Old 22nd November 2016, 13:40   #61
paragsachania's Avatar
Thanked: 10,942 Times
Default Re: Bangalore - Pune - Ahmedabad : Route Queries
Originally Posted by mpksuhas View Post
[*]With a 04:00 AM start from Bangalore and quick (~30 mins) food breaks, is it possible to reach Vapi in 15 hours?
Yes, possible even without really speeding and maintaining healthy 100-110 KMPH all throughout.
I say this as I have done it multiple times starting at 0400 from Bangalore.
I have a few tips here:
  • Stop early for breakfast - Well, it will be almost 0730 when you are near Ranebennur Kamat with a start as early as 0400
  • Stop for lunch, after Kolhapur and near Karad - This will be around 1300-1330 Hours when you are here - It is always good to cross Kolhapur-Islampur and then stop for lunch. With this, dont aim at Nippiani-Kolhapur for lunch (no not even Sai International) and target Vittal Kamat near Karad
  • With this you will cross Pune by 1500-1530ish and then at Panvel (Mumbai Entry) by 1700
  • Hence, Do not plan to tank up or break anywhere between Pune and Mumbai, cross Mumbai completely and plan a break at Ghodbunder from where you simply get onto NH* for Ahmedabad - This works beautifully as you cross Pune and Mumbai before peak hours and save a lot of time
  • After Ghodbunder, you are free to stop anywhere any number of times and it won't really matter much. However, a quick stop at Ghodbunder at Fountain Inn or Express Inn (well managed place) would make sense so that you can then stop only for refuel near Manor (If needed) and finally Vapi
[*] Any suggested bunks around Nippani on left side while headed North? I am aware of a BP bunk which is on right side of the road. Link
Stick to that, It is not at all a time consumer even when its on he right side. You may lose not more than 5 minutes.
[*] For byepassing Mumbai I am thinking of taking the suggested route
Stick to this route, the fastest and reliable and mostly clean from bad traffic and now roads have been patched up too.
However, any specific reason for avoiding NH 48 till Thane in this section?
Have taken this and the progress will be really slow. This is mainly because this route remains favorite for trucks from the port heading north as they don't have to drive through Vashi-Mumbai. Secondly, the traffic density comprises of mostly trucks and multi axle trailers - Something that you would not be happy to drive (Rather crawl) along in few sections where you have inclines.
Adding to this, as you close in near Thane, traffic build up too and further slows you down from NH48 side.
Lastly - Road conditions are not at all great on this that it remains the last choice to bypass Mumbai.
[*] With a 05:00 AM start from Vapi towards Ahmedabad, based on usual trend is it advisable to take Golden bridge (Considering that the new bridge is not open still)
Quite easily - In fact, I would say take the usual route itself than the Golden Bridge. Your decision should be strictly based on the traffic shown on Googlemaps. Plot route between the 2 points and see what is suggested as fastest - It really works and I have always relied on that.
[*] Is 6 hours descent timeline for Vapi - Ahmedabad town?
More than just good. Regular drivers do Ghodbunder - Expressway end in 7 hours, so 6 hours for just Vapi and Ahmedabad town including crossing Ankleshwar-Bharuch will be easily possible.
Bottom line: Make sure you start no later than 0400 and strategically plan breaks to avoid spending time crossing Pune and Mumbai. It has worked for me with parents, with kids and with relatives by setting the right expectations and am sure it should not be a task for you anyway. So speed is not the key here and I don't need to re-iterate that. It is mostly going to be a good start (0400) and proper planning with breaks.
paragsachania is offline   (3) Thanks Reply With Quote
Old 24th November 2016, 14:10   #62
Thanked: 455 Times
Few query on Bangalore - Vapi - Ahmedabad route.
[*] Also, heard there is some road closure near Vasai Creek. Any updates on that?
Apparently, the closed North bound Versova bridge ( Vasai creek ) is now open for light vehicles but it seems, a limited number of vehicles are allowed to pass at one time, that too with a very slow speed. This causes traffic backlogs. In peak hours, add about 25-30 mins extra to your total estimated travel time. Since you are planning to start from Bangalore by 0400 hours, it's likely that you would enter Bombay by 6 PM and touch Versova bridge at around 7.45pm. This is a peak hour, so be prepared to face some quite heavy traffic.
I don't intend to make you anxious, but just thought of sharing this update which I too learnt just yesterday from a friend.
vivek95 is offline   (1) Thanks Reply With Quote
Old 24th November 2016, 14:36   #63
Vivek, twice when I did Bangalore - Ahmedabad, I was almost precise with the timings with my usual speeds when I started from Bangalore at 0430AM.
-- My breakfast was at Kamat, Ranabennur
-- First Refueling was at BPCL COCO after Nippani
-- Lunch at Vittal Kamat near Umbraj
-- I very easily recall that at 0530PM, I was at Fountain Inn for my break
-- There was no stopping anywhere after lunch as the tank range for the next 650 kms from Nippani will easily take me beyond Mumbai and I could plan my refill after entering the Gujarat Highway
Of course, the Creek Bridge was all functional then but work was in progress at Nalasopara which delayed us by 45 minutes.
