Old 26th October 2010, 14:06   #1
Default Route Advice: Delhi - Naukuchiatal
Need advice regarding route and road conditions for Delhi Naukuchiatal Delhi trip.
Planned dates are start on 31st October - noon / afternoon, if possible / required break for night at someplace en-route. Start on 1st morning to reach Naukuchiatal. Return is planned for 5th November, would like to reach back by early evening.
Need suggestion regarding
1. The best route in terms of road / traffic conditions.
2. Suggestions for a place to make a night halt.
3. For the outward trip suggestions for a scenic route can be considered as time will not be a constarint.
4. For the return journey the shortest route (time wise) would be preferred.
Look forward to all the suggestions.
Bharat
ZeroThoughts is offline   Reply With Quote
Old 26th October 2010, 15:36   #2
Thanked: 116 Times
Dear Bharat,
Naukuchiatal isn't very far away, and there are hardly ant good places en-route. I suggest that you do directly there; it is hardly 250 KMs (6 hrs) from Delhi.
There are two routes Delhi-Ghaziabad-Hapur-Muradabad-Rampur-Rudrapur-Haldwani-Kathgodam-Ranibagh(2 KMs from Kathgodam)-Bhimtal-Naukuchiatal and Delhi-Ghaziabad-Hapur-Muradabad-Bazpur-Kaladhungi-Haldwani-Kathgodam-Ranibagh(2 KMs from Kathgodam)-Bhimtal-Naukuchiatal.
As far as I know, both these routes are in a pretty bad shape nowadays. Though the Bazpur-Kaladhungi one will be a little better.
In my opinion, there is not much to do in Naukuchiatal for 3-4 days. Plan some excursions to near-by area liek Nainital/Mukteshwar etc.
Nitin
ntomer is online now   Reply With Quote
Old 27th October 2010, 15:03   #3
Thanks Nitin.
I am familiar with the routes, just wanted to know if there are any ineteresting places as offshoots available enroute.
Also I am keen to know the road condition after the monsoon.
I had last been up to Rudrapur in February, and it had taken us nearly 7 hours with a 45 minitute break in an Innova. Road condition and a couple of traffic jams being the main culprit.
As we can not start early on Sunday, we will hit Prime Sunday Traffic all through the way and hence the enquiry regarding break journey and the road conditions.
Bharat
Old 27th October 2010, 15:06   #4
suman's Avatar
Thanked: 257 Times
AFAIK, the roads are in a mess. You can PM Trance_Nut, he was up at Kausani recently. IIRC, he mentioned some bridge having been washed away near Kathgodam so he had to do a river crossing in his Safari
Old 27th October 2010, 15:13   #5
Thanked: 90 Times
Nitin
>>> Both roads are likely to be in optimal condition around mid November, in time for the busy touristy traffic in Dec-Jan. With the current road conditions as they are (bad surfaces), it might take you nearer seven hours to reach Naukuchiatal.
Naukuchiatal is ideal if you want to immerse yourself in nature; it is a bird lover's paradise. Otherwise four days will hang heavy for 'normal' tourism.
Regards, drive safe
issigonis is offline   Reply With Quote
Old 27th October 2010, 16:27   #6
Thanks for the suggestion, will definitely check out with him.
Have planned a nice drive. No swimming planned, neither for the car nor self!
Regards, drive safe
So, not only will I be facing bad roads but added to it will be half closure of lanes for re-carpeting for the "Tourist Season"! I seem to be going at the most inapropriate time.
We both are nature lovers and I plan to try my skills at some Bird Photography. Hence the idea to spend some time there, and possible trips to Sattal, which is again a good place for Bird Watching, I am told.
Old 17th September 2013, 09:02   #7
predatorwheelz's Avatar
Thanked: 1,112 Times
Default Re: Route Advice: Delhi - Naukuchiatal
Bumping up an old thread. I plan to travel to Naukuchiatal in November (23-25 to be precise). Would need pointers on:
1. Current road condition.
2. Things to do and places to see
3. I presume it will be quite cold, so recommended clothing.
predatorwheelz is offline   Reply With Quote
Naukuchiatal: Far from the crowd shashanka Travelogues 49 10th May 2017 13:20
Planning long holiday, Delhi-Leh-Delhi, Delhi-Gangotri-Delhi by road arunforu1 Route / Travel Queries 19 22nd August 2009 02:25
Delhi-Manali - on 14,15,16. Advice Required - Route from Ambala,Climate v&v Route / Travel Queries 6 10th August 2009 19:55
Jim Corbett & Naukuchiatal Country Road Travelogues 21 22nd August 2008 16:15
Dharamshala/McLeodGanj - Delhi route advice tsk1979 Route / Travel Queries 2 26th December 2007 18:06
