Old 13th December 2010, 10:33   #1
Exclamation Bangalore-Kodaikanal Route Map
Team,
We are Visiting Kodaikonal. Looking for Bangalore -Kodai Route trip. Guide.
gogo_gogo is offline   Reply With Quote
Old 13th December 2010, 13:31   #2
sbkumar's Avatar
Thanked: 90 Times
Default Re: Bangalore-Kodaikanal Route Map
Following routes are the ones I have taken
Bangalore-Salem-Dindigul-Chempatti-Vattalagundu-Kodai
or
Bangalore-Salem-Dindigul-Kodai Road-Vattalagundu-Kodai
sbkumar is offline   Reply With Quote
Old 13th December 2010, 16:01   #3
ampere's Avatar
Thanked: 8,593 Times
or
By pass at Dindigul itself and take the 45 (Theni road). That I guess is the standard route for Blr-Kodai.
Old 13th December 2010, 16:18   #4
Yes. Dindigul bypass - NH45 (Theni road) - Vattalagundu (Bathlagundu) - Kodai road - Kodai. Awesome roads all the way.
bullinb is offline   Reply With Quote
Old 13th December 2010, 17:45   #5
motomaverick's Avatar
Thanked: 864 Times
If you are looking for a shorter route then take the one below,
Bangalore - Krishnagiri - Dharmapuri - Thoppur - Mettur - Bhavani - Dharapuram - Palani - Kodai
I did this route first time on a bike in 2008, again did this in Jan 2009, road conditions were good at that time. It took some 10.5hrs in Bike and some 9.5hrs in car. Traffic wise this route has much less traffic than the NH ones.
Old 13th December 2010, 17:47   #6
ampere's Avatar
That would have been the best, if the 4L was not up. If one is bored driving on GQ, its good to take the Palani road for a change.
Old 13th December 2010, 19:21   #7
BulZire's Avatar
Thanked: 132 Times
This route is excellent till last month. but the palani-kodai route is blocked due to a recent land slide in between. When i enquired 2 weeks back I was told that this route will be opened only after 2 months . So right now whoever had planned in this route please ignore it and take salem-Dindigul-Kodai road route.
BulZire is offline   Reply With Quote
Old 13th December 2010, 19:22   #8
But i heard, Palani road is closed since last few weeks. Pl advice.
Old 13th December 2010, 19:27   #9
ampere's Avatar
No idea about closure. I would say the Dindigul-Batalgundu option.
At Dindigul, take the by-pass (I think its the second exit, the first one is 209) to 45 (Theni road). You will hit Batlagundu and divert to Kodai.
Old 13th December 2010, 19:58   #10
bejoy's Avatar
Thanked: 409 Times
Here is the detailed log from HVK:
http://hvkumar.googlegroups.com/web/...Palani-Blr.xls
I followed this route last October and was very helpful. Only place you need to pay a little attention is at Dindigul, where you need to take Theni road. You should not take the Palani road, which turns right from the first junction below the flyover. The signages are a bit confusing there.
This is the fast route. In case you like to enjoy scenery, you can take the Mettur - Palani route, as mentioned by motomaverick.
bejoy is offline   Reply With Quote
Old 13th December 2010, 22:53   #11
Thanked: 864 Times
Too bad the palani - kodai is blocked due to landslide, i remember doing it in december 25th 2008, is this due to rains last month? This was quite a scenic route with very less traffic.
Old 14th December 2010, 03:37   #12
Chevy_lover's Avatar
Thanked: 121 Times
Take the Bangalore - Salem - Dindigul - Vattalagundu - Kodai route. This is the best route in terms of facilities en-route.
If you take the Palani route, you will have to climb 14 hair pin bends. It is best avoided as that road is pretty narrow and the TN bus and truck drivers are maniacs.
Since you are new to this route, drive only during day time. The scenery is awesome en-route. You can also see Silver Cascade water falls just before reaching Kodai, if you take this route.
Kodai ghat roads are fantastic. So have a great drive!
Chevy_lover is offline   Reply With Quote
Old 14th December 2010, 12:48   #13
BulZire's Avatar
Thanked: 132 Times
Exactly, the land slide is due to the recent rains around Palani which was recorded as one of the heaviest in that area in last few years. It is absolutely a scenic route with many hills all around and many mini falls through out. Now 2 wheelers are allowed is the latest update.
Old 8th August 2011, 10:17   #14
prakash_ajp's Avatar
Thanked: 718 Times
Palani-Kodai road is open now and probably the most scenic of the available options. But the road is slightly narrow at some places and one has to be careful enough. And if one is not experienced with ghat roads, I won't recommend it. But I prefer it since I can take the Mettur-Kangeyam-Dharapuram-Palani-Kodai route to avoid all the tolls.
prakash_ajp is offline   Reply With Quote
Old 8th August 2011, 11:19   #15
Thanked: 140 Times
This route is far more scenic than the regular one via Bathalagundu. It is similar to the Valparai road with regard to the views offered of the plains and dams down below.
Here is a panorama shot which I took on my way up last Friday.
pypkmsrikanth is offline   (1) Thanks Reply With Quote
Bangalore - Kodaikanal - Velankanni : Route Queries CJP Route / Travel Queries 216 7th September 2017 14:50
Bangalore - Madurai - Kodaikanal - Bangalore (Route Query) dreamdiesel Route / Travel Queries 19 12th September 2014 11:12
