Old 30th April 2010, 12:05   #16
Sportsmind's Avatar
Thanked: 28 Times
Cool
Originally Posted by sbraj View Post
This is a longer route. I have driven on both the routes, but I don't have the exact difference in distance. My guess is this route is longer by 50-70 KMs.
But traffic on this route is lesser, is a more scenic route. Once you are in Nilambur, take diversion towards Manjeri and further to Calicut. Nilambur-Manjeri-Calicut stretch is good, but two lane (as usual, in Kerala).
Once past Gundlupet, you would find shops and facilities in Gudalur, and then near Nilambur. Similar to NH212, where once past Gundlupet, you would find facilities near Sultan Bathery, and then near Kalpetta.
Did a distance calculator and got the route you described a total of 350 Kms(Blr-Mys-140km/Mys-Nil-135km/Nil-Cal-75km).
I guess the Bathery/kalpetta route totals to 340Kms.
So I take your route..Cheers and thanks
Sportsmind is offline   Reply With Quote
Old 30th April 2010, 13:51   #17
ampere's Avatar
Thanked: 9,125 Times
There is a JLR pugmarks hotel at Bandipur. You dont have to wait till Gudalur. But yes no shops as such.
Old 30th April 2010, 14:14   #18
sarinkumar's Avatar
Another option is the Nilambur route. Gundlupet-Bandipur-Mudumalai-Gudalur-Nilambur-Manjeri-Ferok-Calicut. Traffic is less on this route compared to Bathery route (NH212). Roads are good, but ghat section is little more twisty and curvy.
NH212 is open for traffic between 6am and 9pm. Not sure whether the same timing restriction holds for the Nilambur route.
The best route to Calicut is via Kalpetta.
sarinkumar is offline   Reply With Quote
Old 30th April 2010, 15:45   #19
sbraj's Avatar
Of course, yes. That is the staple route. One can opt for Nilambur route, just for a different option.
sbraj is offline   Reply With Quote
Old 3rd August 2010, 15:50   #20
Sportsmind's Avatar
Thanked: 28 Times
Can someone update me on the road condition on Gundlpet calicut road, especially during these rains. I know of heavy rains in kerala over the last few weeks. Is night driving fine on the Ghat section? I am driving down tommorow.
Old 3rd August 2010, 17:42   #21
ampere's Avatar
PM to Bigzero. He just went a week or two back.
Old 3rd August 2010, 19:46   #22
Thanked: 593 Times
Road upto Kalpetta is still good - barring a few pot holes in the forest road and a few very small bad stretches on the Muthanga-Bathery-Kalpetta section. I travelled that way last Saturday, but since I went only as far as Vythiri, not sure of the conditions of the Ghat section.
kala is offline   Reply With Quote
Old 10th July 2012, 10:09   #23
Thanked: 17 Times
Default Re: Gundlupet to Calicut - Road Condition
Hi friends,
Am planning to travel to Calicut through Gundlupet. Can I know
1. If by NH212, what are the current movement timings /restrictions ?
2. Comparison between Sultan Battery route and Gudalur-Nilambur route.
Would appreciate your help on the above.
SAPVEN is offline   Reply With Quote
Old 10th July 2012, 11:57   #24
Rajeevraj's Avatar
Thanked: 8,869 Times
Originally Posted by SAPVEN View Post
Hi friends,
1. the forest road is closed between 9pm and 6am (both the bathery route as well as gudalur route)
2. If you are going to Calicut, then the Bathery route should be the preferred one. Road conditions are good except for small stretches (Not sure if the monsoon rains have damaged anything). If you are going to somewhere in Malappuram dt, then the Nilambur route may be better.
If you are interested in taking the Bangalore-Kanakpura-kollegala-Chamrajnagar-Gundlepet route, you can find details in the following post in the Bangalore- Calicut thread
http://www.team-bhp.com/forum/route-...ml#post2769968
This thread has a lot of information on Bangalore-Calicut route.
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 10th July 2012, 12:07   #25
Thanked: 593 Times
Sulthan Batheri route would be faster since the highway between Kalpetta to Calicut is in very good shape as of now. The stretch between Kalpetta and Kerala-Karnataka border is somewhat patchy, but from Gundlupet to the border is in pretty good shape excepting a couple of largish potholes just after you enter the forest. Beware of frequent unmarked speedbreakers in the 5 to 10 kms just before the border (on the Karnataka side where the surface has been recently re-tarred).
Not sure about the road conditions on the Gudlupet-Gudalur-Nilambur-Calicut route since I haven't travelled that way for a while now. But I'd expect going to be slow from Vazhikkadavu to Calicut since that route passes through a large number of smallish towns and the traffic density is heavier.
As for allowed travel timings it's still the same as before - no traffic is allowed through the forest between 9PM and 6AM. (The same restriction applies even on the Gundlupet-Gudalur route if you decide to take that route)
kala is offline   (1) Thanks Reply With Quote
Old 10th July 2012, 12:59   #26
ampere's Avatar
I think its better to go via Bathery as Kala said. Take the regular NH212.
It should also be faster.
ampere is offline   (1) Thanks Reply With Quote
Old 10th July 2012, 21:37   #27
chandan's Avatar
Thanked: 46 Times
Any idea about the Mysore-HD kote-Mananthvadi-Bathery road ? I believe it is a shorter route.
chandan is offline   Reply With Quote
Old 12th July 2012, 12:05   #28
mpksuhas's Avatar
Thanked: 4,130 Times
Chandan, unless your plan is to travel between 09PM - 06AM (When forest section in Gundlupet- Batthery is closed) it doesnt make much sense taking HD Kote road since surface and road wise it is worse than NH-212
mpksuhas is offline   Reply With Quote
Old 12th July 2012, 17:29   #29
Thanked: 593 Times
If my memory serves me right even the HD Kote route is closed from 6PM to 6AM (it passes through the Nagarahole WLS).
And in addition the broken portion of the road (the detour through several villages for about 15 kms) is difficult to drive through in broad daylight, so I wouldn't even think of attempting it at night.
If one needs to travel after 9PM, the shortest route that would be open is the one via Hunsur-Gonikoppa-Kutta-Mananthawadi, and even that road is pretty bad between Hunsur and Kutta.
Old 12th July 2012, 17:54   #30
Thanked: 96 Times
Shortest route, YES !
Faster and comfortable route would be the one via Hunsur-Gonikoppa-Virajpet(bye-pass)->Iritty->Thalassery->Calicut. Lots of night traffic in this route and the road condition is generally good (not sure about the recent effects of monsoon) except a few kms in the forest section between Hunsur and Gonikoppa.
ajithbr is offline   Reply With Quote
Calicut - Trivandrum - Calicut Route Updates nairrk Route / Travel Queries 99 19th October 2017 15:13
1st ever Mini meet in Calicut. Post here for all future Calicut mini meets.. MaserQ The Team-BHP Meet Section 17 8th August 2017 04:32
Need some guidance on the Calicut - Pune / Mumbai road arunkmar Route / Travel Queries 13 25th April 2012 07:45
3 bhpians coming to calicut, calicut bhpians want a meet? pramodkumar The Team-BHP Meet Section 9 26th September 2011 21:51
Need some pointers! Calicut - Aluva - Rameshwaram - Madurai - Ramakkalmedu - Calicut Klub Class Route / Travel Queries 8 18th March 2011 12:45
