Go Back   Team-BHP > Indian Cars > What Car? > Sedans
Sedans Indigo, City, Fiesta, Octavia etc.
Thread Tools
Old 31st July 2007, 20:55   #1 (permalink)
Default advise needed on buying a car
hi everyone
i self drive about 80000kms per annum. presently driving a WagonR. Planning to go for a bigger one.most of the travel will be in karnataka, kerala and tamilnadu.need AC and power Steering.i have clocked more than 4L kms till date on Petrol cars.now i have started getting neck pain ( severe).but travel is a must. i feel i should think about diesel also.please suggest a decent vehicle either new or used within 8-9 lakhs. all the roads i travel range from bad to worse.
thanks!
nutmello is offline   Reply With Quote
Old 31st July 2007, 21:53   #2 (permalink)
jkdas's Avatar
Safari Dicor !
Either 3L or wait and get the 2.2L
__________________
Audio, video, disco
Tat tvam asi
Old 31st July 2007, 22:00   #3 (permalink)
DCEite's Avatar
In 8-9 lack diesel car options, you have Fiesta TDCi and Verna CRDi.
Both cars have their own pluses and minuses, deliver similar fuel efficiency. While Fiesta has good driveability in city conditions, Verna has much better highway performance. You can consider base model Elantra as well ( i am not sure it sells now or not).
A note of personal advice. You mentioned you are having severe neck pain due to all the driving. Why don't you buy a cheaper diesel car (say an Indica/Indigo/Logan), and invest the remaining money(4-5L) (say in a monthly income plan or a mutual fund) and use that money as salary for the driver (ie be driven instead of driving)? That way your body can get sufficient rest and within 2-3 years you will be able to drive again with full vigor. Hows the idea? Please don't mind if it doesn't suit you.
DCEite is offline   Reply With Quote
Old 31st July 2007, 23:31   #4 (permalink)
lamborghini's Avatar
Hey nutmello,
If you are looking for a diesel car, check out the fiesta or the Verna D.
The elantra is not available in diesel anymore.
I had posted a thread in the same section where the main choices were Fiesta D and Verna D.
Do check that thread out as i listed the pros and cons of each car.
Also, if you don't mind an SUV, try the safari.
__________________
¢нєєяѕ
ℓαмвσ
lamborghini is offline   Reply With Quote
Old 1st August 2007, 00:20   #5 (permalink)
For your price tag, FIESTA D / VERNA D is the best bet. If your drive involves more of highways, go for VERNA, else FIESTA should be fine.
karty_83 is offline   Reply With Quote
Old 1st August 2007, 08:15   #6 (permalink)
dear pal
thanks for your advise.im seriously considering having a driver also. please suggest on innova / bolero? i will take a test drive of verna and see. but neck pain has become worse with pain coming down to fingers.
Old 1st August 2007, 09:49   #7 (permalink)
vabs78's Avatar
Originally Posted by nutmello View Post
dear pal
I think what you need is a comfortable vehicle which is easy to drive. Bolero won't fit the bill here. If you need space then Innova should be a good choice. Your travel is in city or highway?
Honda city CVT can be a good option in city. Not sure about the ride comfort though.
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 1st August 2007, 10:05   #8 (permalink)
CrAzY dRiVeR's Avatar
Since you are considering a driver.
I guess you need the best back-seat, and i dont think any vehicle in the market can better the TATA Safari for back seat comfort. You could also look at the innova.
Also, if you want cheaper options, Logan D is said to have a very good ride comfort.
And, please go for medical check up. A stitch in time saves nine.
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 1st August 2007, 10:59   #9 (permalink)
Wow, thats some amount of running. Keeping in mind the volume of running, bad road factor and that you are keen on comfort, its either the Tata Safari or the Toyota Innova for you.
Search the forum for reviews. And test-drive both before making up your mind.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 1st August 2007, 11:14   #10 (permalink)
namit's Avatar
I think its Logan Diesel for you with good ride quality and loads of space.
TD and decide between Fiesta D / Innova / Logan D according to me.
namit is offline   Reply With Quote
Old 1st August 2007, 11:25   #11 (permalink)
iraghava's Avatar
I too would suggest the Toyota Innova for the sheer confort & ease of driving. However, do have the neck pain checked up immediately, it can be something serious & such symptoms should not be ignored.
__________________
Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
Old 1st August 2007, 12:35   #12 (permalink)
yogi1771's Avatar
hi off topic regarding your neck pain get a MRI done yours is a classic symptom of cervical spondylitis
yogi1771 is online now   Reply With Quote
Old 1st August 2007, 12:47   #13 (permalink)
phamilyman's Avatar
Indica/Indigo front seats are best. For your cervical pains, best is to make the front seat almost flat and travel half sleeping with a neck pillow. Aids alot.
Helped a lot in my neck pains when I earlier used to commute about 40 oddkms a day in office cab. Don't bother about eliteness or anything else.
I'm not sure but in Palio adventure or Marina - the rear seat can be completely rolled back. With your travel, i'd recommend that - sleep as you travel. Neck first, EVERYTHING else later.
phamilyman is online now   Reply With Quote
Old 1st August 2007, 13:19   #14 (permalink)
gemithomas's Avatar
hi everyone
thanks!
with that kind of running you seriously need a diesel. I waould also suggest that you go for a car that gives you the best driving posture so as to avoid enhancing your pains. I think higher seating would be better and the ride quality should be really good. I think you should look no further than the Innova. It can be driven like a car. Its got the best suspensions in its class. Its got enough and more space for long travels. I've seen ones that run as smoothly as new even after crossing the 2L mark. And most of all...its within your budget . Just dont waste time thinking. with your kind of travel, you need the best ride. Go for the Innova. I suggest the 7 seat version with pilot seats in the middle row. It ensures comfort at the best for you when go with a driver.
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 1st August 2007, 20:52   #15 (permalink)
thanks a lot for your support.i was doing lot of rallying in my 20s, in a gypsy then on esteem and also finally on a baleno.now this neck pain has taken away all my instincts.its really painful. thanks again
Thread Tools
Help needed in buying a second-hand car ahmik SUVs, MUVs & 4x4s 4 7th October 2008 00:55
Buying a 1998 Honda City Advise Needed madhokritesh Sedans 6 25th August 2008 13:56
Help Needed for Buying a Used car scorpio07 Sedans 14 25th June 2008 12:31
Advise needed on buying Tata Safari kdeepakk SUVs, MUVs & 4x4s 52 13th July 2007 16:50
Advise needed on buying Opel Astra spatafarose Sedans 3 29th March 2007 10:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
