Go Back   Team-BHP > Indian Cars > What Car? > Sedans
Sedans Indigo, City, Fiesta, Octavia etc.
Thread Tools
Old 29th June 2007, 16:28   #1 (permalink)
gopz's Avatar
Default used Accent (petrol) or used Baleno (budget 3 lacs)
Any suggestions? I want FE, maintenance on priority
gopz is offline   Reply With Quote
Old 29th June 2007, 16:28   #2 (permalink)
rjstyles69's Avatar
Baleno Baleno all the way .
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 29th June 2007, 16:43   #3 (permalink)
arup10's Avatar
Without a doubt, go for the Baleno.
It way ahead in terms of performance and fuel efficiency.
arup10 is offline   Reply With Quote
Old 29th June 2007, 17:14   #4 (permalink)
akshay1234's Avatar
baleno. u wont regret it.
akshay1234 is offline   Reply With Quote
Old 29th June 2007, 17:34   #5 (permalink)
gopz's Avatar
Well, I heard that Baleno is very very expensive to maintain, spares are imported and cost a lot. Is that true? Since I am buying a used car, I better be aware of spares cost before I invest in a car!
And I dont like the looks of Baleno :( However I think this is the best in 3lac budget isnt it? I dont want Esteem/ Ikon. Any other Sedans worth looking at (used)?
I somehow like Accent because build quality is better & resale value is less so i can bargain a good deal. But if BHPians can convince me about Baleno's then i dont mind the looks. Help! I am confuseddddd!!!
Old 29th June 2007, 17:40   #6 (permalink)
mclaren1885's Avatar
Only the headlamps and tail lamps of Euro III are expensive. However what is expensive in the whole car is the AC condensor assembly @ 20k. Rest everything is on par with the cars in its class if not cheaper. Since you are buying a 2nd hand car, things like suspension, brakes, clutch etc are pretty cheap.
Then I suggest you stick to the accent. There is no point in buying a car that you don't like.
At the end of the day, its you who will live with the car. Not us BHPians. So stick to what you like best.
__________________
I am proud of you, binzy boy !!! Keep up the good work.
Old 29th June 2007, 17:45   #7 (permalink)
gopz's Avatar
Well its not that i hate the looks but the rear is somwhat not to my tastes...but I want to know whats the FE of Baleno (city & highway) and also want to know what all I need to check when i look for a used car (not general tips, but what I need is specific to Baleno - if there are any checks to be done)
And any short comparison between Accent and Baleno (or a link to a thread) will be of great help!
Old 29th June 2007, 17:47   #8 (permalink)
navdeep's Avatar
You are on TBHP and I don't think anyone will reco other than Baleno .. and you know what ... TBhpians are right !
__________________
eXpect the uneXpected | Diesel For Men
navdeep is offline   Reply With Quote
Old 29th June 2007, 17:48   #9 (permalink)
gopz's Avatar
Also, I like the Baleno Altura better than the regular one...is there any difference in the engine or suspension or gearbox of an Altura compared to a standard Baleno?
ANother question- Baleno's power steering - is it hydraulic or electronic? I prefer electronic ps because its helpful on highways.
Old 29th June 2007, 17:50   #10 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
No point buying a car whose looks you dont like. I mean, you are going to live with it on a daily basis. Go for Accent in that case.
You are right about the Accent resale value. But build quality ? Hmm, thats a new one. That's supposed to be the prerogative of only Fiat cars.
If you think you are the type that can be convinced to change your opinion, search for Baleno and you will get all the reasons you need to get convinced. But again, buy a car that you like - not because someone convinced you.
__________________
Give time a break - be a part of the Chennai-tbhp drive to Pondy.
Check out the "Rendez-vouz at Pondichery" thread for details.
Old 29th June 2007, 17:50   #11 (permalink)
Honestly, you can call me mad. But I love the rear of the Baleno from certain angles. I wish I could capture a pic of what my eyes see. But, I can't.
FE of the baleno without AC should range between 12-14kmpl with sedate driving and about 12 with AC. On the highways expect a FE of over 15 under 120kmph.
Well, nothing particular in baleno to check. But check the status of the suspension, tires, brake pads, clutch, status of windscreen, accident damages. This holds good while purchase of any second hand cars.
Suspension is much stiffer on the Altura. Engine and gearbox remain the same.
Its hydraulic. And its far better than most other cars with PS. Infact, I am thankful that there is no PS on the baleno.
__________________
Old 29th June 2007, 17:56   #12 (permalink)
gopz's Avatar
hey guys thanks for all the quick responses...!
I think I will consider Baleno...any idea on which model I should look for? I dont know much abt the versions or variants so suggest me a good model (for eg. Esteem MPFI is better than the older engines..things like that for Baleno models/ variants)
Old 29th June 2007, 17:57   #13 (permalink)
namit's Avatar
Out of these 2 Baleno will serve you longer and perhaps maintenance free relatively.
namit is offline   Reply With Quote
Old 29th June 2007, 18:14   #14 (permalink)
gopz's Avatar
McLaren1885, your posts are very helpful, let me know if there are any long term reviews of Baleno.
Old 29th June 2007, 18:26   #15 (permalink)
rjstyles69's Avatar
gopz search here : http://www.team-bhp.com/forum/long-term-ownership-reports/ and you will find quite a few long term ownership reports.
edit :
Only LXI and VXI.
__________________
rjstyles
Thread Tools
New Car for Myself - Budget 8.0 lacs Vishesh Sedans 22 8th June 2007 10:43
Looking for SBK (as soon as possible)-Budget 4.5 lacs barbar Shifting gears 1 12th September 2006 00:09
budget 5-6 l fiesta/baleno/accent/indigo/swift/flair? pankaj123 Hatchbacks 12 8th July 2006 11:42
Calculated:Diesel versus Petrol. Baleno /NHC/ Accent Crdi Buffetfan Sedans 23 19th September 2005 18:20
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
