Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 19th June 2008, 16:13   #1
Smile Whis is the best second hand Diesel car?
Hi Everybody,
I want to buy a used diesel car. My budget is 3.0 lakhs. I have shortlisted Lancer GLXD/SLXD, Palio 1.9 D and Ikon 1.8D as my options. Can anybody give me some suggestion on each of the option (pros and cons). My preferences on this purchase is Low cost of ownership, good quality (both build and ride) and a decent resale value. I am open to your views on the following points.
1. Is this a good idea (buying a used diesel car)
2. If the answer is yes for the above question what care should be taken while buying one.
Thanks,
ForeRunner is offline   Reply With Quote
Old 19th June 2008, 16:22   #2
Thanked: 20 Times
You can safely remove Ikon 1.8D from the list. It is known to be a problematic one (however, you will get one for much lesser than 3L).
Of the other two, palio 1.9 is my pick (unless you need that boot). Accent CRDi is a better one however you may not get a good one for 3 lakhs. Not sure why Indigo is not in your list? Indigo should retain better resale value than Palio
Not really, unless you know that the car odo reading is correct, and that the owner has taken good care of the car.
Need to take it to a mechanic. Need to check the health of the engine as well as the injectors. I am told that fuel injectors are very expensive. Would be advisable to check the car early in the morning (for cold starts).
Dieselheads, please advise!
Jeep is offline   Reply With Quote
Old 19th June 2008, 16:25   #3
Eddy's Avatar
Thanked: 5,078 Times
Welcome to the forum. Please go through these articles
http://www.team-bhp.com/forum/buying...-used-car.html (ARTICLE: Buying a New Car vs Used Car)
http://www.team-bhp.com/forum/buying...car-india.html (ARTICLE: How to buy a *USED* Car in India)
Apart from these, there are a lot of threads running on each of the cars that you mentioned above. Please search and you will find a lot of info.
On a personal note, please avoid a Ford 1.8D since it will be fairly expensive to maintain.
Eddy is offline   Reply With Quote
Old 19th June 2008, 16:33   #4
shuvd's Avatar
IMHO, stay away from the Ikon 1.8. I have suffered a lot with that car.
See if you can find a really old Elantra.
shuvd is offline   Reply With Quote
Old 19th June 2008, 16:37   #5
greenhorn's Avatar
Thanked: 1,519 Times
how about an indica? In fact, if you stretch your budget a bit , you can buy one new. Thats what I ended up doing. started with a 3L budget , but ended up buying a new indica ( and a turbo at that ). I think I made the right decision
greenhorn is online now   Reply With Quote
Old 19th June 2008, 16:45   #6
Hi Jeep,
Thanks for your valuable inputs.
My dad already has an Indica and I feet the quality of TATA cars is poor. I think except FE and Low maintenance cost we can't expect anything from Indica.
Old 19th June 2008, 17:29   #7
Awaiting Email Confirmation
Thanked: 20 Times
the lancer diesel, though slow, is quite reliable.
of course, you will have to get it checked out by a mechanic who's knowlegable and trustworthy.
are you sure you dont want a new indica?
please stay away from the ikon.
Old 19th June 2008, 17:36   #8
abhinav.gupta88's Avatar
Thanked: 310 Times
Try for a Swift Diesel too. it will be good if you can get a good one
Old 19th June 2008, 17:39   #9
vkochar's Avatar
Thanked: 219 Times
Go for an Accent CRDi - At that price you can find one with luck.
Other cars are a No No !!
vkochar is offline   Reply With Quote
Old 19th June 2008, 17:46   #10
snaronikar's Avatar
Thanked: 23 Times
Swift Diesel is not available at 3L. The owners are not willing to part their ways with DDiS. For Swift coming into 2nd hand market will take some more time and that to for 3L is impossible unless the owner wishes to sell it.
snaronikar is offline   Reply With Quote
Old 19th June 2008, 18:01   #11
greenhorn's Avatar
ForeRunner, which is your dad's indica's Vintage? They hugely improved compared to the earlier models
Old 19th June 2008, 20:17   #12
Thanked: 13 Times
Hey ForeRunner! Welcome to Team-Bhp...
First, tell us, why you are thinking of buying a used car... Is it the sound of the diesel or the sound of the money that you'd save by driving a diesel?
IMHO Since there is a premium on Swift Diesel Hatchback, it would be difficult to find a used one for even 4L
Accent CRDi is your best bet, followed by Indica. Other cars like Lancer, Ikon etc., maybe too expensive to maintain with parts that are hard to find too!
barcode is offline   Reply With Quote
Old 19th June 2008, 20:47   #13
GTO - Touring's Avatar
I'd suggest:
1. Palio D : Simply construction and incredibly robust.
2. Indigo : Either a used example, or you can stretch for a new Indigo CS.
GTO - Touring is offline   Reply With Quote
Old 19th June 2008, 21:12   #14
Thanked: 1,415 Times
Of the three, Lancer would be the best. Pick up is slow but engine is very trouble-free and reliable. Most silent among diesels and fastest cold starts. In fact it starts better than even a petrol car. I have seen one here which has logged nearly 5 lakh KMs and still no work on engine is done, apart from the standard Mitsubishi 1 lakh km service where they change timing belt, pulleys etc. But finding a good used diesel car is a tough task.
pgsagar is offline   Reply With Quote
Old 19th June 2008, 21:51   #15
karanraheja's Avatar
Thanked: 266 Times
Lancer - If you spot a used Lancer it ll have lot of km s done. Not easy
to spot less km done lancer.
Palio D- Wins hands down for build quality but loses when it comes to resale.
Ikon D- Just forget this car . It ll be quite expensive to maintain.
Instead
2nd hand Accent CRDI -
Not sure you will get a well maintained Crdi @ 3l.
But this should be the best buy IMO.
karanraheja is offline   Reply With Quote
Wanted VFM second hand diesel car: Ford Fusion 'vs' Logan/Ikon/Fiesta/Swift/Ritz abheekg Sedans 83 3rd November 2015 16:45
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
Advice on second hand diesel car GoodDevil Hatchbacks 31 1st October 2008 10:41
