Old 1st October 2015, 09:39   #6301
Added_flavor's Avatar
Thanked: 845 Times
Default Re: The art of travelling between Bangalore - Mangalore/Udupi
Originally Posted by speed_edge View Post
Guys,
Any good morning breakfast option on mangalore road after Nelmangala with clean toilets. Travelling tomorrow morning in a group and expecting to be at nelmangala around 7:30AM.
SE
1. Swathi Delicacy - Just after you cross Kunigal on the right side.
2. Mayura - A little ahead in Yediyur on the left side.
3. Vasudev Adigas - further ahead on the right.
My personal favourite is Swathi Delicacy.
Added_flavor is offline   (1) Thanks Reply With Quote
Old 1st October 2015, 10:46   #6302
Thanked: 16 Times
Thanks Bro! This for sure will help. Also any review about YATHRIK RESTAURANTS, just after turning left from nelmangala?
speed_edge is offline   Reply With Quote
Old 1st October 2015, 10:55   #6303
addyhemmige's Avatar
Thanked: 465 Times
Just a small correction.
1. Swathi Delicacy
2. Hotel Mayur - Just before Yediyur (on the right side)
3. Adigas Grand - Between Swathi and Mayur on the right side (not related to the Adigas hotels in Bangalore)
4. Golden Breeze and Shark Food Court - These are before Kunigal. Shark Food Court is quite popular with travelers here.
Originally Posted by hangover View Post
You could try another route. From Channarayapatna go towards Shravanabelagola. Continue on state highway to Huliyurdurga. Then Magadi and then BLR town.
I found it very scenic. Traffic is less till Sunkadakatte. Beyond that it's your normal jam packed traffic.
You would need a good map if you've never been on that route. It's got a few turns you may need help on. When I last travelled that way 2 years ago, the roads were in decent condition.
This route was quite bad between Nagamangala and Huliyurdurga. The other stretches are good to decent. I last took this route sometime in May/June (IIRC). Although the whole route is almost devoid of traffic, the bad roads will test your patience. One or two stretches (Shimsha bridge to Devalapura) was being re-laid, so this might be done by now. No idea about the latest conditions on the remaining stretches.
Last edited by addyhemmige : 1st October 2015 at 11:05. Reason: Quoted another comment
addyhemmige is offline   Reply With Quote
Old 1st October 2015, 10:59   #6304
Thanked: 845 Times
Err no. I am talking about Mayura on the left side while going towards Mangalore.
EDIT: Just before Bellur cross to be even more precise.
Added_flavor is offline   Reply With Quote
Old 1st October 2015, 11:09   #6305
Thanked: 465 Times
Yes indeed, that is correct. You mentioned Yediyur, so I assumed you were referring to the Mayura (now called Mayur) at Yediyur
Old 2nd October 2015, 17:18   #6306
cool_dube's Avatar
Thanked: 397 Times
Default Bangalore - Kundapura
Hi folks,
I am driving down from Bangalore to Kundapura next month and wanted to confirm that the following route (which is my all-time favourite) contiues to be the optimal one:
Bangalore - Hassan - Belur - Chikkamagalur - Aldur - Balehonnur - Jayapura - Sringeri - Agumbe - Haladi - Ampar
Another query - is there any option other than via Chikkamagalur to reach Aldur from Belur? The one via Mudigere might be too much of a detour. Inputs needed.
Thanks in advance...
cool_dube is offline   Reply With Quote
Old 2nd October 2015, 18:07   #6307
Samurai's Avatar
Thanked: 15,684 Times
Default Re: Bangalore - Kundapura
Do you know the state of this road? Last time I did it, it was horrible between aldur and balehonnur.
You are better off taking ampere's route.
Samurai is offline   (1) Thanks Reply With Quote
Old 3rd October 2015, 17:16   #6308
cool_dube's Avatar
Thanked: 397 Times
Do you know the state of this road? Last time I did it, it was horrible between aldur and balehonnur. You are better off taking ampere's route
Thanks Samurai. As per this route, I need not go all the way up to Shivamogga. If so, how would be the road conditions b/w Bhadravati and Madagadde (where I join NH13)?
Old 4th October 2015, 15:26   #6309
Thanked: 38 Times
Question Re: The art of travelling between Bangalore - Mangalore/Udupi
I am headed to Madikeri, starting from my home near Hebbal, next week. Is the Chanrayapatna-Holenarsipura-Arakalagud-Somwarpet-Madikeri route still in good condition? I took it during summer this year and was smooth all the way.
nma83 is offline   Reply With Quote
Old 4th October 2015, 16:12   #6310
NPV
NPV's Avatar
Thanked: 5,241 Times
Haven't heard about any bad stretches on this route recently. Should be fine. Try the CR Patna-Agrahara-Holenarasipura, scenic with some windmills around, see the Bekal, Kabini thread for details.
NPV is offline   (1) Thanks Reply With Quote
Old 4th October 2015, 16:19   #6311
Samurai's Avatar
It is fine, and no traffic either. Ampere's route has no bad stretch at all.
Old 5th October 2015, 15:57   #6312
AmazeGuru's Avatar
Thanked: 209 Times
Hi Folks,
I will be travelling to Mangalore on either 23rd/24th Oct from Davanagere. Driving from BLR to DVG on 23rd and from there to MLR on 24th.
