Old 17th May 2010, 02:43   #1
Thanked: 60 Times
Default Hubli - Dandeli - Margoa - Cansaulim goa - Londa
Hi
I need to drive from Hubli / Dharwad to Dandeli and then from there to Cansaulim goa. What would be the best route for this travel? I need to drive back to Londa from Cansaulim goa. What would be the options?
TIA
Best regards
Bala
balan is offline   Reply With Quote
Old 17th May 2010, 06:50   #2
ampere's Avatar
Thanked: 9,117 Times
Hubli to Dandeli is is via Dharwad. At Dharwad turn to Haliyal and then onwards to Dandeli.
Now to drive to Cansaulim you can go via Ramnagar. Drive to Ramnagar, where you intersect the NH4A. Drive on NH4A all the way to Goa.
The same road can be taken to come back. Londa is very close to Ramnagar.
Old 5th October 2015, 14:35   #3
srivatsahg's Avatar
Thanked: 136 Times
Exclamation Re: Hubli - Dandeli - Margoa - Cansaulim goa - Londa
Route update:
Took the road to Goa from Dandeli via Ramnagar over the weekend.
Strictly for Off-road enthusiasts(pun intended). Definitely not for cars with low ground clearance. Had a hard time negotiating these craters sitting in my Punto. The roads sadly are in dilapidated state till you reach Goa border. The size of pot-holes(craters) as I would call it are quite dangerous adding to the owes is the amazing driving sense of the oncoming vehicles try to swerve without warning just to negotiate a ditch on their side and come directly in front of you. I could not take pictures as I was way too occupied with the driving. Once you cross the border Goa they roads are as usual pleasure to drive with
srivatsahg is offline   (1) Thanks Reply With Quote
Old 8th November 2015, 01:34   #4
Chewbacca's Avatar
Thanked: 121 Times
Default Re: Hubli - Dandeli - Margoa - Cansaulim goa - Londa
Originally Posted by srivatsahg View Post
Route update:
Strictly for Off-road enthusiasts(pun intended). Definitely not for cars with low ground clearance. with
Which part exactly is bad?
Is it bad between Ganeshgudi and Ramnagar?
Chewbacca is offline   Reply With Quote
Old 9th November 2015, 08:52   #5
srivatsahg's Avatar
Thanked: 136 Times
The Panjim-Belgaum road. Between Ramnagar - Anmod near the Castlerock junction. Not sure if they've repaired it now.
Old 9th November 2015, 11:12   #6
mpksuhas's Avatar
Thanked: 4,130 Times
It was repaired some 1.5 years back, however as per latest posts on Bangalore - Goa thread it has gone bad again. You can check Bangalore - Goa thread for exact details.
mpksuhas is offline   (1) Thanks Reply With Quote
Old 13th November 2015, 08:38   #7
srivatsahg's Avatar
Thanked: 136 Times
Yes, I took this route in the first week of October. The roads definitely are bad.
Belgaum - Londa - Goa road condition sfilinto Route / Travel Queries 53 16th June 2016 07:45
Bangalore-Sirsi-Dandeli-Hubli anup7649 Route / Travel Queries 9 21st July 2014 12:29
Hyderabad -Belgaom-Goa and Goa -Hubli-Rayachur Road Trip dsreddy Travelogues 32 29th July 2013 16:55
Advice on Road Trip : Goa - Dandeli - Chikmagalur KarFan Route / Travel Queries 0 9th December 2009 12:12
The route from Dharwad-Alnawar-londa-goa s.prashanth Route / Travel Queries 3 9th April 2008 14:09
