Old 20th October 2015, 11:09   #121
Thanked: 81 Times
Default Re: Bangalore - Kumbakonam - Thanjavur - Trichy - Madurai - Namakkal - Bangalore
Originally Posted by mohan41 View Post
Any good restaurants on Salem-Namakkal-Trichy route preferrably off the highway without going too much inside the towns?
There is a A2B at Namakkal, if that suits you. Google maps location. Please note the location on the map is not accurate. This place is on the main road itself.
If you are taking the Karur route, then you have coastal Residency on the Namakkal bypass. Really good food. Recommended.
Landkruzer is offline   (1) Thanks Reply With Quote
Old 29th August 2016, 16:08   #122
Thanked: 33 Times
Folks,
Can anyone help me with the best route to take from Mysore to Tanjavur? I will be starting early on day 1, plan to reach Tanjavur by night. Will stay in Tanjavur overnight, get done with temple visits in the morning and immediately head back to Mysore on day 2.
I'm well aware of the Mysore-Coimbatore highway, and I believe the route will be the same till Sathyamangalam. What route should I take from Sathy to Tanjavur? Would prefer a good comfortable drive, even if it is slightly longer. Please advise
Thanks a lot,
Kaushik
kaushik60 is offline   Reply With Quote
Old 29th August 2016, 16:15   #123
ampere's Avatar
Thanked: 7,660 Times
Mysore-Chamarajanagar-Dimbam-Sathy-Annur-Avinashi-Mangalam-Palladam-Kangeyam-Karur-Trichy-Tanjore.
That I think should be a good option.
ampere is offline   (1) Thanks Reply With Quote
Old 29th August 2016, 16:51   #124
Thanked: 33 Times
Thanks! Will take this route. Also what would be an approximate drive time for the Sathy-Tanjore leg? If I set off from Mysore at 6, I should be reaching Sathy around 10 or so. By when can I hope to reach Tanjore? Any particular streches of bad roads/ traffic I must be aware of?
Many thanks
Old 29th August 2016, 17:25   #125
ampere's Avatar
I think another 6 hours easily. Given its a 2-lane traffic most of the time, you should account for lower average speeds.
Old 29th August 2016, 21:15   #126
Thanked: 476 Times
Personally makes no sense to go via Avinashi. I would suggest one of the following choices from Sathy:
1. Sathy-Gobi-Bhavani-Erode-Kodumudi-Karur-Musiri-Number 1 tollgate-Trichy bypass-Thanjavur - Am not sure how to bypass Erode here. Pretty sure it needn't be touched get on to Kodumudi.
2. Sathy - Gobi- Bhavani-Salem bypass-Namakkal-Musiri/Thuraiyur-Number 1 tollgate-Trichy bypass-Thanjavur.
Given the 4-lane availability, I'd suggest the 2nd option. Drive time should still be above 5 hours from Sathy.
There are shortcuts from Bhavani to Namakkal via Tiruchengode which is the bus route for Trichy-Erode buses. But not sure about the current conditions.
narayans80 is offline   (1) Thanks Reply With Quote
Old 29th August 2016, 22:42   #127
ampere's Avatar
A variation of this is the default Google option, which does make sense. But the reason I wont suggest is not about the amount cross roads, the OP may have to wade through. Hence suggested simplest of all.
Salem does not make sense to me because beside 4-lane I am not sure if we can gain time. Plus time lost in crossing the city. Salem-Namakkal traffic not to talk about and crossing Namakkal town.
This can be tried.
My ideal route would be Sathy-Gobi-Chengapalli-Kangeyam-Karur-Trichy-Tanjore.
Except for Trichy every town is bypassed. If OP can trace this through nothing like it.
Old 29th August 2016, 23:13   #128
Grand Drive's Avatar
Thanked: 266 Times
My suggestions are as follows:
Option 1: Sathy - Gobi - Erode - Karur - Trichy - Thanjavur.
Option 2: Sathy - Perundurai - Erode - Karur - Trichy - Thanjavur.
Option 3: Sathy - Kangeyam ( via Uthukuli) - Karur - Musiri - Trichy - Thanjavur.
Option 4: Sathy - Gobi - Erode - Thiruchengode - Namakkal - Musiri - Trichy - Thanjavur.
Travel time depends on the lorry traffic between Karur - Trichy / Namakkal - Trichy.
