| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| Team-BHP Support ![]() | Yes I do know we can go from ORR to Hebbal and get onto BIAL but this is filled with truck traffic and sometimes takes ages. I had read somewhere that there is way to go from Marthahalli/Whitefiled near ITPL towards BIAL. Some state highway which goes all the way around the airport or something and one has to drive back towards the city and go to the airport. I want to give this a try but have no idea where this road is and if it does really exist. Where do I get onto it from Marthahalli and where does it come out near airport? Has anyone tried it? Pls. post the details here. |
| | #2 |
| Distinguished - BHPian ![]() | Viddy, check the maps for the area : it doesnt show any such sufficiently good road to by-pass this traffic. Red - standard route Blue - is it even possible ? Well, unless you are considering reaching the airport perimeter - on the far side of the terminal. And, the first 30% of this route is not free of trucks anyway. ![]() At the most, you could go into HBR Layout (right just before Manyata) and reach NH-7 after Yelahanka. EDIT : That road may even take you there, if you follow these directions given by MapMyIndia : Take the KR Puram Hanging Bridge and continue on Old Madras Road (NH 4)10.55 KmCross the following on way: Krishnarajapura, Bangalore South Taluka at 2km Basavanapura Nr Krishnarajapura at undefinedkm Medahalli at undefinedkm Veerenahalli at undefinedkm Hirandahalli at 8km Cheemasandra at undefinedkm Bandapura at 9km Turn left on Hoskote Road1.91 Km9Continue straight23.31 KmCross the following on way: Bommenahalli at 0m Mandur at 2km Shringaripura at undefinedkm Jothipura at 5km Thirumenahalli, Bangalore South Taluka at undefinedkm Manchapana Halli at 10km Gollahalli, Bangalore North Taluka at 11km 10Turn left on Bangalore Bellary Road (NH 7) Last edited by condor : 22nd November 2009 at 11:58. Reason: Adding directions |
| | #3 |
| Senior - BHPian Join Date: Jul 2006 Location: Dehradun -Bangy (Again :)
Thanked: 67 Times
| I know of one route from the Hennur signal. Take a right from the main road (Hebbal Rd while going from KR Puram to Hebbal) at the Hennur signal. Keep following the road, you will see lots of boards guiding you. It will take you a while though, to figure out which is the best way as they get you close to different areas on the airport road. The best one I follow is the one which comes out next to the petrol pump, about 1km from the Airport. The pump is on the opposite side of the road (if u are going towards the airport)in the service lane. The road is under construction in a few places, lots of speed bumps so you need to be careful but very little traffic. I prefer taking this route to the normal one. Though, would suggest you to take a drive to explore that route before using it as you might end up getting stuck and missing a flight . There is some construction happening somewhere and lots of options, which my wife realised when she took that route a few days back. She took one wrong turn and when she came back, the car looked like it has just come after the Paris Dakar. There is another way, coming from KR Puram OMR, cross the flyover at the tin factory junction and that road curves left somewhere taking you to the airport. Have been thru it just once so cant really give you 100% directions. Tell you what, will map the route the next time I go on it and create a thread with pics so its easy . Last edited by sammyboy : 22nd November 2009 at 12:00. |
| | #4 |
| BHPian Join Date: Jan 2008 Location: Bangalore
Thanked: 12 Times
| I stay in HSR Layout and have taken alternate routes to go to BIAL. This depends upon the time of the day. Early Morning before 7.00 AM : Through the city and then getting onto Raj Bhavan- Mekri Circle - Airport Between 7.00 AM to 11.00 PM : Through Marthahalli--> KR Puram--> Hennur Cross Signal--> Hennur Bund Road-->Kannur - Reva Instititute-- Yelhanka Air Force Base Station-- BIAL I would suggest taking the Road via Hennur Bund Road. The directions are as below Hennur Signal - Take right to get onto Hennur Bund Road . Continue on the road and drive past Kothanur. In Village Kannur , you would get a sign board with BIAL and Bagalur to go straight and Take left for Yelhanka. Take a left at this T Junction. Continue on the road till you get an under construction under pass. Take a right here and head strainght to Bagalur Cross road by crossing Reva Institute. On Bagalur Cross Road, take a left to join the NH to Airport. I would not recommend going through the other road (Old Madras Road, Hoskote)which joins NH7 after Aiport |
| | #5 |
| Team-BHP Support ![]() | Vid, The signal opposite to the new BEL HQ, opposite to Manyata Tech Park, ORR, Nagawara. One smallish road leads inside - bordering Lumbini Gardens lake, in the general direction of the airport. This is said to lead to Yelahanka and is said to be good. Dont know the name of the road nor I have tried it personally. |
| | #6 | |
| BHPian Join Date: Jun 2006 Location: bangalore
Thanked: 65 Times
| Quote:
