Old 4th November 2012, 22:29   #31
ampere's Avatar
Thanked: 8,761 Times
Default Re: Current road condition from Madurai to Kumily/ Thekkady?
Originally Posted by gajadonga View Post
From Shenkottai to Rajapalyam was also heavy traffic.
From Srivalliputtur took the road via Sivakasi - Satur.This road is good except
for traversing the Sivakasi town.From Satur it was four lane and I could
bypass Madurai easily.The problem Madurai bypass towards Trichy is two laned and surface is not good and they are charging Rs.40.I felt the charge was pretty high for the average roads.
You were driving to Trichy? Thats why the Sivkasi Ssttur option?
I thought for driving to BLR/HYD why this route? Is the Srivilliputtur-Madurai so traffic prone, that you need to re-route to Sattur?
Old 5th November 2012, 10:57   #32
Thanked: 284 Times
I had to visits temples around Trichy so deviated from Madurai.
I do not know the traffic conditions between Rajapayam-Madurai.
It was only the four lane bug which did the trick to turn towards Sivakasi-Satur.
gajadonga is offline   Reply With Quote
Old 5th December 2012, 23:30   #33
arun_josie's Avatar
Thanked: 4,334 Times
Coming from Kanyakumari/Nagercoil, which is the best route to reach Kumily? Is it through Madurai? If so, how is the road condition between and Madurai and Kumily?
Any other better alternates?
arun_josie is online now   Reply With Quote
Old 5th December 2012, 23:42   #34
ampere's Avatar
I think that is true. There is no option but come till Thirumangalam from where you can divert to the Theni road.
The option via Kerala is not worth it.
ampere is offline   (1) Thanks Reply With Quote
Old 5th December 2012, 23:50   #35
arun_josie's Avatar
Thanks amp! Any idea about the road condition between Thirumangalam and Kumily?
Old 5th December 2012, 23:57   #36
ampere's Avatar
Arun, I think Thirumangalam to Theni is not a problem. Once you hit the bypass at Theni on the road to Kumily, I am not sure how much
of ride widening is happening on that section. (Road widening is happening on Dindigul-Theni section. )
So at worst its the last 60km where you can expect bad roads at most.
Old 17th October 2014, 11:52   #37
thoma's Avatar
Thanked: 1,073 Times
Any updates on this stretch? Kottayam-Kumily, Kumily-Theni and Theni-Madurai?
I had done Kottayam-Kumily some 6-8months ago and Kumily-Theni almost 1.5yrs back; but never been on the last stretch.
thoma is offline   Reply With Quote
Old 17th October 2014, 12:15   #38
ampere's Avatar
I think the road beyond Theni is bad. I mean Theni-Kumily stretch; the one through the ghats.
Old 17th October 2014, 12:53   #39
Thanked: 284 Times
I had been to Sabarimala last month.
Kumily-Theni is not a problem at all.
The roads are in good condition.
The road Gudalur-Vandiperiyar-Kuttikannam has lot of twisty ghats and overtaking has to be done carefully.
gajadonga is offline   (1) Thanks Reply With Quote
Old 19th October 2014, 01:13   #40
thoma's Avatar
Just back from Madurai, 500km round trip in a day. Theni-Madurai is in good condition so is Kumily-Kottayam, but the former can be done in high speeds. Theni-Gudalur is 50:50; some excellent stretches and some crater-crawling stretches. Gudalur-Kumily ghat section on the TN side is surprisingly holding on for good.
thoma is offline   (1) Thanks Reply With Quote
Old 19th October 2014, 10:55   #41
ampere's Avatar
Wow! Thats really nice (and sorry if I sent out a wrong update). I thought I read some time back, that roads beyond Cumbum/Theni till the ghats were quite bad. But this does not look like so.
In other words Theni-Kumily-Kottayam is indeed an option to escape the Kerala arterial road traffic.
Old 19th October 2014, 11:55   #42
thoma's Avatar
Definitely a good option when you can enjoy a) the high speed Bangalore-Dindigul express way b) winding roads from Kumily to Kerala which at present is in pretty good condition.
But sedans and hatchbacks should beware of the pathetic stretches around almost all villages en route Theni-Gudalur. My mention of 50:50 in the earlier post does not mean that the full stretch is 'half doable'. There are good high speed stretches (for ex a good 10 kms) and then comes crater filled 5-10 km road which has to be done in crawling speeds; and this pattern cycles. Kumily-Theni ~65 km took close to 1.5 hrs with good speeds on the excellent stretches and crawling speeds on the bad.
Old 25th April 2016, 08:41   #43
Thanked: 37 Times
Can some one help me with the present condition of road between Dindigul and Kumily?
Bibin is online now   Reply With Quote
Old 25th August 2016, 22:41   #44
Post Re: Current road condition from Madurai to Kumily/ Thekkady?
Dear All,
I am planning to go to Kanjirappally (Kerala) from Chennai, for Onam vacations in first week of September. I am considering following routes.
1) Chennai-Dindigul-Cumbum-Kumily-Mundakkayam-Kanjirappaly
2) Chennai-Salem-Coimbatore-Palakkad-Angamaly-Pala-Kanjirappaly
My preferred route is first one which is at-least 100KMs shorter than second. Can someone tell me about the present condition of road between Cumbum-Kumily-Mundakkayam, especially the width?
sajeeshms3 is offline   Reply With Quote
Old 26th August 2016, 12:54   #45
Thanked: 168 Times
Cumbum-Kumily-Mundakkayam road is in good shape, however, there are lots of curves from near Kumaly to Mundakkayam. Width is sufficient for two vehicles to pass. Generally no issues and you should be able to drive at 60kmph on most sections.
Had driven on this route in March (Kodaikanal to Trivandrum) and recently Trivandrum to Munnar via Kumily.
Saji
SajiNSalin is offline   (1) Thanks Reply With Quote
Bangalore- Madurai- Thekkady- Rameswaram- Tirunelveli- Madurai- Bangalore: Dec 2010 DrVjy Street Experiences 9 20th February 2011 20:14
Chennai-Trichy-Madurai-Thekkady route condition sekharr Route / Travel Queries 41 9th October 2010 19:08
Current road condition on NH4 near davangere ?? Mumbai to Bangalore ume11 Route / Travel Queries 12 7th December 2009 14:58
Current weather / road condition at Wayanad ashis79 Route / Travel Queries 0 25th September 2009 15:05
