Old 4th August 2014, 23:27   #196
ampere's Avatar
Thanked: 8,067 Times
Default Re: On Bypassing Bangalore
Originally Posted by paharino1 View Post
Coming from Hyd - reaching Devanahalli - What is the best route to get on to Kanakapura Road ? Will be reaching Devanahalli in the 1-3 pm time on a weekday. Is it better to reach Hebbal crossing & then getting on to Kanakapura road ? I am a totally lost inside Bangalore...but have bypassed Blr couple of times via Devanahalli to Nelamangala, & Hosur Road side..
With the elevated road up and running, coming all the way to Hebbal is a breeze. Beyond that you take the Outer Ring towards Tumkur side and get on the NH4 at Yashwantpur. Once on NH4, you exit to NICE road and there on to Kanakpura road.
Route Link
Now the only impediment here is that you can get stuck in that small section from Hebbal to Penya. Where there is a railway over bridge construction in progress.
As against that, you can drive till Doddaballapur- Nelamangala and then drive back to Bangalore on NH4 and then take the NICE road exit.
Route Link
Now this option bypasses the city traffic totally. But then you get to see bad roads around Doddaballapur-Nelamangala section.
Given the option, I would say it would worth the risk to take the Hebbal road. Esp because the elevated road make it a smooth ride all the way till Hebbal. And if you able to go past ORR by early noon that would be good. But be aware that there are trucks in this section waiting to hit the 4-lane NH4. So expect some congestion.
ampere is offline   (1) Thanks Reply With Quote
Old 5th August 2014, 09:32   #197
NPV
NPV's Avatar
Thanked: 4,165 Times
In addition to the options Amp has listed, you can do this as well:
Cross Hebbal-Outer Ring Road junction and proceed straight up to the next junction at Mekhri circle, here take the service road (not the underpass ) so you get on top of the bridge. Make a right turn at the signal, go past IISC and you're at Yashwanthapur, proceed straight on NH4 till you see a left turn for NICE Road and then you can get to Kanakapura Road.
*Only thing is at the IISC junction you will turn to extreme left and then make a U turn onto the underpass on that road to get past the IISC junction but almost all traffic will follow this routine so shouldn't be an issue.
This route is not as difficult as it may sound - I don't intend to confuse you
NPV is offline   (1) Thanks Reply With Quote
Old 5th August 2014, 10:06   #198
ampere's Avatar
I would have suggested what NPV mentioned. But refrained from that as I did not want to confuse you either.
This is what he meant: Route Link
Old 5th August 2014, 11:37   #199
Divya Sharan's Avatar
Thanked: 507 Times
This used to happen in the past. Now, Mekhri to Yeswantpur is a straight line.
Divya Sharan is offline   (3) Thanks Reply With Quote
Old 5th August 2014, 12:08   #200
Thanked: 115 Times
Default Re: Bangalore: Detours to avoid Traffic Lights
Very good thread. Over the years - I have tried all sort of possible routes and none seem to solve my purpose.
When approaching from Hosur to Join the NH7 which is the best possible route to avoid bangalore city.
I have tried:
- NICE Road and exit ( at kanakpura ? ) to ultimately join the airport road.
- Madiwala - Koramangala - palace road - hebbal - yehlanka - devenahalli.
- ORR ( Madiwala - Marathahalli KR Puram - Hebbal ).
to me all seem equally time consuming.
It take about 1.5 hours at the least from Madiwala to reach BIAL.
Is there any way to avoid bangalore at all ?
From Sarjapura to reach chikballapur ?
Padcot Prakash is offline   Reply With Quote
Old 5th August 2014, 15:58   #201
Thanked: 8,834 Times
Exactly! Thanks to the CNR Rao underpass fully functional now, it has ensured to ease a lot out from the typical bottleneck this area faced.
paragsachania is online now   (2) Thanks Reply With Quote
Old 5th August 2014, 16:07   #202
guyfrmblr's Avatar
Thanked: 1,913 Times
It should be also noted that if one takes the elevated expressway in NH-4, there is no exit at NICE road junction. One should get into to the service road as soon as the toll is paid for the expressway.
guyfrmblr is online now   (2) Thanks Reply With Quote
Old 6th August 2014, 06:45   #203
NPV
NPV's Avatar
Does toll need to be paid even if one takes the service road from the place where the elevated road to Peenya begins just after Jalahalli-ORR junction ?
NPV is offline   Reply With Quote
Old 6th August 2014, 07:21   #204
guyfrmblr's Avatar
No need to pay the toll if you don't take the elevated road. But its always better to take the elevated road, pay the toll and then exit to service road to join NICE road since it saves lot of time.
guyfrmblr is online now   Reply With Quote
Old 6th August 2014, 08:26   #205
condor's Avatar
Thanked: 3,478 Times
The NICE road starts after the elevated road ends. Hence no problem there.
So you can take the elevated road. Immediately after the toll, take the exit & move to the service road. The NICE road is soon after this. Not easy to get confused.
You dont need to pay the toll only if you are on the service road all the way. You pay the toll as long as you are on the main section - whether on the elevated section, or right below it.
Considering that the toll is only 20/- one way (30 for the day pass), I would suggest to take the elevated section & cover that distance in 5-7 minutes rather than taking 30-40 min on the service road.
Old 6th August 2014, 08:50   #206
guyfrmblr's Avatar
I was actually referring to the expressway stretch after the toll booth. First time when I had gone there, I descended the elevated road, paid the toll and continued in the expressway only to find out that there is no exit to NICE road.
guyfrmblr is online now   (1) Thanks Reply With Quote
Old 6th August 2014, 09:23   #207
Something that I have been doing at least thrice or four times a month whenever I need to reach E-city faster in peak hour traffic from my Vidyaranyapura home and I couldn't agree more on this.
The exit is soon after the toll and you are hardly gaining momentum that you can very easily miss this exit if you do not watch out for the exit on the left. If you miss this, the only exit is Nelemangala town which is at least 8 kms beyond this point.
Old 8th August 2014, 10:51   #208
NPV
NPV's Avatar
I have tried:
Yes. Some options:
1. From Hosur, take the NH 207 all the way upto Hoskote and go to other side of 207 to reach NH 7 at Devanahalli. This may be a good option in terms of time.
2. When coming into Bangalore from Hosur, just after the toll gate, stay on service lane and go below first flyover and turn right onto Sarjapur road. From sarjapur go via Dommasandra and turn right onto Varthur road, the one with many international schools. It merges at Old Airport Road where you turn right go past Hoodi signal, past Sai baba ashram and reach NH4 old madras road. Turn left and at next junction Budigere cross, go below flyover. This road goes via Mandur and joins NH 207 near Devanahalli and merges with NH 7 little ahead. This may not be a great option in terms of time especially on weekdays and peak hours.
Old 8th August 2014, 15:01   #209
Thanked: 115 Times
Yes. Some options:
This route makes sense when we look at google maps. But how is this road surface and traffic conditions ? Any ones' experience ?
Old 8th August 2014, 16:26   #210
NPV
NPV's Avatar
Road condition is good. Do look at the "On bypassing Bangalore" thread for recent updates. Also maybe the NH 207 thread.
Bypassing Pune on Bangalore-Shirdi route Rajiv-Bang Route / Travel Queries 45 27th March 2017 18:32
Salem to Hyderabad bypassing Bangalore vartakavi Route / Travel Queries 1 2nd February 2010 06:51
Bypassing Bangalore Minardi Route / Travel Queries 5 18th April 2008 20:13
Tips for Central Locking Systems and Bypassing mithun Technical Stuff 1 30th March 2006 11:37
