Old 26th May 2010, 12:31   #1
rockyb's Avatar
Thanked: 11 Times
Default Bangalore - Ganeshgudi - which route should I take?
Option 1 - Stick to NH4 and deviate somewhere after Shiggaon
Option 2 - Tumkur > NH206 and deviate from Talaguppa - Sirsi - Yallapur
Any recent update on road condition of Option 2?
rockyb is offline   Reply With Quote
Old 26th May 2010, 12:39   #2
The Shiggaon route is the preferred route, the last time I went there, the Haliyal-Dandeli route was being re-tarred. To get to Ganeshgudi, you will bypass Dandeli when travelling from Haliyal.
The Sirsi- Yallapur route will be longer though the road's in good condition.
watfor is offline   Reply With Quote
Old 26th May 2010, 14:48   #3
ampere's Avatar
Thanked: 9,108 Times
Easiest route to Ganeshgudi is via Hubli/Haliyal. Yellapur route would be roundabout, unless you want to enjoy the route in rains.
Old 26th May 2010, 17:18   #4
rockyb's Avatar
Thanked: 11 Times
thanks watfor & ampere. I will stick to NH4
Old 26th May 2010, 18:41   #5
ampere's Avatar
@watfor
This is the part I am confused. How can you by-pass Dandeli.
I thought the route should be :
Hubli - Haliyal - Dandeli - Joida - Ganeshgudi
Only when one is coming from Yellapur, he/she can hit Haliyal directly.
Old 28th May 2010, 10:49   #6
@watfor
After Hubli-Dharwad - haliyal there is an intersection; one which takes you towards Dandeli. Another one which goes straight through the forest and to Ganeshgudi. No Joida either.
Old 7th June 2010, 15:13   #7
rockyb's Avatar
Thanked: 11 Times
Default Back form the trip
OK am back from the trip. Thank you all for all the info. I tried both the routes
The onward route I took was Bangalore Nelamangala Tumkur - Chitradurga Ranebennur Haveri - Hubli (all NH4) and now the tricky part. In between Hubli - Dharwad (bypass) you have look for a underpass that goes to Haliyal to your left. But there is no exit to the left. So you have to slow down, look for a bunch of mango trees (with a old security guard) and take sharp right. Go down few hundred meters on the dirt road and hit the underpass road, take right and continue twds Haliyal. Best part is there is no signs whatsoever. I missed it twice. Went all the way upto Londa highway junction and again returned to Kalghatgi highway junction (NH63). The road we took is SH28. >> Haliyal - Ganeshgudi Old Magazine House.
I hope this helps
Total distance was 569 km from point to point. Approx distance was 490 km from Yeswantpur. Did 20 odd km during road hunting. Started late due to puncture. Effectively started from Tumkur at 10:15 am after replacing tube. Reached Old Magazine house at 4:30 pm. 1 BF + 1 Lunch + 1 tea break.
Return Route - Ganeshgudi Yellapur Sirsi Banavasi Sorab - Siralkoppa- Shikarpur Shimoga Tarikere Kadur Arsikere Tumkur Nelamangala Bangalore - Approx distance was till 520 km
Started at 10:30 am - reached Nelamangala at 8:45pm. And another grueling 2:30 hours to reach home. 1 Lunch + 1 tea break.
The return route was very scenic and less traffic but lot of change in directions, no sign boards in English or Hindi and lots of villages I couldn't manitain a consistent speed. Due to this I lost lot of time. Otherwise difference is only of 30 odd km.
So if you want to reach your destination faster - stick to NH4
Old 14th January 2011, 20:56   #8
Default re: Bangalore - Ganeshgudi - which route should I take?
Did this circuit in my car last month.
Trip route map
Ongoing
BLR-haveri-shiggaon-TADAS-KALGHATGI-haliyal-Ganeshgudi
return route
Ganeshgudi-Anshi forest reserve-Karwar-Honnavar-Sagar-Shimoga-BLR
ROAD less travelled-
->TADAS-KALGhatgi: this stretch of road is recommended only if you want to experience some serious motocross/cross country experience.no paved roads greet you here, but the road surface condition isn't that bad, the avg top speed we reached here was 70 kmph.covered this stretch pretty fast.
-> Kalghatgi-Haliyal : road under contruction.very poor surface condition.avg speed was 30 kmph.
-> Ganeshgudi-Anshi-KArwar : road inside the forest reserve(35 kms) is in abysmal condition, surely not seen asphalt for years.its a ENDURANCE track for the motorr vehicles.
If you want to have some fun, use the above 3 routes, else there are better/conventional routes you can take to save time.
ajithnarasimhan is offline   Reply With Quote
Old 14th January 2011, 21:51   #9
ampere's Avatar
Extremely sorry for that slip. Yes Joida-Dandeli-Ganeshgudi form a triangle, whose three sides I have driven many times. Amazingly scenic, but horrible roads!
Trip route map
Ongoing
return route
Karwar-Kadra section has been repaired now, but the roads in the hills still continue to torment every one.
I have heard of the Dandeli-Yellapur route, but never taken that stretch.
Old 16th January 2011, 08:54   #10
hvkumar's Avatar
Thanked: 3,365 Times
So the Ganeshgudi-Sadashivgarh is its usual self, no improvement! ajithnarasimhan, are there any night drive restrictions on this route?
rockyb, the Sirsi-Shimoga route - is it good? Would you recommend that above the longer-Sirsi-Siddapura-Jog-Sagar-Shimoga route which is invariably good?
hvkumar is offline   Reply With Quote
Old 16th January 2011, 09:49   #11
ampere's Avatar
There is no restriction as such, but nature and road conditions itself are a deterrent. No lights or many any villages on the roads. Plus road conditions are usually bad! Initial climb till highest point from Kadra is a bit tight, but later the conditions are more winding (like the Udumalpet-Munnar drive).
PS: I dont remember a forest check post on the route. Also I used to struggle getting one/two KSRTC bus per day to Londa/Belgaum. Leave along any one on the road at night!
Old 16th January 2011, 19:46   #12
hvkumar's Avatar
Are there wildlife - meaning bison or elephant - crossings on the road at night?
Old 16th January 2011, 22:04   #13
ampere's Avatar
Never went on that road in the night! I was a student then ! .
Also never heard folks going on that route at night.
Not sure if its a heavy wild animal territory as there are ghats immediately after Kadra. And again not sure about Dandeli area.
Old 8th March 2011, 16:02   #14
Thanked: 32 Times
April 2nd week I am visiting Dandeli from Karwar via Anshi. From local guy he said he would show road which goes thru villages to avoid bad roads there. Lets see how it works out. I will update on the same. I heard there are chances of bisons/elephant but not frequent!!
Because of some poor political interest roads are never completed and reason given for not completing the road is to avoid illegal forest activities. Lets wait and watch for a year to see beautiful road there too!!
Ravi.
ravibhat is offline   Reply With Quote
Old 8th March 2011, 18:50   #15
ampere's Avatar
Ravi.
Thats the humid season. The road from Karwar to Dandeli was never good!
How to you plan to go to Karwar? There is also a train.
Bangalore to Rajampet - which of the 2 routes should I take? pkumar Route / Travel Queries 9 2nd January 2018 11:35
Mumbai - Karwar : Which route should i take? nvldvr Route / Travel Queries 65 19th December 2016 12:35
Pune-Ganeshgudi/Dandeli trip report choombak Travelogues 0 3rd May 2012 15:40
Bang to Tvm - Which route to take? Jaguar Route / Travel Queries 3 28th June 2006 04:12
