Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 11th March 2013, 12:09   #31
Thanked: 73 Times
Default Re: Buying a used Skoda Laura
Hello EagleEye,
Came across your post and thought I would chime in with my views. I own a 2006 Skoda Laura MT L&K which was bought 2 years ago. When I bought it, it had clocked over 90,000kms was very well maintained with all service records in place.
It is hard to find less used Skodas in the market and even if you do the asking price will be on the higher side. Buying a 2006 Skoda is alright if the vehicle is well maintained with service done at proper intervals. Having used Skodas for the last 6 years myself I can say that Skoda engines and parts are built to last. I have seen Laura and Octavia which have done over 3L kilometers and still running like new. It all boils down to how well the car is maintained. All the electronics on my car are working fine till date (touch wood).
Things you may do are:
1. Call/Visit Skoda service centre, give them the vehicle number and they will get the service history for you. Look for any major repairs or part changes.
2. The best things would be to see if you can talk the seller into accompanying you with the vehicle to the nearest Skoda service centre. Some sellers won't be willing. I actually did this. We found a problem with the AC compressor at the service centre and also got the vehicle thoroughly inspected. See if this is possible.
3. Skodas are known for their turbo related issues, especially the earlier cars.
4. Check for condition of brake pads, timing belt replacements, fuel injectors, clutch assembly replacement etc.
5. Look for suspension related noises while driving.
There are car dealers who give you a selling price including their margin and there are others who charge 1-2% or a fixed price for a deal. There is nothing wrong in and if fact you should ask the dealer what his charges are.
And remember this, there are a few people who would buy a used Skoda Laura over a new C/D1 segment car. Use this to your advantage while bargaining. Don't rush things from your end. Take some time to find some good deals around.
Good luck with your purchase and keep us posted.
over.drive is offline   (1) Thanks Reply With Quote
Old 11th March 2013, 12:24   #32
ACM
ACM's Avatar
Thanked: 2,882 Times
If you must, go in with your eyes wide open.
The a/c compressor is a failure point. Check if it has been replaced, if not budget for a replacement, ensure a Sanden version is used, you might be able to get this done outside the Skoda network.
DSG enough has been said about it. Budget for the mechatronics, clutch and dual mass flywheel replacements at a later stage
Fuel injectors might need replacement at 100000 km it all depends on the quality of fuel.
heck turbocharger, faulty seals will see blue smoke puffing out.
Otherwise, the 1.9 tdi is a workhorse but a lot depends on the cars maintenance.
Actually as a Laura 1.9PD DSF AT Owner can say that that actually covers it all. Have infact Had AC compressor changed to Sanden, Had turbo and intercooler changed twice and had some issues with the DSG Mechatronic sorted out as well as got the flywheel and timing bets changed when due.
Besides this the suspension can show aging between 75,000 kms to 100,000kms. Basically one needs to budget for this work over time, for any PD would recommend one budgets Rs. 2L over the next 3 years if the car is between 70,000 kms to 100,000 kms.
Originally Posted by EagleEye View Post
I have found one 2008 Laura L&K TDI AT with 62000 kms on the odo. Car looks extremely well maintained, and the dealer says service records are available (of course I'll be inspecting them before taking it further). There are bruises and dents on the body, but nothing major.
My questions to you are below:
1. Where can I take the car to get it checked by some knowledgeable person about wear and tear of components, find out what replacements are necessary, whether all fluids are topped up, etc?
2. Which Skoda dealership can I call to get the service history? Or can I call any outlet; does Skoda have a centralized records system?
3. The dealer is quoting 8 lakhs (he mentioned it is negotiable). How much do you think I can bring the price down on bargaining?
4. Normally when buying from a broker is the brokerage charge over and above the quoted price or is it included?
Thanks in advance.
You need to call the Dealership where the car is normally serviced for the service records.
JMD is I feel the better service centre of the lot in Mumbai. They have 3 or 4 centrer in Mumbai,
You could manage the following pricing 2006- 6L, 2007-6.5L, 2008-7-7.5L (It also depends on the model, as the years progress Skoda introduced lower spec varient - they started off earlier with only the L&K) So as one goes to newer cars one also tends to get lower spec ones (though lesser kms generally means more reliable).
The other thing is that if to check what all has been already replaced, if nothing is replaced but the car is at about say 50-60k kms then a lot may be due for replacement while at 70k the car may have already gone though some of the replacements and be good for another 50,000 kms or so?
Brokerage is normally included in the price quoted by the Dealer. The Dealer makes more if he has already paid for and bought the vehicle and is holding it. He makes lesser money if he is just showing you a customers vehicle and arranging for the deal.
ACM is offline   (1) Thanks Reply With Quote
Old 11th March 2013, 14:46   #33
EagleEye's Avatar
Thanked: 266 Times
Originally Posted by over.drive View Post
Hello EagleEye,
Thanks for your help, I shall definitely get checked all the things you have mentioned. With the help of member ACM I have got in touch with SkodaJMD Bhandup, where I will be going for inspection of the vehicle.
Also thanks for the tip, I'll bargain hard for this car. Actually there are dents and scratches all around the car, and also one scratch on the bonnet which I believe can't be polished away due to the fact that it is slightly beveled up. I'll try to use these things to bring down the price even further.