Grand Drive is online now   Reply With Quote
Old 30th August 2016, 13:01   #129
Thanked: 476 Times
Trichy is the easiest to bypass. If coming from Namakkal, its either of the 2 options:
1. Namakkal-Thottiyam-Musiri-Number 1 Tollgate
2. Namakkal-Thuraiyur-Nochiyam-Number 1 Tollgate
At Number 1 Tollgate, if you take a right it takes you across Kollidam bridge (a narrow bridge across Kaveri which is now open only to light vehicles, all buses and lorries take the left i mention below) to Thiruvanaikoil/Srirangam et al. You should take a left at the Number 1 Tollgate, in half a km you'll meet the Trichy NH45 bypass. Take a right here that's all. You should breeze till Thanjavur exit which is about 15 km away.
narayans80 is offline   Reply With Quote
Old 30th August 2016, 13:06   #130
Thanked: 260 Times
At Number 1 Tollgate, if you take a right it takes you across Kollidam bridge (a narrow bridge across Kaveri which is now open only to light vehicles, all buses and lorries take the left i mention below) to Thiruvanaikoil/Srirangam et al..
New bridge over Kollidam is open so no issues.
gajadonga is online now   (1) Thanks Reply With Quote
Old 30th August 2016, 13:35   #131
Thanked: 476 Times
Thanks. A year back, they were in the early stages of the bridge work at the Number 1 Tollgate end.
To reach Thanjavur though, it makes sense to catch the bypass at Number 1 tollgate itself.
Old 30th August 2016, 14:46   #132
ampere's Avatar
This road is always crowded around Srirangam/Thiruvanaikoil. That was point. Especially if you are coming from NH67 (Musiri) its a pain. If coming via Thiraiyur, you get wade through to get to the toll gate. With the amount of turns its not easy with open-up a GPS.
With the new bridge that is also resolved.
Old 30th August 2016, 15:52   #133
Thanked: 476 Times
The reason of going via Musiri is to avoid the Thiruvanaikoil traffic. If you are coming from NH67, you have to take the bridge across Kaveri at Kulithalai to get to Musiri and then the SH25 till Number 1 Tollgate. Taking the NH67 all the way will land you at Chathiram bus stand, wading through this mess will take a lot more time and effort than coming via Musiri. If you are doing it in daytime, Musiri route isn't that bad, the death-wish Namakkal Salem buses of 80s and 90s have largely mellowed down when I compare them to how I've seen them since 2010.
The lack of signages inside Trichy city don't make it easy either. I've gotten lost twice taking the wrong turn and circling Trichy city.
If you catch the bypass at Number 1 tollgate, you won't see any of Trichy traffic at all, except the minimal traffic on the Trichy bypass.
I havent been through Thuraiyur so can't comment, have been through Musiri thrice a year over 30 years.
As such new Kollidam bridge doesnt change anything much for the route am suggesting, the mess actually starts as you get closer to Thiruvanaikoil. If anything, it should've made things worser as heavy vehicles (all Lalgudi, SH25, Samayapuram bound buses and lorries) will now take the new Kollidam bridge rather than diverting to the bypass as they used to do in the interim.
I've crossed Salem and done Salem-Namakkal, was rather greeted with near empty roads on Salem-Namakkal. Salem bypass I agree, but speeds are on par with what you would do on a 2-laner on the bypass section. Bhavani-Salem-Namakkal is around 110 km, which can be done in 90-100 min. Another 90 min for Namakkal-Number 1 Tollgate, 20-30 min to get to Thanjavur exit,45-60 min to reach Thajavur. Sathy-Bhavani is another 60-75 min.
Old 30th August 2016, 16:12   #134
ampere's Avatar
I agree. Even I have been through this quite easily. But only issue is if some one does not these locations, he needs to have navigation in handy.
Wow! Thats long. I have been through Thuraiyur. Amazing roads, but again, navigations needs to be in handy. Thats why I was not suggesting earlier.
I am not denying it all. Just the basic school /college buses apart from the need to get into Namakkal town along with Salem bypass traffic. Hence my point on going via Karur/NH67.
Bangalore to Trichy, Thanjavur, Velankanni, Kumbakonam, Chidambaram & Rameswaram in a week for_cars1 Travelogues 3 15th May 2015 15:41
Driven: Bangalore - Trichy - Tanjore - Kumbakonam - Velankanni - Chidambaram pramodpk Travelogues 5 19th September 2014 12:20
Bangalore, Namakkal, Madurai, Rameswaram, Kanyakumari, Trivandrum & Srivilliputhur daisyb Travelogues 5 28th December 2012 09:57
Did this last weekend - Chennai-Trichy-Dindigul-Kodaikanal-Madurai-Trichy-Chennai srikanthpotluri Route / Travel Queries 2 2nd November 2011 02:20
Need route/lodging/restaurant info for trip to Kumbakonam/Thanjavur/Trichy & nearby sathya_nars Route / Travel Queries 12 24th June 2009 09:52
