09:00   #4
Thanked: 28 Times
Salem- Athur- kallakurichi- ulundurpet- vridhachalam.
Ideal route.
PRADEEP KUMAR is offline   Reply With Quote
Old 27th May 2009, 12:21   #5
Thanked: 142 Times
Ideal route.
You can go straight to Vridachalam from Talaivasal via Veppur (cross the NH 45) instead of coming via Kallakurichi, Ulundurpet isnt it. If you are suggesting the route via Ulundurpet on account of road conditions I suppose then its a different issue.
Bangalore to Nagpur : Route Queries sammyboy Route / Travel Queries 104 26th May 2018 08:41
Route info needed - Bangalore to Kanyakumari naveenroy Route / Travel Queries 20 5th August 2011 14:37
Bangalore-Jog-Karwar-Dharwad-Blore....Route Info Needed? explorer09 Route / Travel Queries 4 21st December 2009 19:39
Route info and Human companion needed from Bangalore to Gurgaon (with 3 dogs) :D AlokSriva Route / Travel Queries 34 18th May 2009 19:42
