Old 15th April 2011, 15:26   #61
ranjitp1's Avatar
Thanked: 1,801 Times
Default re: Coimbatore to Calicut
Originally Posted by PRADEEP KUMAR View Post
Sir,
Which of the above is the better route from ooty to calicut.Road conditions and kms.
cheers
Go via Nilambur,roads are in very good condition
Ooty-Gudalur-Nadugani-Vazhikadavu-Nilambur-Manjeri-Kozhikode
Ghat section and real twisties begin as you begin your descent from Nadugani till Vazhikadavu.If you have motion sickness,I'd suggest take something for it.
From Vazhikadavu,traffic is dense and the road narrows down considerably.But overall no problems with the road and the route is pretty scenic as well.I did the Gudalur-Nilambur-Perinthalmana route last week.
ranjitp1 is offline   Reply With Quote
Old 16th April 2011, 10:59   #62
Thanked: 28 Times
What is the distance and how long would it take to reach calicut from ooty in this route?
To reach gudalur which route would you advise from ooty?
tx
PRADEEP KUMAR is offline   Reply With Quote
Old 16th April 2011, 13:41   #63
ranjitp1's Avatar
tx
From Ooty there is only one road that goes to Gudalur and it is well marked.Go past the Taj hotel and double decker petrol pump,you cant miss it,so do not worry about this part.
Ooty to Calicut should roughly take you about 4-5 hours.
Old 22nd April 2013, 09:49   #64
Has anybody been to a place called Devala near Gudalur. I am making a plan to stay in a resort called Amberina there -end of May? Any idea regarding the road condition from Gudalur to devala. Google maps show a deviation near Nadugani (the other branch going to Nilambur)
anupkma is offline   Reply With Quote
Old 22nd April 2013, 10:22   #65
ampere's Avatar
Thanked: 9,128 Times
This is the road to Meppadi. This would lead you further to Nh212 to either Kalpetta or Bathery. The road is narrow, but have heard it to be good.
But you have brilliant views of the tea estates along this road.
ampere is offline   (1) Thanks Reply With Quote
Old 22nd April 2013, 10:43   #66
hvkumar's Avatar
Thanked: 3,366 Times
Excellent road.
Gudalur-Nadugani 11 kms-Devala 5 kms.
At Nadugani, the left road goes to Nilambur, straight continues to Cherambadi/Meppadi/Sultan battery - that is the road to take.
This is a TN village just before the KL border.
hvkumar is offline   (1) Thanks Reply With Quote
Old 27th March 2014, 14:05   #67
RedRapid's Avatar
Thanked: 18 Times
Default route from Coimbatore - Guruvayoor - Calicut
Team,
Long weekend is up and we are scheduled to be in guruvayoor by saturday evening. I have two queries as mentioned in the title -
  • First is on the route from CBE to Guruvayoor which I believe passes through Kudraan (not sure of spelling), and was wondering if the bad roads in this ghat like section has been corrected or if its a better idea to travel via Ottapalam where the last time I traveled the roads are much better ?
  • Second, from Guruvayoor to Calicut I tried google maps and its showing 3 options, option 1 is a direct route (Edapally - Panvel Hwy), option 2 (Thrissur - Kuttipuram Rd & then Edapally - Panvel), Option 3 (Kozhikode-Ferokh-Palakkad Hwy) - Any suggestions on which route is better ?
RedRapid is offline   Reply With Quote
Old 27th March 2014, 14:42   #68
wilful's Avatar
Thanked: 893 Times
Default Re: route from Coimbatore - Guruvayoor - Calicut
1) Cbe/Gvr - the Kudiran route is ok now - meaning that the massive craters have been covered but... owing to the four-laning work many sections get pretty choked with traffic. Depends on the time of day you travel. Evenings esp late evenings can be pretty frustrating. On the other hand if you are taking the Ottapalam/Shornur route, you need not go all the way to Trichur and then turn. You can turn off at Wadakancherry and proceed to Guruvayur via Kunnamkulam.
https://www.google.co.in/maps/dir/IC...9!2d10.6536639
2) From Guruvayur to Calicut, I would suggest you take the option 2 - a bit longer but a better one. Guruvayur-Kunnamkulam-Edappal-Kuttipuram-Valancherry-Kottakkal-Calicut.
