Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 20th March 2015, 00:02   #91
PatienceWins's Avatar
Thanked: 284 Times
Default Re: Car for Super Tall Men
I am 6' 2" tall and the cars I find comfortable for tall driver are:
Hatch - Wagon R, Swift
Sedan - SX4
SUV/ MUV: Ertiga (best choice), Scorpio
I find Maruti particularly good for tall drivers with the seat quality, height and seat travel. I would have gone for Swift instead of Getz if it had more space for my family. I am managing in my Getz by adding extra foam and using an extra cushion.
PatienceWins is offline   Reply With Quote
Old 24th March 2015, 21:28   #92
vaibhav_a_a's Avatar
Thanked: 179 Times
Update - tried the Ertiga and found the central console a serious hindrance to my left leg. Seating as recommended above cannot be faulted though.
vaibhav_a_a is offline   Reply With Quote
Old 24th March 2015, 21:32   #93
Thanked: 29 Times
Try Ritz. Seating position in Ritz should be more apt for tall persons.
speedgun is online now   (1) Thanks Reply With Quote
Old 26th March 2016, 21:40   #94
I am 6ft 2in but not too big at 65kg. I have had a Swift VDI since 2008 and clocked 89k. Given sporadic pain in the tail of my spine and left knee, looking at options, preferably south of 10L.
I test drove the following - primarily automatics with a view to giving my left leg rest but have not been able to make a decision
1. Ecosport AT - No room behind me after adjusting the driver's seat to the maximum legroom position
2. New Figo AT - Narrow car, did not seem to be suited for 5 passengers
3. Vento TSI - Absolutely loved this car. Left leg was able to rest on the seat due to the lack of a clutch but not too sure about the low seating
4. Ciaz AT - Very good in terms of space but the AT is not fun to drive at all
5. Baleno CVT - Not fun to drive
6. Baleno Petrol MT - With the seat height adjustment and light clutch seemed to be a good option
My preference would be grey/ black interiors and at least reasonably fun, if not a hoot, to drive.
Would be great to hear from the experts.
Thanks!
krishna_kt is offline   Reply With Quote
Old 26th March 2016, 23:17   #95
ToyotaFan's Avatar
Thanked: 246 Times
Thanks!
I think you should try the Jazz V CVT. You may need to put black seat covers but the seating position is spot on for tall folks as am myself 6'2". It's a reasonably good performer with ample space for 5 and their luggage.
ToyotaFan is offline   Reply With Quote
Old 27th March 2016, 18:30   #96
Thanks. I did try the Jazz both in CVT as well as MT options. I drivers seat is restricted from traveling way to the back. Hence, I feel leg room is restricted for a 6ft+ driver. Since, I was at Honda, tried the City - legroom was better, but not a big fan of the current version.
Old 27th March 2016, 19:34   #97
shankar.balan's Avatar
Thanked: 5,349 Times
Krishna.
Im 6 ft 2 inches tall too, with long legs. Am also very big built and nowadays, quite fat. 100Kgs.
I fit beautifully in my Dad's I20. I fitted very comfortably in his old Indica V2.
Every time I use a cab service, I realise how absolutely comfortable the following cars are;
1. Swift Dzire both old and new
2. Renault Logan/ Mahindra Verito
3. Toyota Etios - this is simply superb.
Other cars I can suggest to you are the petrol versions of Nissan Sunny, Renault Scala.
All of which should meet your requirement of below 10 Lac.
But seriously, all things considered, the best of the above mentioned, to me, are
A: Toyota Etios
B: Renault Scala/ Nissan Sunny.
Old 3rd April 2016, 14:06   #98
Thanks Shankar.
Have pretty much tried all options in the sub 12L bracket and finally decided to go with the new Baleno. It meets a lot of my criteria.
I actually booked it a while ago and should get it in the next couple of weeks.
Cheers!
Old 26th August 2017, 21:17   #99
Thanked: 27 Times
I'm 6' 2" with long legs. I've been using a Swift for the past 3 years. While somewhat manageable for short drives, the driving position quickly becomes uncomfortable for drives lasting longer than an hour - the lack of legroom and the lack of a telescoping steering complicate matters.
I'm now looking at AT cars in the 10 - 15L bracket which are atleast reasonably fun to drive. Finding a car with a good driving position (while leaving reasonable legroom for rear passengers) has been a challenge.
Hyundai cars (Creta and the new Verna) for some reason omit a telescoping steering wheel which greatly reduces driving comfort levels. In an Ecosport, my driving position leaves almost no legroom for the passenger behind me. While the Vento is comfortable, I've ruled it out for various reasons.
Any suggestions on cars that will "fit" people like me would be much appreciated.
I'm open to looking at used cars in a segment above if they offer better seating.
qaqa is offline   Reply With Quote
Old 27th August 2017, 01:22   #100
ToyotaFan's Avatar
Thanked: 246 Times
I have a similar body structure and this was a major criteria for me when I was in the market 2 years ago. Though my budget was around 10L only and EcoSport was a top contenders for my requirements but the leg room left with my seating position was a deal breaker. Regarding AT cars the City and the Jazz have excess leg room which should prove to be enough even with your seating position. I test drove both the cars at that time but had my head touching the room in the sunroof equipped 4th gen city. Legroom in both the cars is sufficient and you can possibly fit two six footers one behind the another.
For a 10-15L lakh budget the Honda City is a no brainer with the AT in mind. Do check out both the VX/ZX and the V to see if you are comfortable with the head room. If you don't mind the hatch then the new Jazz Platinum edition with the Digipad system is also a good buy though at 8.42 lakhs for the CVT it does seem a bit expensive. None the less am fully satisfied with the jazz and don't get tired even on long hauls. My cousin recently got the CVT and he too is happy with the car in the city though finds it wanting on the highway. So I feel the City should be your first choice and the jazz can be a backup. Hope this helps.
ToyotaFan is offline   (1) Thanks Reply With Quote
Sudha Cars' 26-feet tall car (Hyderabad)! shyn The Indian Car Scene 2 17th October 2015 13:20
KTM 1290 Super Duke R, Super Adventure imported into India Tushar Superbikes & Imports 3 26th June 2015 11:24
which car for tall drivers sakharamcool Hatchbacks 56 19th January 2015 13:27
Need Help in buying a car for 6' tall passenger. ~28L budget. ronnyquest Luxury, Imports & Niche 10 11th May 2009 23:22
