Old 9th April 2010, 12:50   #1
Rajesh K R's Avatar
Thanked: 56 Times
Default BLR-Munnar-Guruvayur-BLR Trip - Help needed
Dear T-Bhpians,
I am planning to undertake a trip from BLR to Munnar & Guruvayur and back sometime at the end of rainy season. The members of the trip will be Myself, Wife and my eight year old daughter.
My plan ( tentative ) is somewhat like this :
Day 1 : Leave BLR @ 3 PM and reach Perundurai - Night halt
Day 2 : Leave Perundurai @ 7 AM and reach Munnar around 12 noon
Day 2 : Do local sightseeing of Munnar for half day
Day 3 : Spend the day at Munnar ( local sights & spices shopping )
Day 4 : Spend the day at Munnar ( local sights )
Day 5 : Leave Munnar @ 7 AM and proceed to Guruvayur, have darshan
and leave for BLR ( Via BLR / via CBE ?? )
I would seek your valuable suggestions, opinions & guidance on the queries as listed below :
1) Route, distance & road conditions from Munnar to Guruvayur.
2) Whether it will be advisable to return to BLR from Guruvayur via Mysore
or via Coimbatore.
3) Will it be possible to cover the distance from Munnar to BLR with a
stoppage in Guruvayur ( maybe for 2 hrs) in a single day's time.
will it be too tiresome ?
Will be looking forward to all the inputs which will be of immense help to me in going ahead and planning the trip.
Rajesh K R is offline   Reply With Quote
Old 9th April 2010, 13:07   #2
ampere's Avatar
Thanked: 9,108 Times
or via Coimbatore.
Munnar to Guruvayur is about 180-200Km.
Route: Drive down to Muvatupuzza via Adimali on NH49 and then take the MC road via Kalady to hit NH47 at Angamaly. Then Drive to Thrissur and via Guruvaur and Choondal Road to Guruvayur. You should be in Guruvayur by about 12 noon. It takes more time as you need to get down to Adimali through the ghats.
As regards to Darshan at Guruvayur; temple will be closed in the afternoon and opens only in the evening (I think by 4). So you cant do anything till then. If luck permits and there is no crowd, you should finish it in about 2 hours. This means you start from Guruvayur only in the evening. If this is OK with you, the only route available is Thrissur/Palakkad/CBE/Salem. As Bandipur route to Mysore will be closed for the night.
I am not sure, but others can tell you about the art of driving on NH47/NH7 at night through Palakkad/CBE/Salem/Krishnagiri.
Best I would say is take the day off, stay at Guruvayur for the evening. Once you finish the darshan, you can start very early next day and drive down to Bangalore via Mysore. Its very scenic and nice. This route is well discussed. See the following thread:
http://www.team-bhp.com/forum/route-...-required.html
So to summarize it wont be fun to cover Guruvayur on the way back from Munnar and drive to Bangalore the same day. It will be too tiring. At least I wont recommend it.
Old 9th April 2010, 13:34   #3
Rajesh K R's Avatar
Thanked: 56 Times
Thanks ampere for your quick response. As suggested by you, if i check out of Munnar on day 4 around 1 PM and reach Guruvayoor by 5 pm and plan to stay there, it would be less tiring for me and family.
Thanks ampere for your quick reply. No, i dont intend driving in the night in roads which i am not familiar.
As suggested by you, i can checkout of Munnar on day 4 by 1 PM and reach Guruvayur around 5pm, have darshan and stay there for the night &
plan to leave next morning early.
Yes, i do intend coming via Bandipur and how much time do you reckon will the journey from Guruvayur to BLR ( via Mysore) will take ? and how are the road conditions from Guruvayur to Mysore ?
Old 9th April 2010, 13:52   #4
ranjitp1's Avatar
Thanked: 1,794 Times
or via Coimbatore.
My points:
1.Pls call ahead at Perundurai and ensure room is blocked,why dont you stay the night at Salem itself(am assuming its going to be hotels?)Salem is a better place to stay the night than Perundurai.Not a major difference when you start the next day morning in terms of travel time(better breakfast options also at Salem)
2.Munnar-Blore-gvr,same day is going to be really tiresome.Easiest way to do it would be to spend a night at GVR and start the next day after breakfast.Reason being rush @ GVR temple is just very unpredictable.You could stay the night and visit the nearby temples of Mamiyoor,Venkateshwara,Parthasarathi,the elephant camp etc.
3.Via CBE as well as Mysore,not much difference in both,just that via Mysore,the sights and sounds are varied and would make the drive all the more interesting,but in case you are driving back to Blore in the night or late evening,then take the CBE stretch as roads are safer and straighter.
ranjitp1 is online now   Reply With Quote
Old 9th April 2010, 13:52   #5
aargee's Avatar
Thanked: 2,142 Times
I'd a different thought though, can you not finish of Guruvayoor darshan first & then proceed to Munnar & then back to Bangalore? I mean, no problem with your earlier approach, but I thought its best to take the blessings first & then enjoy the holiday; just a suggestion though.