I plan to take one of the below routes:
1. Davanagere-Shimoga-NR Pura-Koppa-Sringeri-Karkala-Padubidri-MLR
2. Davanagere-Shimoga-Thirthahalli-Koppa-Sringeri-Karkala-Mudubidri-MLR
3. Davanagere-Shimoga-Thirthahalli-Agumbe-Udupi-MLR
Can someone suggest which is the better route in terms of road condition? I will be driving my Amaze and it has tendency of bottoming out even on not-so-bad roads. Time is not a constraint, and I intend to break for lunch at Sringeri, which seems to be the logical mid-point of the journey.
AmazeGuru is online now   Reply With Quote
Old 6th October 2015, 13:20   #6313
Klub Class's Avatar
Thanked: 1,213 Times
AmazeGuru, sharing few points :
Please don't take Davangere - Harihar - Honnalli - Shimoga route. The Honalli - Shimoga stretch is in bad shape and makes the progress slow (Davangere - Harihar PB Road has potholes and broken patches, but you can avoid it by taking NH4)
a) You can take the Hadadi Road Exit and do Davangere - Hadadi - Sulekere (Shanthi Sagara) - Nallur - Channagiri - Shimoga (good two lane scenic roads with less traffic). Though the distance is 10+ kilometres more compared to the other one, you can save time
- There's a beautiful view point of Shanthi Sagara (Sulekere - Asia's second largest irrigation tank) at 14.13071, 75.8853491. If you're not in a hurry, spend some 5 mins there
i) Shanthi Sagara - Channagiri road
The art of travelling between Bangalore - Mangalore/Udupi-11045340_10206165141431400_3560672391173773751_n.jpg
ii) Shanti Sagara - Channagiri road
The art of travelling between Bangalore - Mangalore/Udupi-10352616_10206165143231445_1611129118446514084_n.jpg
iii) Shanti Sagara view point
The art of travelling between Bangalore - Mangalore/Udupi-11041806_10206165139031340_1240905858544506695_n.jpg
iv) Views of Shanti Sagara
The art of travelling between Bangalore - Mangalore/Udupi-11037321_10206165139591354_5027801409222686991_n.jpg
The art of travelling between Bangalore - Mangalore/Udupi-11041802_10206165140871386_8376841639476534769_n.jpg
b) Shimoga - Thirthahalli - Agumbe - Someshwara
- Shimoga - Thirthahalli is in excellent condition
- Thirthahalli - Agumbe - excellent surface (but do watch out for two unmarked rumble strips - they resemble rough patches filed with granite pieces - after the deviation to Kundadri - roughly 8 km before Agumbe)
c) Agumbe - Someshwara
- First half is concreted and has broken patches
- Second half is tarred - seems recently resurfaced and is a bliss to drive
And while you're in Davangere, have the yummy Davangere Benne Dosa from Old Sagar Benne Dosa Hotel (or Sri Guru Kottureshwara Benne Dosa Hotel - easy to locate and park your vehicle)
Klub Class is online now   (2) Thanks Reply With Quote
Old 6th October 2015, 15:26   #6314
AmazeGuru's Avatar
Thanked: 209 Times
@Klub_Class, thanks for the suggestions. I will make sure to take the Channagiri - Shimoga route and avoid Honnali.
I do plan to visit Sringeri (break for lunch perhaps) via Thirthahalli - Koppa. Any idea about Sringeri to Mangalore route?
There were couple of routes that Google Map threw up:
1. Sringeri-Karkala-Padubidri-MLR
2. Sringeri-Karkala-Moodbidri-MLR
Any recommendations on the above routes to reach MLR?
Old 7th October 2015, 11:24   #6315
AmazeGuru's Avatar
Thanked: 209 Times
Default Bangalore-Davanagere-Mangalore-Goa: Road Condition
Hi Folks,
I have planned a long road trip (long by my standard) during the end of this month and here is the itinerary.
Day 1: Bangalore - Davanagere via NH4 (I believe it is 4/6 lane throughout)
Day 2: Davanagere - Mangalore - Plan to take Channagiri-Shimoga-Thirthahalli-Sringeri-Karkala-Moodabidri-MLR route. Need help from experts on the road condition.
Day 3: Mangalore sight-seeing
Day 4: Mangalore - Udupi and stay in Udupi. (Visit the temple and St Mary island)
Day 5: Udupi - Goa: stops at Maravanthe-Murdeshwara-Gokarna. Destination is Colva beach
Day 6&7: Goa sight-seeing
Day 8: Leave Goa and head to Bangalore via NH4A and SH34 and join NH4 @ Dharwad (Borim-Mallem-Gharli-Honnapur-Dharwad)
I will need help on the road condition on the above route - especially the NH17 from MLR to GOA and also from GOA - Dharwad. I will be driving my Amaze (with family) and do not want to get into bad roads in a low-GC car.
Thanks,
Guru
New Year Drive: Bangalore to Mangalore & Udupi nandita_bayan21 Travelogues 11 21st January 2016 12:27
On TVS apache: Pune-Chennai-Pondy-Bangalore-Mangalore-Udupi-Ankola-Belgaum-Pune CoNrOd Travelogues 12 26th May 2014 16:04
Road conditions between Bangalore and Udupi rdna Route / Travel Queries 1 11th December 2011 00:55
Mumbai-Mangalore-Bangalore-Mangalore-Mumbai trip sumitdongerkery Travelogues 4 17th October 2006 14:28
