Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 26th October 2014, 23:14   #106
Default Re: Chauffeur-driven / Comfortable Sedan under Rs. 10 Lakh
Hi, I'm in this same quandary upgrading from a 2005 City but have an added need for safety in the back seat since I fall asleep far too easily!
My usage is approx. 1200km/mo. Currently am considering the Verna Sx Opt (with 6 airbags) and Sunny XV Safety (with 4 airbags)... planning to TD next week. Should I be considering any others? Thanks,
bajajm is offline   Reply With Quote
Old 31st October 2014, 11:08   #107
Zappo's Avatar
Thanked: 2,017 Times
Verna is a good car to buy as long as your commute is limited to mostly slow moving city traffic. In fact it is a very comfortable car in such scenarios. Problem starts only when you are on twisties or on high speed drives with sharp manoeuvers etc.
How about also having a look at the Ciaz? It is a very good car for those who are chauffered around. Oodles of space at the back, lot of features and in general should be a very safe although a bit of a plane jane car which should meet most of your demands.
Zappo is offline   Reply With Quote
Old 31st October 2014, 18:41   #108
thanks Zappo
Ciaz does look interesting... but has only 2 front airbags.
Another side question would be: how important and effective are these side/curtain airbags? there are contrary report online.
Re usage, mainly city driving including some on NH8 in Gurgaon!
Old 31st October 2014, 21:24   #109
iliketurtles's Avatar
Thanked: 1,023 Times
I think as chauffeur driven cars go, look no further than the Sunny/Scala. Oodles of space, decent safety in the higher trims and super value for money. The City too has loads of space at the back and might well be worth considering, but the Sunny/Scala should do it for you.
iliketurtles is offline   Reply With Quote
Old 31st October 2014, 22:09   #110
D4D
D4D's Avatar
Thanked: 327 Times
[quote=bajajm;3564644have an added need for safety in the back seat since I fall asleep far too easily![/QUOTE]
Verna is terrific if you're usage is restricted to intracity commutes. It's a good reliable car, easy to maintain and run.
Try looking at the Ciaz if you're chauffeur driven. It's cheaper and will be cheap to run too. It doesn't have curtain sirbags though.
Sunny is a good choice given the Nissan dealer in your area in good.
D4D is offline   Reply With Quote
Old 31st October 2014, 23:50   #111
Thanks guys,
Any inputs on airbags for the back? Worth focusing on this? Because it leaves me with only Verna or Sunny... if I drop it as an essential requirement, options grow to include Ciaz! And also look at another category ie Duster/Terrano...
Any inputs on what is preferred Sunny or Scala?
Any difference in the service or ownership level?
Old 1st November 2014, 01:31   #112
drmohitg's Avatar
Thanked: 3,651 Times
Please avoid the Verna if back seat is where you want to be. The Sunny is the car to go for in your case. And if you are comfortable with having only 2 Airbags then you can also check out the Etios once for the back seat comfort.
As a side note I have hardly seen any one using seat belts in the back in our country. In which case a Airbag may not help either.
Lastly I hope you didn't mean you fall asleep too easily while driving and thats why need a car with more airbags .
drmohitg is offline   (1) Thanks Reply With Quote
Old 1st November 2014, 14:44   #113
IshaanIan's Avatar
Thanked: 3,166 Times
The Sunny/Scala seems perfect. I would not recommend the Verna due to its bouncy nervous ride, but it has received a facelift that reportedly brings huge improvements, so if you're fine with the space in the rear bench, you might want to check out the Verna too (haven't driven the one with updated suspension so I can't say).
If you're feeling a little adventurous, do check out a used Teana nothing this side of 50 lakhs can compete with the car in terms of rear seat comfort
Cheers!
IshaanIan is offline   (1) Thanks Reply With Quote
Old 1st November 2014, 15:07   #114
D4D
D4D's Avatar
Thanked: 327 Times
I actually have a feeling that curtain airbag will harm you if you're head is against the glass while sleeping.
Reason:
See how they deploy in these videos. They deploy from top to bottom and they may not offer protection in side impacts.
Refer:
Give or take a few features and mechanically, there's hardly any difference between the two.
