Old 20th September 2009, 17:17   #16
PlaneMad's Avatar
you guys can also use openstreetmap to upload your gpx files and post the link here, like this
it becomes much easier to share and the people in the osm project can also use it to make a free map of the india's roads
Here is the map of Bangalore, fully editable. its got the NICE roads and the BETL
OpenStreetMap
PlaneMad is offline   Reply With Quote
Old 19th October 2009, 09:53   #17
deutscheafrikar's Avatar
Thanked: 324 Times
Originally Posted by PlaneMad View Post
you guys can also use openstreetmap ....
youre absoultely right. This is quite good. Thanks for the link
deutscheafrikar is offline   Reply With Quote
Old 4th December 2009, 20:11   #18
Originally Posted by hrag View Post
And how exactly does one use the posted attachments? Sorry if I'm asking a stupid question.
Depends on your program. Most attachments are in GPX, the GPS exchange format. You can convert these tracks to the format of your device using GPSBabel, a free software.
For example, I have Oziexplorer, so I convert these to plt format using this software
I have a series of queries
I use SatNav - Destinator 7 on a mio 320.
I converted your .gpx to Destinator .dat file using GPSBabel.
My next query is where in the Destinator 7 should I copy the converted file.
And the last query (and the most stupidest) - how should I use the file that I copied.
Sorry if my queries are idiotic, but I am not so tech-savvy.
kingshukt is offline   Reply With Quote
Old 5th December 2009, 14:48   #19
tsk1979's Avatar
Thanked: 16,422 Times
I do not have much experience with destinator 7, but whatever brief experience I have with it, I saw that you could not write tracks of your trips with this software.
However it may be able to read tracks. I suggest you put the track file somewhere on your memory card in destinator folder, and then in the destinator application, look through the menu and see if you have the option of reading track from file
Old 24th January 2010, 15:59   #20
Thanked: 237 Times
Folks,
This thread does not seem to have progressed much. I am interested in pushing this further and share my (limited) expertise here.
Specifically:
1. I want post .GPX files for commonly used routes in Bangalore. Important thing to keep in mind is that one does not need to have a GPS system to generate GPX files.
2. I can explain how to record tracks and share them with others using iPhone (3G and above).
Let me know if you find value in above and I can kick-start the same.
Thanks.
bsdbsd is offline   Reply With Quote
Old 18th May 2010, 19:19   #21
Thanked: 71 Times
Default Bangalore- Munnar / Adimaly GPS track
Bangalore-Krishnagiri-Dharmapuri-Thoppur-Bhavani-Dharapuram-Udumalpettai-Marayoor-Munnar-Adimaly.
440kms- 7.15hrs of driving time.
Nokia Sports Tracker Beta
xotiq is offline   Reply With Quote
Old 12th July 2010, 15:18   #22
ampere's Avatar
Thanked: 9,123 Times
Originally Posted by hvkumar View Post
Cataloguing still going on, promise to upload ASAP. In the meantime, happy to help whichever way I can.
Still the cataloging is on? If you have all your tracks in one GPX, that would be great.
Old 12th July 2010, 15:35   #23
hvkumar's Avatar
Thanked: 3,365 Times
Default GPS Route profile: Ladakh, including Zanskar, Lahaul, Spiti & Kinnaur Valleys
Here is the link to my GE (kmz) file which covers the following route:
Bombay-Udaipur-Jaipur-Delhi-Pathankot-Dyala Chowk-Udhampur-Srinagar-Kargil-Padum-Leh-Hunder-Wari la-Pangong-Mahe-Tso Moriri-Sarchu-Kaza-Sangla-Shimla-Delhi-Udaipur-Bombay
http://hvkumar.googlegroups.com/web/...Mt0t6nY0uV5FIQ
hvkumar is offline   Reply With Quote
Old 12th July 2010, 16:30   #24
hvkumar's Avatar
Default GPS Route profile: North East India, Bhutan, East-West India
Here is the GE (kmz) file for the North East India - Sikkhim, Assam, Arunachal - Bhutan (East to East) and East to West India drive.
Route:
Bombay (MH)-Nagpur-Raipur (CG)-Sambalpur (OR)_Calcutta (WB)-Siuri-Malda-Siliguri-Gangtok (SK)-Changu-Yakshum-Lgship-Dentam-Birpara (WB)-Phuntsoling (BT)-Thimphu-Paro-Punaka-Jakar-Trashigang-Samdrup Jhonkar-Guwahati (AS)-Itanagar (AR)-Ziro-Daporigo-Along-Pasighat-Dibruhargh (AS)-Kibithu (AR)-Dibrugarh-Guwahati-Cooch behar (WB)-Falkata-Purnea (BR)-Begusarai-Muzaffarpur-Gorakhpur (UP)-Lucknow-Kanpur-Jhansi-Shivpuri (MP)-Kota (RJ)-Udaipur-Palanpur (GJ)-Bhuj-Koteshwar-Ahmedabad-Bombay (MH)
http://groups.google.com/group/hvkum...Apr%202009.kmz
Old 12th July 2010, 18:35   #25
ampere's Avatar
Thanks HVK. Let me import to Mapsource and check it out.
Old 19th July 2010, 17:52   #26
ampere's Avatar
HVK, I loaded them into Garmin. Pretty heavy, Mapsource chokes!
Because each point, the converter treats as a Way point tries to expand the name.
Also how come, you have files in a Google format? You should be having a GPX right?
As the tracklog should have been directly dumped from the GPS device.
Old 19th July 2010, 17:59   #27
hvkumar's Avatar
Also how come, you have files in a Google format? You should be having a GPX right? As the tracklog should have been directly dumped from the GPS device.
I download the data from my Garmin GPS onto both MapSource (gdb format) and Google Earth (kmz format), edit waypoint info in MapSource, then copy the same info in kmz. Never deal with gpx format.
Old 19th July 2010, 18:35   #28
ampere's Avatar
If you have the GDB, thats even better! Can I get a hand on that (NE and LEH) .
The reason was, conversion, may miss something or add extra details.
Since I use Mapsource, it would be a direct input.
Old 27th August 2010, 15:32   #29
ranjitp1's Avatar
Thanked: 1,801 Times
Default Hyderabad-Mumbai Aug 2010
Trip log of Hyd-Solapur-Pune-Mumbai attached as on Aug 2010.
ranjitp1 is offline   Reply With Quote
Old 1st September 2010, 20:30   #30
Thanked: 9 Times
gps log of Marayoor-kandalur-Kundala Dam- Top Station- Vattavada.
i.1979 is offline   Reply With Quote
Data Bank Of Tracks Across India (Go karting tracks included) dustDevil Indian Motorsport 70 10th April 2017 19:31
Convert Google Maps driving directions to GPS tracks vu2pmc Gadgets, Computers & Software 5 25th September 2011 11:39
Full HD Videologue with GPS Logs of 2300+ Kms in 6 Days of Tamil Nadu & Pondy Tour TrueDreamer Travelogues 13 26th November 2010 09:11
Service Report - Green Tracks / Javali Motors, Bangalore - for Fiat Palio finneyp Indian Car Dealerships 26 20th September 2010 11:57