IMO, driving through NH47/NH7 through Palakkad/CBE/Salem/Krishnagiri is really good. What you may want to do is stay in Guruvayoor & start next day early morning; I'm very sure you'll enjoy the morning drive through ghat section & by the time you come to Coimbatore, it will be time for breakfast, lunch @ salem & back to Bangalore.
Old 9th April 2010, 14:08   #6
ampere's Avatar
Couple of points about Thirchur/Guruvayur
- NH47 almost bypasses Thrichur (others can confirm)
- You will need to take diversion at the right place to get into Trichur and then go through the city to take the Guruvayur road.
Guruvayur to Bangalore is about 400Km. The main route is Kunnankulam, Pattambi, Perinthalmanna, Melatoor, Nilambur, Gudalur, Bandipur, Gundlupet, Nanjangud, Mysore Bangalore.
Old 9th April 2010, 14:22   #7
aargee's Avatar
Right; I didn't have to enter into the city last time.
+1; IMHO, you need to enter into the Thrissur city if you come either ways (from Bangalore or from Munnar) to go to Guruvayoor.
Old 9th April 2010, 14:39   #8
ampere's Avatar
My Garmin + Satguide was of a real help during my drives in these regions and told me exactly where to take these diversions.
Old 9th April 2010, 14:50   #9
ranjitp1's Avatar
Munnar to Guruvayur,I would recco the following route:
Munnar-Aluva-Parur-NH17-Kodungallur-Vatanappilly-Chavakkad-Guruvayur.
Old 9th April 2010, 15:26   #10
Rajesh K R's Avatar
Thanked: 56 Times
Thanks aargee, maybe if i do this way, on the return journey, i can think of leaving Munnar around 7 AM and reach BLR in the evening. Also, my hotel expense of 1 night at Perundurai will not be needed.
You have definitely given my brain something to chew on.
Old 9th April 2010, 15:31   #11
Rajesh K R's Avatar
Thanked: 56 Times
@ ampere : Thanks for the inputs, but i do not have any garmin / satguide, so have to rely on manual / visuals / local assistance only in Thrissur turnoff from NH-47.
@ ranjitp1 : If i halt in Salem, distance to be covered next day ( Salem - Munnar) will be more and we will reach Munnar only late afternoon. Am i right ??
Also, i definitely intend coming via Bandipur, Mysore only.
Old 9th April 2010, 15:33   #12
Thanked: 142 Times
I doubt you would be able to finish your darshan at Guruvayoor in 2 hours especially during summer vacations, not to forget if I am correct Guruvayoor possibly has more number of times when darshan is stopped for various rituals unlike most other temples hence the crowd tends to accumulate more each time the darshan is stopped for some time. If you want to do Guruvayoor on your way back to Bangalore, the best is to plan for a stay overnight as it would make a lot more sense than trying to do Munnar - Guruvayoor - Bangalore in one go not to forget the strain of waiting for Darshan at the temple.
I second Ranjith's point, its better to stay at Salem than Perundurai may be you could start at 6 AM instead of 7 AM to compensate the additional distance which you would have to cover on your way to Munnar but would make a lot more sense. Alternatively you could think of driving all the way upto Erode where you have good hotels to stay for the night.
pypkmsrikanth is offline   Reply With Quote
Old 9th April 2010, 15:36   #13
Rajesh K R's Avatar
Thanked: 56 Times
Ampere has suggested a route thro' Angamali, Kaladi. What is the difference between the above route and the one suggested by you ?
Distance & road conditions pls ?
Old 9th April 2010, 15:39   #14
Rajesh K R's Avatar
Thanked: 56 Times
Now, after going thro' my fellow T-Bhpians reply to my query, i have taken off the thought of making the Munnar - Guruvayur - BLR stretch in one single day and will stay overnight at Guruvayur.
Old 9th April 2010, 15:50   #15
ampere's Avatar
Not sure of the NH17. Only Ranjit or HVK can comment. I have not taken that route. Not sure which one is faster.
BLR-Madurai-Munnar-Thekkady-Coonoor-Ooty-BLR (Advice please) neo45007 Route / Travel Queries 13 4th June 2010 18:56
A quick summary of road trip to Guruvayur Traxter Travelogues 16 18th May 2010 11:27
BLR-GOA-SHIRDI-BLR: Route Info Needed n.devdath Route / Travel Queries 4 5th February 2010 16:24
BLR-HYD-BLR-CHENNAI-BLR - Road conditions report PatchyBoy Travelogues 8 6th July 2008 17:05