He is just showing me a customer's vehicle. He said brokerage is 2% but I don't know whether he meant it as over and above the sale price. I'll have to find out.
EagleEye is offline   Reply With Quote
Old 11th March 2013, 15:00   #34
ACM
ACM's Avatar
That is the typical % if it is a customer vehicle. It was included in the price when I made a purchase.
ACM is offline   Reply With Quote
Old 13th March 2013, 20:38   #35
EagleEye's Avatar
Thanked: 266 Times
Dear ACM and other knowledgeable members,
I've 2 quick questions:
1) If the interior parts like plastics, steering etc of a Skoda Laura are scratched/scuffed due to normal wear and tear (not as a result of poor maintenance), can the blemishes be polished away?
The owner says that some chemicals/polishes can be applied and it will look as new.
2) If the gear lever is pretty badly scratched (example pic below), can anything be done about it?
Thanks, I'll be finalizing one soon. I'll tell you the details later!
Old 13th March 2013, 21:00   #36
n.devdath's Avatar
Thanked: 2,077 Times
Such a gear lever cannot be brought to its original form because it has lost the "top coat"that was applied to it during its manufacture.
Also, it is nice to avoid cars which show such signs of wear and tear. With a little patience, it is possible to get an immaculately maintained Laura DSG at a decent price.
n.devdath is online now   Reply With Quote
Old 14th March 2013, 16:15   #37
ACM
ACM's Avatar
ACM -- Actually the AT Gear lever bit that you say is scratched is leather being exposed to moisture from the hands. My gear lever is similar but a bit better. After leather cleaning service it looks much better but returns to this look after a few months. Actually with leather if it is not pealing off then a bit of this look is fine, The Drivers seat too could have a bit of this on the seating area joints.
Getting an original replacement part is expensive whatever be the part. But there are excellent leather workers available who can replace any door pad part to close to original in a reasonable cost (3K for the black part per door near the top of each door pad) The Roof cloth too can be changed for about 5-7K outside the service centre. --
Hi - note the response above itself typed within the quote by mistake.
The best way out is to give the guy who says it can be restored to orignal say Rs. 3000 and tell him to get the work done (interior cleaning) and if it comes our well you will consider bying the car else if you don't like it he can keep the 3K and you too have no regrets about the car you pick up. I had actually paid 10K for service of the Laura I picked up 5 years back on the same terms.
In the case of my gear lever the dark brown marks become very close to the light leather in colour - infact are a bit lighter but one can notice that they have lost the top film.
Old 14th March 2013, 21:45   #38
EagleEye's Avatar
Thanked: 266 Times
Hi, the deal has already been fixed and the person has told me that he will do the interior polishing before giving.
The gear lever I have attached was from another car I was checking; the final car I chose has a worse looking gear lever, unfortunately :(
The rest of the car is immaculate, which is why I went for it. Once the deal is finalized and the car is in my hands I'll try and figure out if anything can be done.
Old 16th March 2013, 11:30   #39
EagleEye's Avatar
Thanked: 266 Times
One of the dealers I had spoken to had recommended keeping a box of fuses inside the car in case of a blown fuse sometime during a drive. Is this necessary / advisable?
And where do I get a box of fuses for the Laura?
Old 16th March 2013, 11:53   #40
ACM
ACM's Avatar
Touching a lot of wood - Have never blown a fuse in my Laura - it is at 87,000 kms. Others could comment if they blew anything. But also never made any after market electrical mods.
Old 16th March 2013, 14:31   #41
Thanked: 1,159 Times
All fuse ratings are mentioned in the owner manual - buy the spare ones as per that list. There are 2 fuse boxes - one in the cabin (below the the driver side dashboard, and the other in the engine bay). The car also comes with a set of spare fuses and bulbs - check if the previous owner has preserved it. It's placed inside the spare wheel in the boot.
Don't forget to buy a fuse puller. it's difficult to take out a fuse with bare fingers as they are quite tightly spaced.
anandpadhye is offline   (1) Thanks Reply With Quote
Old 16th March 2013, 22:13   #42
sagarpadaki's Avatar
Thanked: 1,330 Times
Where can i buy a fuse puller from?
sagarpadaki is online now   Reply With Quote
Old 17th March 2013, 22:35   #43
EagleEye's Avatar
Thanked: 266 Times
I searched online, found these... http://geb.ebay.in/g/ImportHubViewIt...CAR-AUTO-TRUCK
It's expensive because it's coming from US. Better to check at a spare parts store, that's what I'll be doing.
Old 18th March 2013, 14:11   #44
Thanked: 65 Times
You can buy a long nosed plier (the one which has a pointed tip) costing Rs. 30-40 to pull the fuses. It worked on my Octavia.
Bomi is offline   Reply With Quote
Old 19th March 2013, 15:34   #45
Good question. I have been using one that came as part of a PC screw driver set (so it may not officially be a fuse puller). But local auto electrical shops should have those.
Yes, something like this should be good.
anandpadhye is offline   Reply With Quote
New Skoda Rapid or Used Skoda Laura coolboy007 Sedans 19 15th July 2012 11:31
Skoda Laura Ambiente-cheaper Laura deuce-deuce The Indian Car Scene 94 11th July 2008 06:53