Both Renault and Nissan have a bad reputation for their ASS, so check which dealer in your city has a better reputation.
Also, I think the Scala is a little more expensive than the sunny.
D4D is offline   (2) Thanks Reply With Quote
Old 1st November 2014, 17:58   #115
Which one were you referring to : Sterling or Sarveshwar(?)
Am headed the sunny direction but am not comfortable with poor ASS
Old 1st November 2014, 18:57   #116
drmohitg's Avatar
Nissan aftersales is not poor but it is not upto the Toyota standards either. Another grudge I have with Nissan is that even for the diesel variant they recommend service every 6 months/10k kms. And each service costs around 5k.
Before buying the Sunny, do check on the under thigh support. It may appear to be on the shorter side if you are tall.
drmohitg is offline   Reply With Quote
Old 1st November 2014, 19:07   #117
dZired's Avatar
Thanked: 7,514 Times
Verna is a boat IMO(sorry owners, but I could not put it in a better way). Pathetic ride and hadling.
If you are stern on four airbags, sunny/scala is the choice for you. But if you can drop a couple of airbags, Ciaz is definitely worth a look. City is also a good overall package.
dZired is offline   Reply With Quote
Old 1st November 2014, 20:41   #118
I need a safe back seat and since I use my cars for almost 10 years think I should get the rear airbags as it is only likely to get standard in a few years...
Should I be considering any preowned cars? That may not be popular but are solid workhorses...???
Old 6th November 2014, 23:30   #119
I am getting disillusioned with my hunt for a comfortable and SAFE chauffeur driven car.. as am discovering that in the C segment it seems there is no SAFE car for the rear seated passenger bar the Verna. As all the airbags are for the front seated passengers. Have I made the right analysis here? Help!
Old 2nd March 2016, 18:29   #120
speedmiester's Avatar
Thanked: 828 Times
Default Used Car options: The right ride for elderly parents
Hi All,
I was planning to buy a new SUV between 15-20L by June of this year coinciding with my birthday. But, the additional taxes on new cars in this budget have thrown a spanner in my plans.
Now I am planning to buy a used car, a Sedan or an SUV within 10L which will be used for the next two years. I am not new to used cars, in fact apart from my E2O all my other cars within my family were pre-worshipped cars and touch-wood, I never faced any issues with any of the cars.
My key requirements are as below
1. Safety (no compromise on this one, a minimum of 2 airbags and ABS with EBD)
2. Comfort for my parents in the rear seat with easy ingress and egress
3. Reliability
4. Relative ease of maintenance
This car will be driven by me most of the time and primarily used on long trips with very limited city driving. Fuel efficiency and choice of fuel is not a concern as long as the overall FE is around 10KMPL.
With the above criteria in mind I have shortlisted the following cars in the order of preference.
1. Toyota Corolla Altis
2. Honda CRV
3. Skoda Laura
4. Mahindra XUV500
5. Mitsubishi Outlander
Have ruled out Honda Civic due to low seating and ground clearance issue.
Safari Storme is also ruled out due to excessive body roll, my mother can get car sick quite quickly, so this was a concern with Storme.
I am leaning towards Corolla Altis as it is a good all round car. My only concern with Honda CRV is the ease of maintenance compared to Altis.
Any CR-V owners with their feedback on maintenance?
Are there are any other cars that I might have missed out on or that are worth a try?
P.S: Mods, please move to the appropriate thread as I could not find the right thread. Thanks.
speedmiester is online now   Reply With Quote
Tata Storme - 'Chauffeur driven perspective' torquing_points Test-Drives & Initial Ownership Reports 117 28th January 2017 21:28
Most comfortable car/SUV for long journeys (under 12 Lakh) mohan41 What Car? 71 13th September 2016 22:08
Best Chauffeur Driven Car (18 - 25L) jatinahuja Luxury, Imports & Niche 18 24th July 2010 11:19
Best Entry Level Chauffeur Driven Diesel Sedan Gautam Misra The Indian Car Scene 68 22nd July 2010 15:21
chauffeur driven hatchback in 4.5lakhs < NM360 Hatchbacks 37 27th October 2007 23:51