wilful is offline   (3) Thanks Reply With Quote
Old 27th March 2014, 16:58   #69
ampere's Avatar
Use the below thread for all Kerala roads.
http://www.team-bhp.com/forum/route-...erala-444.html (All Roads to Kerala)
Bangalore-Guruvayoor :
Bangalore-Salem-CBE Bypass-Pallakkad-Ottapalam-Shoranur-Kunnamkulam-Guruvayur
Second, from Guruvayoor to Calicut I tried google maps and its showing 3 options, option 1 is a direct route (Edapally - Panvel Hwy), option 2 (Thrissur - Kuttipuram Rd & then Edapally - Panvel), Option 3 (Kozhikode-Ferokh-Palakkad Hwy) - Any suggestions on which route is better ?[/list]Thanks
Guruvayoor-Calicut:
Guruvayur-Kunnamkulam-Edappal-Kuttipuram-Kottakal-Calicut
Old 27th March 2014, 17:24   #70
M35
M35's Avatar
Thanked: 1,513 Times
From Shoranur, I usually take the route via Kecheri to Guruvayur.
  • All the way fantastic roads
  • Less traffic, thus more relaxed drive
  • Hit KizhakkeNada, Guruvayur first
M35 is offline   (1) Thanks Reply With Quote
Old 27th March 2014, 17:34   #71
ampere's Avatar
Thats the route I too wanted to suggest too. But I am not sure if the OP would be able to follow that route. Hence suggested the safe option of Kunnamkulam.
Old 11th January 2018, 18:24   #72
Thanked: 120 Times
Infractions: 0/1 (5)
Default Re: Coimbatore to Calicut
Looking for an update on this route suggestions.
I am traveling from Coimbatore to Calicut this weekend.
Any changes in the routes? Road conditions after rains?
Or do the old suggestions in this tread still ok?
I just wanted to check as I am asking in a 4 year old tread. :-)
agbenny is offline   Reply With Quote
Old 12th January 2018, 17:28   #73
mallumowgli's Avatar
Thanked: 760 Times
Road is good. Beyond Palakkad it's two laned. Traffic depends when you are starting. Where in Calicut is your destination? There was a flyover construction at Ramanattukara. Dont know the current status of this
mallumowgli is online now   (2) Thanks Reply With Quote
Old 12th January 2018, 18:08   #74
Thanked: 120 Times
I am starting by 7AM from CBE. I think it will take 5 hrs or even bit more. I like to take pictures, not sure if the road is scenic somewhere on the way.
I am staying at Taj Gateway - PT Usha road. Will it be easy to reach? Thank you.
BTW - is this the route you meant? Palakkad-Mundur-Cherpulassery-Perinthalmanna-Malappuram (bypass)-Kondotty-Ramanattukara-Calicut
Old 12th January 2018, 18:46   #75
mpksuhas's Avatar
Thanked: 4,131 Times
- If possible do consider starting bit early from Coimbatore.
- No particularity scenic locations enroute (Unless you want to stop over at Malampuzha / Anakkal).
- For Taj, proceed on Calicut NH byepass till Thondayad junction and take left from there. There is flyover work ongoing there (seperate flyover to what mallumowgli mentioned above). Also, there is a traffic signal here, so its difficult to miss.
- Once you take left you are on 'Mavoor road' continue on this road all the way till you reach a 'T' junction past private & KSRTC bus stand.
- From this junction you will have to take left (No right turn allowed).
- Some 200 meters from here, you will reach a traffic signal. Take right here and get on the railway over bridge.
- Once you get off the bridge, take right.
Direction
mpksuhas is offline   (2) Thanks Reply With Quote
Calicut - Trivandrum - Calicut Route Updates nairrk Route / Travel Queries 99 19th October 2017 15:13
1st ever Mini meet in Calicut. Post here for all future Calicut mini meets.. MaserQ The Team-BHP Meet Section 17 8th August 2017 04:32
3 bhpians coming to calicut, calicut bhpians want a meet? pramodkumar The Team-BHP Meet Section 9 26th September 2011 21:51
Need some pointers! Calicut - Aluva - Rameshwaram - Madurai - Ramakkalmedu - Calicut Klub Class Route / Travel Queries 8 18th March 2011 12:45
Coimbatore-BLR-Mysore-Calicut-Coimbatore Velmurugan Route / Travel Queries 0 5th September 2010 15:14
