Closed Thread
Old 13th May 2010, 19:00   #106
rkbharat's Avatar
Thanked: 613 Times
Originally Posted by pramods View Post
Can I get a Jerry can :-), I tried to find it here at Nagpur and was unsuccessful, the best advice I got was to use the pesticide can, as they are good rugged and air tight, I am not sure if this is a good alternative, the last option that I have is to carry 2-3 plastic vegetable oil container they are generally air tight.
Suggestion and options please for Jerry can or any other alternative.
-Pramod
Hi Pramod, I will share the source detail, you can order minimum of two jerry cans of 20 Ltrs. The only issue is that they do not sell without proper billing and TIN number of the buyer is required. Could be anybody's TIN number for billing purpose. Shipping address can be yours. I used a friends company TIN
In anycase just hold on till I receive mine. I will confirm if the quality is worth for Rs 1100 per jerry can
Here is the supplier
[FONT=Times New Roman][SIZE=2][COLOR=navy][COLOR=navy]Shoaib Khan
Manager Exports
Techno Tools
6-Uptron Estate, Panki, Kanpur(U P) India
Ph: +91 512 2691560
Fax: +91 512 2692221
Email: info@technotools.co.in shoaib@technotools.co.in
Website:www.technotools.co.in
Details of Jerry can I received from Shoaib:
Product Name: Steel Jerry Can
Capacity : 20Ltrs
Dimension : Height=470mm, Length= 340mm, Width=165mm
Thickness : 0.8 mm
Colour : Olive Green
Inner Paint : Petrol Resistant Paint
Outer Paint : Powder Coating with Epoxide Resin
Other : Exhaust Pipe & Security Pin
Packing: 4 Pcs Per Carton
Carton Dim: 475mm x710mm x 330mm
Attached is the picture of jerry can I received from Shoaib
Want to get Leh’d in 2010 for 30 days – Suggestions please-steel-jerry-can-20l.jpg
Part of invoice: I have intentionally removed the TIN and Billing company
rkbharat is offline
Old 13th May 2010, 19:18   #107
urban_legend's Avatar
RKB@ Was myself looking for Jerry cans myself. Shall wait for your feedback on it.
Is it required to bring the jerry cans all the way from UP..! Does anyone know a supplier in Mumbai or Pune?
urban_legend is offline
Old 13th May 2010, 19:30   #108
rkbharat's Avatar
Thanked: 613 Times
They don't have any supplier, basically as I understood after discussion, they auxiliary of LML Scooters and supply on tender basis, mainly to Indian Ordinance. But still try calling Shoaib in the number above, a very helpful guy
rkbharat is offline
Old 13th May 2010, 20:23   #109
Thanks RKB, shall contact Shoaib.
But then eager to get your feedback on the Jerry Cans. Plan to do Leh in August. So got sometime in hand for the purchase.
Old 14th May 2010, 10:08   #110
pramods's Avatar
Thanked: 452 Times
RK, Thanks for the info and I await your feedback, but I know I would not be able to get this before my trip of 29th May this year, but would be a valuable adding to have. So if you find it better and suitable I would go ahead and order, just have to look for the TIN number then!
-Pramod
pramods is offline
Old 14th May 2010, 12:28   #111
rkbharat's Avatar
Thanked: 613 Times
-Pramod
If you really need it I can help you procuring it. And by any chance if you are passing via Gurgaon or Delhi, I can leave it with somebody you can pickup on the way, as I myself will be on the move .
Will update once I get it
rkbharat is offline
Old 14th May 2010, 14:24   #112
pramods's Avatar
Thanked: 452 Times
That would be great, I have to cross Delhi anyway , I most probably will stay at Hodal and then cross Delhi in the morning.
Let me know when you get the Jerry Can and if there is a feasibility to get that on way.
-Pramod
pramods is offline
Old 14th May 2010, 14:24   #113
tsk1979's Avatar
Thanked: 16,422 Times
I use plastic jerrycans(slightly flexible ones). They leak from the cap, but I fixed that with baloons. Cost me 100rs for the 35 liters one. I put 20 liters in each and I am all set.
do we really need to spend 1000s on jerrycans, esp since in a car it will be inside the car and protected from stone impacts and the like?
tsk1979 is offline
Old 14th May 2010, 14:48   #114
pramods's Avatar
Thanked: 452 Times
I have never carried extra fuel till now, Jerry Can are safe bet is what come to mind, because they are made for carrying fuel, but your point is valid too we can use the "Juggad" too and get the task done, give opportunity I would prefer to have Jerry Can over other arrangement else I don't have option just to follow what you do, carry plastic can and make sure to seal them with some "Juggad".
-Pramod
pramods is offline
Old 14th May 2010, 14:50   #115
hvkumar's Avatar
Thanked: 3,365 Times
We carried fuel in plastic cans, put a small plastic wrapper before tightening the cap, no smell.
hvkumar is offline
Old 14th May 2010, 19:55   #116
Not sure, but then heard that plastic cans usually go out of shape in the high altitude and the risk of spill off is there and ofcourse the smell which follows.
How real is the necessity to carry jerry cans along?
Old 14th May 2010, 21:17   #117
hvkumar's Avatar
You need spare fuel in some sections:
Leh-Nubra (there is a fuel pump in Desikit, but may not have stocks sometimes)-Wari la-Pangong-Karu.
Leh-Upshi-Tso Moriri-Pang-Sarchu-Keylong-Tandi
hvkumar is offline
Old 15th May 2010, 12:37   #118
Kumar@ I thought there is a pump in Karu?
Plan to do both Nubra as well as Pangong and Tso Moriri, so guess Jerry cans is a must.
RKB@ might need your help if i'm not able to procure a TIN. But then like i said still 3 more months to get Leh'd..!
Old 15th May 2010, 16:55   #119
hvkumar's Avatar
Petrol pumps:
Srinagar-Leh (from Sonmarg onwards)
- Sonmarg
- Kargil
- Mulbek
- Khaltse
- 9 kms before Leh Airport
Leh
- Leh
- Choglasmar, between Karu & Leh
Nubra V
- Deskit (Nubra V)
Leh-Manali
- Karu
- Tandi (Keylong)
hvkumar is offline
Old 15th May 2010, 16:57   #120
hvkumar's Avatar
The Nubra V pump is a small one, can run out of stock.
The 3 long sectors:
Kargil-Padum (Zanslkar V)-Kargil
Leh-Nubra V-Wari la-Pangon Tso-Karu
Karu-Upshi-Tso Moriri-Pang-Sarchu-Keylong-Tandi
hvkumar is offline
Closed Thread
got leh'd Mumbai-Leh-Mumbai 6100 kms, 4 bikers razorBlades Travelogues 4 13th October 2010 14:29
Delhi - Leh - Delhi, Lay Man to Leh Man on Bikes (29th may - 14th June) SamtheLeo Travelogues 84 21st July 2010 10:50
Drive to Leh Or Fly to Leh deky Route / Travel Queries 27 9th July 2010 22:43
4 Days, to where? - Suggestions Please given2fly Route / Travel Queries 2 12th May 2010 16:50
Paris & Brussels in three days - Suggestions Please ashwinsid Route / Travel Queries 6 8th April 2010 08:13
