Closed Thread
Old 19th August 2010, 14:33   #166
Souvik's Avatar
So its final. After so much of planning, it is 1 car (Swift) and 3 Idiots who will be leaving from Bangalore on 3rd Sept!
Souvik
Souvik is offline
Old 19th August 2010, 14:34   #167
tsk1979's Avatar
Thanked: 16,420 Times
All the best. Tourism is picking up somewhat, and Nubra valley/Pangong are now accessible to tourists.
tsk1979 is offline
Old 19th August 2010, 14:57   #168
rkbharat's Avatar
Thanked: 613 Times
wonderful, be prepared well
rkbharat is offline
Old 19th August 2010, 15:21   #169
Souvik's Avatar
Thanks Tanveer, Rajiv (and thanks to HVK too). Your inputs have taken me this far and I am going to brave the situation and carry on.
Rajiv: I will meet you in Delhi to pick up the Jerry Cans, catch up on coffee and get some details on Hanle too.
Off topic (with reference to Tanveer's comment): I am adding a couple of days to my trip to contribute my personal time for the relief work. I am also contributing money to Ladakh Autonomous Hill Development Council fund (directly to Office of the Chief Executive Councillor).
Do you think TBHP will support the cause?
Souvik
Souvik is offline
Old 19th August 2010, 17:19   #170
BolBolero's Avatar
Thanked: 271 Times
@Souvik, All the best for the drive! Great news that you will be spending some time for relief work.
About the jerry cans, I just used them on my trip to Himachal in July. Not the best option as Rajiv would also tell you. Would be easier carrying plastic cans, with suitable packing to prevent leakages.
Drive safe.
BolBolero is offline
Old 19th August 2010, 17:38   #171
tsk1979's Avatar
A diesel swift can do manali leh on a single tank.
Even plastic jerrycans leak, esp for petrol cars where the fumes are intolerable. If you plan to carry fuel buy the bislery 20l water can. After drinking all the water, you can use it for fuel. It does not leak at all. Truly good quality.
tsk1979 is offline
Old 19th August 2010, 18:19   #172
Souvik's Avatar
@Gautam: Thanks for the wishes. Your log and the experience faced to cross the Rohtang La was quite an ordeal. I hope you go back again. Will PM you later since I have to ask you some specific questions on some stretches.
Well, for the cans, we are locked on to the Jerry Can from Rajiv for now. We are on Swift Petrol.
Souvik
Souvik is offline
Old 19th August 2010, 18:59   #173
tsk1979's Avatar
Rajiv was in a car with a separate boot. Your hatchback does not have an external boot. So avoid those plastic cans. Using a baloon as a gasket works somewhat, but fumes will nevertheless enter the cabin.
Rohtang is quite an ordeal, esp with HP getting rain.Make sure you cross in daylight.
What is your tentative date of crossing Rohtang?
tsk1979 is offline
Old 19th August 2010, 19:23   #174
Souvik's Avatar
Hi Tanveer,
Yes, agree that I will face the fumes and will have to work out the baloons to seal neck as much as possible.
My tentative date to cross Ro-La would be 7th / 8th Sep.
Souvik
Souvik is offline
Old 19th August 2010, 19:31   #175
Sha
Sha's Avatar
Jerry cans never inside the car, fumes at higher altitude will make you dizzy and irritation.
I am planning from past 1 year how to fix jerry cans in my Gypsy still in planning stage.
Sha is offline
Old 19th August 2010, 19:42   #176
rkbharat's Avatar
Thanked: 613 Times
Sure Souvik, let me know when you reach here.
Drive safe.
Gautam's expereince with those jerry cans was really bad, one his can actually cracked when fell on floor, it was hair thin crack and he realized it when fuel leaked inside.
So careful with them.
oh that can be very very painful, last year we had to drive at Chang-La with open windows as Diesel Leaked from similar cans, in Scorpio. And my eyes all soaked with water
This is turning to be the best solution
WARNING : Never ever use baloon as sealant in case of Petrol. In my case the inner layer of balloon degraded/broke and fell inside the Jerry can . And when I was transferring fuel into car, I saw that piece also going in i n split second. It was a panic situation. In any case carry a cotton cloth(dhotti) piece and tie on the neck of can before transferring, as filter
Instead keep pieces of Cycle Tyre Tube
rkbharat is offline
Old 19th August 2010, 19:51   #177
BolBolero's Avatar
Thanked: 271 Times
Souvik
Will be definitely going back, hopefully next year, if the people of Ladakh recover from the tragedy that has befallen them. (Hoping for a speedy return to normalcy!)
My two bits of advice: Try to reach Rohtang as early as possible in the morning. That way even if you are stuck till afternoon at Rohtang, due to some unforseen circumstances, you will still be able to reach Keylong, if not Jispa, before nightfall. Carry enough food and water at all times. Things become very unpredictable once you cross Mandi.
Old 19th August 2010, 20:24   #178
gonewithwind's Avatar
Hi Sha,
I have done a Ledakh trip from Trivandrum by my Gypsy in july.
I have carried 18 litre pretrol in my 20 litre Jerry Can inside Gypsy, never had any leak or fume problem
gonewithwind is offline
Old 19th August 2010, 20:35   #179
Souvik's Avatar
Rajiv: I guess we will have a hearty discussion on the Jerry Can once we meet in Delhi apart from the Hanle thing I need to ask you about. Good stuff.
Souvik
Souvik is offline
Old 19th August 2010, 20:37   #180
Sha
Sha's Avatar
Originally Posted by gonewithwind View Post
Hi Sha,
You are very lucky, i am trying to take 3 jerry cans either one leaks it will be headache.
Sha is offline
Closed Thread
got leh'd Mumbai-Leh-Mumbai 6100 kms, 4 bikers razorBlades Travelogues 4 13th October 2010 14:29
Delhi - Leh - Delhi, Lay Man to Leh Man on Bikes (29th may - 14th June) SamtheLeo Travelogues 84 21st July 2010 10:50
Drive to Leh Or Fly to Leh deky Route / Travel Queries 27 9th July 2010 22:43
4 Days, to where? - Suggestions Please given2fly Route / Travel Queries 2 12th May 2010 16:50
Paris & Brussels in three days - Suggestions Please ashwinsid Route / Travel Queries 6 8th April 2010 08:13