With a 0400 AM start that Suhas is aiming, if he sticks to his schedule including taking breaks as planned, he can very well get out of Mumbai and be on the road to Ahmedabad by 0600 PM for sure and might face traffic only till Virar and then have a clean run to Vapi.
The biggest mistake here is to take a break between Pune and Mumbai or stop for a break in Mumbai itself. This will make you cross Mumbai during peak hours.
paragsachania is offline   (1) Thanks Reply With Quote
Old 24th November 2016, 17:20   #64
Thanked: 455 Times
Very much agree with you Parag The only reason I estimated a 6 pm entry into Mumbai was because I considered some unprecedented delays during this time of the year like additional truck and tractor traffic, more so in Maharashtra owing to the sugarcane season and most importantly some sudden protests ( lasting for 15-20 mins ) staged by farmers. Also, read a couple of posts in the past where some people reported taking 12 hours from Bangalore to Pune ( Katraj ). All this and looking at the queries put up by @mpsukhas, I just assumed, he might not be a regular on NH4 ( may be I am wrong here ). Regulars are doing Bangalore--Pune in about 10 hours flat including breaks enroute and without crazily speeding like 140+. I personally believe 100-120kmph on most stretches of NH4 is reasonable and safe. Anyways, 6 pm was just the "upper limit" I considered in general. Else, your timelines are very much doable on this stretch. Other day when I was interacting with a Bangalore-Mumbai-Nasik regular BHPian, I too had given him the same estimate of reaching Mumbai entry point by 5pm with a 4 a.m start from Bangalore.
It was just the sight of many trucks and tractors carrying sugarcane on NH4 the other day and the assumption that OP might not be a regular on this route, some things crossed my mind and I thought of adding an hour extra.
vivek95 is offline   (2) Thanks Reply With Quote
Old 5th February 2017, 15:48   #65
mpksuhas's Avatar
Thanked: 3,372 Times
Thanks for the suggestions Parag & Vivek for the suggestion
Did the trip on 14 Jan 2017-
Start - Bangalore - Marathahalli - 04:30 AM
Took ORR instead of NICE road after a long time.
VRL depot just before Chitradurga ~5 mins break at 06:45 AM
Davangare bye-pass - 07:30 AM
Hubbali toll - 08:56 AM
Belgaum - 10:00 AM
Nippani BP COCO 10:50 AM ~ 20 min break
Lunch break at Hotel Kamat after Karad. 12:34 PM to 01:00 PM. Location
Mumbai-Pune Expressway toll - 03:05 PM
Stopped at food plaza on expressway- 03:58 PM - 04:20 PM
Expressway Exit - 04:50 PM
Vasai Creek/ Hotel Fountain junction - 05:45 to 06:15 PM. Thanks to bridge work took half hour to cross.
Hotel Kalaram Kathiavadi - 07:30 PM - Good place to have food stop. Location
Hotel Ginger Vapi - 08:50 PM
Stayed at Ginger Vapi for night. Started at 06:00 AM from Vapi to Ahmedabad.
Took NH itself instead of golden bridge since traffic was less.
BP COCO north of Baruch at 07:43 AM Location
NE1 Expressway Entry - 09:25 AM
NE1 Exit - 10:15 AM
Ahmedabad SP road toll - 10:35 AM
New bridge near Baruch is still under construction. I guess it may take another couple of months to be done.
Satara deviations are a pain, however felt it was not as bad as projected in this thread.
More than the deviations, traffic as you near Pune was painful.
All toll booths enroute apart from Hubbali byepass accepted Fastag
Details of GJ trip here - Link (Gujarat road trip - Queries)
mpksuhas is offline   (4) Thanks Reply With Quote
Old 11th February 2017, 10:26   #66
King_pin09's Avatar
Thanked: 333 Times
One has to be wary of the mad rush of bikers that builds up at the Kolhapur - Pune stretch by 3:00 P.M onwards (both directions). You encounter an endless ocean of motorcycles carrying 3, 4 or even 5 people, and occupying all lanes. Once caught up in this mess, your speeds will drop down steeply to 40-60 Km/ hr range and help you lose a cool 2 hrs before you enter the MPEW / KA.
Good that you have maintained optimum timings and managed to escape this chaos in time. Congrats.
King_pin09 is offline   (1) Thanks Reply With Quote
Old 2nd March 2017, 17:31   #67
R-Six's Avatar
Thanked: 140 Times
Just drove back from Pune and from what I heard, it is stated to open in the first week of March.
R-Six is offline   (1) Thanks Reply With Quote
Mumbai - Ahmedabad : Route Queries Kaizer Sozay Route / Travel Queries 116 16th December 2017 17:06
Ahmedabad to Indore : Route Queries rammishra Route / Travel Queries 62 11th December 2017 15:38
Rajasthan Trip Pune - Ahmedabad -Jaisalmer - Jodhpur - Ahmedabad - Pune kingshukt Route / Travel Queries 33 3rd November 2017 09:53
Mumbai - Ahmedabad - Jodhpur : Route Queries Shamsher Route / Travel Queries 43 17th September 2017 17:46
Pune - Ahmedabad - Udaipur - Jaipur - Mt. Abu - Mumbai : Route Queries RX135 Route / Travel Queries 86 15th August 2017 18:28