From Marathahalli, go over the flyover and straight onto Forum mall, Whitefield (turning left). Follow this SH straight past the raliway crossing till you end at NH4. Take left, drive for a km or so, and take right. You drive through Budigere cross, following the main road (you see one or two signs indicating airport). After Budigere town, you'll come to a fork. The left goes through some narrow roads and turns and ends up on NH7 before the BIAL exit loop. The right is the main road joins upto NH206, and then your turn left onto Devanahalli town, and you turn left back to BIAL exit loop (from the Hyderabad side). In the latter, you pass BIAL from the other side, and can see the runway/terminal etc in the distance. If you are driving the first time (esp in the evening), I would take the ~10km longer route through Devanahalli town. The roads are great for most part (the scenery is pretty good too in daytime), and see pretty less traffic (though increasing a bit of late). Look out for unmarked big speed breakers near the villages / town , though. Cheers, Last edited by lancer_rit : 22nd November 2009 at 14:58. | |
| | #7 |
| Team-BHP Support ![]() | Perfect Lancer_rit, that was the road I was looking for. I know it will be longer in distance but should save on travel time if the traffic is thin. Also, does this road go through Hoskote town? From the map NH207 is through the town. |
| | #8 | |
| BHPian Join Date: Dec 2006 Location: KA 05, MH 10
Thanked: 61 Times
| Quote:
I have been taking ring road towards Hebbal from my apartment in Marathahalli, but I normally use it during night. The road which diverts from Hennur cross from ring road is advisable only during day time as its not safe during night time. Probably not many people know about it and there is less traffic. During my recent trip the Meru Cab driver who was taking me to airport commented that there have been some instances of muggings on this road. Better to be on safer side. Also I feel that ORR is a better option that you can get an alternative just incase you have a breakdown of the vehicle you are using, may be this is a bit far fetched but just incase, who knows. Anyway if you are commuting during night after 9:00, road marked in red by condor is the best option as there will not be much traffic and is much faster. Last edited by deepaktpatil : 23rd November 2009 at 13:15. | |
| | #9 |
Thanked: 61 Times
| | #10 |
| Distinguished - BHPian ![]() | I would still advocate going straight through town - I ve been using this route for some time instead of the outer ring road because the outer ring road frankly is quite dangerous with the lorry traffic etc. The route through the city if used in the early morning (around 5-7am) or in the mid afternoon (around 2-4 pm) or in the evening (around 8-930pm) (as per my experience) is perfectly fine. I say this because it takes me 1 hour to 1.5 hours usually from my residence to the airport in a Meru cab if I use this route. Even if I go on the ORR it still takes me roughly the same amount of time. Being located in Marathahalli would mean going past HAL, the old airport and hitting MG Road, going through the Ulsoor bit, Dickenson Road, then alongside the parade ground, hitting the Raj Bhavan, passing Windsor Manor, getting onto the Bellary road and out! - I think it is much better than the ORR and Hennur etc most definitely. The one non-negotiable here is to always leave plenty of margin for delays/traffic chaos/errors when one is heading to BIAL. Last edited by shankar.balan : 23rd November 2009 at 13:56. |
| | #11 | |
Thanked: 65 Times
| Quote:
no you don't have to go through Hoskote town. Basically, you take the SH (sort of parallel to NH207) which meets NH4 to the left of Hoskote town. If you are driving in daytime (early evening rush hours included) from Whitefield area, this is much better than going by ORR! I should know having been once stuck in 1hour + 1hour crawls on ORR and then on NH7 and barely making it to the airport at the flight departure time (luckily flight was delayed). | |
| | #12 |
| Team-BHP Support ![]() | There goes the serenity of this route! I am sure TBhp stickered cars with exhausts will be the norm on this road now. |
| | #13 |
| Distinguished - BHPian ![]() | It all depends on what time of the day that you are going? In fact you can also hop on the the Volvo service at Marathahalli. Thats the best you can get. |
| | #14 | |
| Senior - BHPian Join Date: Sep 2008 Location: Bangalore
| Quote:
Vayu Vajra Service (= volvo service for BIAL) is the best public bus service i have seen in India at least. | |
| | #15 |
Thanked: 12 Times
| Hey Vid, i know a route from Hennur signal which connects to Kogilu cross (Yelahanka new town junction) via Kothanur and Hegde Nagar. There a lot of twists and turns involved. I can accompany you and show this route whenever possible. Absolutely no truck or bus traffic. You will even hardly find cars on this route. It passes throught all possible villages surrounded by Farm houses (Kothanur etc). Let me know. |
Similar Threads | ||||
| Bangy Boys: Which area in Bangalore do you stay? | inder_s1 | Shifting gears | 555 | 23rd May 2013 11:24 |
| 3M Car Care, Marathahalli (Bangalore) | libranof1987 | Bangalore | 15 | 28th January 2013 12:51 |
| South Bangalore to BIAL | ranarula | Route / Travel Queries | 4 | 17th July 2011 09:20 |
| DIRT MANIA : Bangalore Boys Enjoy | eagle_f1 | Indian Motorsport | 11 | 27th August 2009 20:59 |
| Bangalore Roads after BIAL opening | maddy42 | Shifting gears | 28 | 9th March 2009 10:55 |
