Old 13th January 2016, 21:22   #286
batterylow's Avatar
Thanked: 576 Times
Default Re: Valparai - Staying Options And Other General Info..
Originally Posted by hyper-VTEC View Post
One quick question - from Avinashi once i continue towards Coimbatore - is the by pass to Pollachi marked? Any pointers on how to know when to take off the road to CBE. Starting tomorrow 5:00 hours
There is a flyover under construction at the point where one diverts to Coimbatore. Plus I remember seeing sign boards also.
If your target is the Pollachi bye pass, take the road to the left.
batterylow is offline   Reply With Quote
Old 13th January 2016, 21:24   #287
ampere's Avatar
Thanked: 7,561 Times
Your question prompted me check Google. And I thought of this simple solution! See if it works for you.
- If you browse Google maps, and see the NH47/NH209 crossing you can see its a cross road and not a flyover.
- Move to satellite mode, you will see many folks have attached photos of that cross-road.
- In one of them I can see board being marked. So for sure you will see the marking for Pollachi (My guess)
- Secondly, on that cross road you should see Karpagam university buildings. So thats one more pointer for you.
Here are a couple of snaps which are available on the Google maps at that location in satellite mode
Location: NH47 <-> NH209 Cross Road @ Coimbatore Bypass
ampere is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 21:29   #288
Thanked: 138 Times
Thanks a lot @ampere. I will use this feature from now on.
hyper-VTEC is offline   Reply With Quote
Old 13th January 2016, 21:35   #289
batterylow's Avatar
Thanked: 576 Times
You have to take a left after Karpagam University.
Old 14th January 2016, 12:01   #290
NPV
NPV's Avatar
Thanked: 3,607 Times
You really have 2 options - either taking the Mangalam-Palladam-Pollachi route from Avinashi bypass on NH 47 (SH 166 per gmaps) OR
proceed further towards coimbatore, get on to L&T Coimbatore bypass and turn left after Karpagam university as shown in earlier posts/images.
NPV is offline   Reply With Quote
Old 9th February 2016, 16:48   #291
Smile Bangalore To Annamalai best root
Hi Guys
I am planning a trip to Annamalai wildlife Sanctuary next month. I will be driving from Bangalore with my family. Please advise the best root to take. Also I request please suggest a good plave to stay in the sanctuary. We are mainly going there to see some wildlife. Appreciate your help guys.
Helter Skelter is offline   Reply With Quote
Old 9th February 2016, 17:19   #292
ampere's Avatar
Default Re: Bangalore To Annamalai best root
Originally Posted by Helter Skelter View Post
Hi Guys
Moved your post here. Its the same route till Pollachi. You can go through the posts and get your answers.
Old 9th February 2016, 18:25   #293
NPV
NPV's Avatar
Get to Pollachi and then take the route towards Sethumadai and Parambikulam. Just outside Pollachi town is Anamalai town. On my recent trip to Parambikulam we went on this route and proceeded via Sethumadai and nearby I saw few "Resorts" that were really farmhouses/home stays. I think the TN forest department has cottages once you cross Sethumadai check post.
If you're going that far, I'd suggest you go a little more say 3-5 kilometers to the Kerala side at Parambikulam reserve and you have their cottages as options as well.
* see earlier posts on this page for Bangalore-Pollachi route options.
Old 9th February 2016, 18:32   #294
Thanks AMP. will follow Pollachi route as mentioned.
Hi NPV
Thanks for the info. Will follow the route to Pollachi and take Sethumadai & Parambikulam as mentioned by you. Would love to stay in the sanctuary. Hopefully will find a good place.
Last edited by ampere : 9th February 2016 at 19:02. Reason: Back to back posts merged
Old 10th February 2016, 06:24   #295
NPV
NPV's Avatar
Look up the Parambikulam website (kerala forest department), alternately the TN forest department website for accommodation option inside the sanctuary. These would be the best options I think.
Old 22nd February 2016, 10:50   #296
pramodpk's Avatar
Thanked: 405 Times
Please note, getting past Pollachi onto to Valparai road is a tricky affair. Check Posts#248 onwards for this. Just note, you will come into Pollachi via 209.
