Old 6th January 2016, 08:25   #271
J.Ravi's Avatar
Thanked: 3,880 Times
Default Re: Valparai - Staying Options And Other General Info..
Originally Posted by hyper-VTEC View Post
And about eateries - are there enough in this route?
For more details, visit here.
Last edited by ampere : 6th January 2016 at 08:33. Reason: Fixed image size; cross linked from referred post
J.Ravi is offline   (1) Thanks Reply With Quote
Old 6th January 2016, 10:06   #272
NPV
NPV's Avatar
Thanked: 3,607 Times
Please note, getting past Pollachi onto to Valparai road is a tricky affair. Check Posts#248 onwards for this. Just note, you will come into Pollachi via 209.
There are multiple options now depending on which direction you're entering Pollachi from
The railway overbridge near the Pollachi Railway station is now complete and that road in general is wide and is the road coming from Kollengode so that leads to Market Road and the Mariamman temple junction where you can turn right on to the Aliyar/Valparai road.
One can even use the NH209 inside Pollachi town (as marked on gmaps) which is the road to Udumalaipet and then turn right at the water tank as mentioned in your earlier post.
NPV is offline   Reply With Quote
Old 6th January 2016, 10:22   #273
ampere's Avatar
Thanked: 7,561 Times
I still doubt that NPV. Can you please point it on the maps as to which are the other options? I still think that routing option we have been using is the only option to get on to Aliyar side, in spite of the flyover being complete. Because the flyover was not the problem. If one is coming to Pollachi from Coimbatore, Palakkad, Palladam or Udumalpet sides, one WILL HAVE one to use the same route that we have discussed earlier to get onto Aliyar road.
Only if one is coming down to Valparai from Kollegode, he need not take the discussed route for Aliyar. He can get on to the to railway station flyover straight away.
Is this what you were referring to? Pollachi Bypass: NH209 to Aliyar
Old 6th January 2016, 10:57   #274
NPV
NPV's Avatar
No. This is the one I was referring to:
https://goo.gl/maps/Ae1z3G2cbfE2
Old 6th January 2016, 12:11   #275
ampere's Avatar
That route does not work. Thats what I was trying to clarify. See post #248
Old 6th January 2016, 12:43   #276
Thanked: 154 Times
I will be traveling from Chennai
Thanks. My target is better roads and stop-over options. Keeping that in mind would your suggested route be better? TIA
Why not take the Trichy Dindigul udumalapet route as outlined in the screen shots attached ? The road from udumalapet is a bit iffy but it would add to the wilderness of the trip.
Valparai - Staying Options And Other General Info..-screenshots_20160106123552.png
Valparai - Staying Options And Other General Info..-screenshots_20160106123718.png
sunsetorange is offline   (1) Thanks Reply With Quote
Old 6th January 2016, 14:34   #277
Thanked: 138 Times
Would have loved to do it if it was a solo drive. With family it might be an issue.
hyper-VTEC is offline   Reply With Quote
Old 6th January 2016, 14:50   #278
NPV
NPV's Avatar
See this earlier post - this works in both directions, so for onward to Aliyar/Valparai, get on to the NH209 towards Udumalaipet and turn right after Vasantham hotel near the water tank.
http://www.team-bhp.com/forum/route-...ml#post2796084 (Route from Trichy to Palakkad)
Or even the one marked on that image with Arrows to Point B since the junction is now open after the flyover construction was completed.
NPV is offline   (1) Thanks Reply With Quote
Old 6th January 2016, 15:53   #279
ampere's Avatar
Thats exactly what I am saying. It does NOT work!
I think the flyover has nothing to do with it. See post 248. That picture depicts the scenario.
Old 7th January 2016, 08:57   #280
Thanked: 138 Times
Now that stay, route and eateries are mostly set, next is food for the beast. Any good (preferably COCO) fuel stations on the way?
Old 7th January 2016, 09:36   #281
ampere's Avatar
There is a COCO bump just once you exit Salem. Its along with a A2B and Polar Bear Ice Cream Joint. Pollachi has a couple of good bunks.
Old 8th January 2016, 12:58   #282
Thanked: 138 Times
I read earlier that only BSNL works on Valparai. The person I made the booking with mentioned Vodafone works in some areas. Any pointers?
We are all with Airtel :(
Old 8th January 2016, 13:19   #283
NPV
NPV's Avatar
When we visited in 2012, only BSNL worked well, only at some places Airtel signals worked!
Old 8th January 2016, 17:04   #284
h14
h14's Avatar
Thanked: 1,176 Times
Aircel and Vodafone also works in few areas. Not sure of Airtel.
h14 is offline   Reply With Quote
Old 13th January 2016, 21:13   #285
Thanked: 138 Times
One quick question - from Avinashi once i continue towards Coimbatore - is the by pass to Pollachi marked? Any pointers on how to know when to take off the road to CBE. Starting tomorrow 5:00 hours
Mitsubishi Cedia SPIRIT - Staying Ahead of the Herd... RajaTaurus Test-Drives & Initial Ownership Reports 150 8th November 2016 11:34
Sea beaches in West Bengal & Orissa - Route & staying options? Sheel Route / Travel Queries 23 25th November 2014 10:42
Route & staying options: Kanpur to Manali Devrishi Route / Travel Queries 5 3rd June 2012 21:06