Also note Avinashi-Mangalam-Palladam-Pollachi is a good option. But if you now get 4-lane till CBE bypass, then why not take it instead of this. Hence I suggested Nh47/NH209 option.
Thats not the route.
You arrive here:
Here (At the end of the route that I have marked).
From that point you move to start of this location I mention here
Between the two points you cannot see the route in regular mode, but only can see in satellite mode.
I will be driving to Valparai this Friday. Planning to start at 5:00 AM and want to reach there for lunch. From the recent posts,
Coimbatore Bypass- Pollachi - Valparai seems to be the best option but I want to try other routes as I take this route frequently.
Which is better?
Perundurai - Palladam - Pollachi? Should I deviate after Annalakshmi Hotel?
or
Perundurai- Avinashi - Palladam - Pollachi?
Is the Coimbatore route is significantly faster than the others?
Also, how is the Omalur - Sankari route now? Want to take it to avoid Salem on a working day and the rush at Sankari toll booth.
Will google map help me navigate Pollachi? I taken the Pollachi route only once and it was very confusing.
thanks in advance.
pramodpk is offline   Reply With Quote
Old 22nd February 2016, 11:15   #297
NPV
NPV's Avatar
Coimbatore bypass route may be the fastest option now that 4 laning is complete. Get on to L&T bypass and turn left at second signal (Karpagam college).
Next option I would suggest is the Avinashi bypass-Mangalam (via Vanjipalayam Railway overbridge). Issue may be to find the turn off from Avinashi bypass since all flyovers are complete so you need to get on to service road. This turn off is just after one of the turn off's to Tiruppur.
Both above routes will take you to Pollachi (and meet perpendicular to each other near the bus stand/"New Scheme Road"). Navigating Pollachi may be an issue so better to ask there, not sure how good Google maps navigation is for this stretch. Look up other posts where @ampere has given route links with a turn off near a water tank for the Valparai road. I'm now quite familiar with Pollachi but still find it difficult to explain without the map
NPV is offline   (1) Thanks Reply With Quote
Old 22nd February 2016, 11:35   #298
ampere's Avatar
Which is better?
Try the Avinashi-Mangalam-Palladam-Pollachi route. Its nice.
Similiar timings I think. But ideally Coimbattore route should be faster by virtue of 4-lane.
If you want to enjoy the SH, by all means. Else, I would prefer Salem.
It is confusing indeed.
The following is the route to get on to Aliyar road:
link
Legend:
- 1 : Start Point
- 2-3-4: Via points
- 5 : End point.
So if you see the link the route between 4 to 5 does not exist. See in the satellite mode and you get correct route.
See Posts #248 and #250 of this thread
Old 22nd February 2016, 14:11   #299
NPV
NPV's Avatar
Just to add to my earlier response, I prefer taking the Mangalam route since it sees lot lesser traffic than Coimbatore bypass-Pollachi route (and I try to avoid L&T bypass unless going to Palakkad). Also this route will take you to Pollachi closer to the Aliyar/Valparai road whereas Coimbatore route will get you bang in front of the bus stand and can be confusing with lots of junctions.
For Avinashi bypass-Mangalam-Pollachi you can refer this post for guidance (hope it helps).
http://www.team-bhp.com/forum/route-...ml#post3576610 (All Roads to Kerala)
Old 22nd February 2016, 14:26   #300
pramodpk's Avatar
Thanked: 405 Times
thanks for your inputs. I will take the Avinashi - Mangalam - Palladam -Pollachi route.
Mitsubishi Cedia SPIRIT - Staying Ahead of the Herd... RajaTaurus Test-Drives & Initial Ownership Reports 150 8th November 2016 11:34
Sea beaches in West Bengal & Orissa - Route & staying options? Sheel Route / Travel Queries 23 25th November 2014 10:42
Route & staying options: Kanpur to Manali Devrishi Route / Travel Queries 5 3rd June 2012 21:06
