Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 9th August 2010, 15:19   #16
Ardy's Avatar
Thanked: 86 Times
IIRC, there is on Silver VRS (Peted) listed in the classified pages of AutoCar India (August' 10 Issue), although not sure if the ad is for Delhi.
Will check again tonight and let you know.
Cheers,
Ardy is offline   Reply With Quote
Old 16th August 2010, 14:06   #17
ashish22's Avatar
Thanked: 49 Times
most of the vRS available now in the market would have crossed 40-50K kms mileage atleast. These cars would definately need through checkups and replacement of following parts:
1. Timing Belt
2. Brake pads and discs
3. Tires
4. Fuel Pump
5. Clutch
6. AC Coil
7. Suspension tune up
8. I'm sure one or two sensors would be on the brink of giving up as well. Dust is the biggest enemy.
Apart from this there are many other issues which can creep up which others can point out. Buy vRS only if you have time, patience, alternate car and money in hand.
ashish22 is offline   Reply With Quote
Old 17th August 2010, 19:30   #18
v&v
v&v's Avatar
Thanked: 1,099 Times
1. Timing Belt
3. Tires
4. Fuel Pump
5. Clutch
6. AC Coil
Thanks buddy for the advice. I am almost through with a deal. I found one 2004 December vRs(Grey) with Odo only 33k absolutely scratch less. Got it scanned from wheel force , rajouri garden - they are Bosch service center.
They say clean car less driven. It has covered 14500kms in 1215 days as per scan.
Works to be done is Service, Break rotor and pads to be changed.
Will post the details soon.
v&v
v&v is offline   Reply With Quote
Old 18th August 2010, 11:45   #19
ashish22's Avatar
Thanked: 49 Times
Yes i've been to wheel force, the bosch service center. Used to get my OHC serviced from there before automax honda came in mayapuri. Have you got the car checked from skoda as well?? i would suggest taking the car to fahrenhiet.
Is the mileage genuine?
Old 18th August 2010, 11:56   #20
Thanked: 11,092 Times
v&v
Errrrr
My Vrs - 45000km - still on original rotors. Front pads were changed at 35000km. Rear lasted about 28000km.
Old 19th August 2010, 03:54   #21
v&v
v&v's Avatar
No i didnt checked from skoda. Certainly need to find a good skoda dealer. Will try fahrenhiet. do you get your car services from there ? any reference.
Errrrr
ajmat these were all pre-buy suggestion by the wheel force guys. Certainly will re-evaluate the before changing. I think a little laith work should resolve the rotor issue.
Old 19th August 2010, 04:43   #22
v&v
v&v's Avatar
Now the news. I bought this car yesterday. Closed the deal all cash at Rs 4.75L
Here is the details
Model : 12/2004
Color : Diamond Grey
Odo : 33610
Status of Car : sparingly used after 2008.
Service Records : Yes
Duplicate Key : Yes
Key Tag : No. they even dont know about it. Assured me to check for it.
Things i plan to do and need advice from vRs owners
Immediate :
1. Service & Oil Change - Thought of Helix - Any other suggestion.
2. Re inspect break pads again. Rotor will hold back for a while
3. Service interval display reset.
4. Air filter checked
5. Will get the timing belt checked. Plan to get it changed as its six years old and more concern no being used regularly.
6. Injector cleaning - How about system G ?
Any other which i need to check immediately as the vRs was less used for 2 years.
Name:  IMG_8963 Medium.JPG
Advice required - Skoda Octavia RS 1.8 Turbo - Bought - Diamond Grey/2004-img_8973-medium.jpg
Mods : Can this thread be moved to ownership section and continue with the same or need to create a new one ?
Old 19th August 2010, 09:15   #23
v&v
v&v's Avatar
I have created a new thread with link below. All my updates regarding ownership will be updated in the below link.
http://www.team-bhp.com/forum/test-d...ml#post2033545
Thanks to all of you again.
v&v
Skoda Octavia vRS - 12/2004 - Diamond Grey - Update @ 54000 kms v&v Long-Term Ownership Reviews 188 8th May 2018 19:34
Lateral Movement - Skoda Octavia to Honda Civic? EDIT : Bought Civic! Jay5150 Sedans 44 19th August 2009 06:07
Wtb: 2004 - 2006 Skoda Octavia 1.9tdi R32_GTR Shifting gears 1 2nd June 2007 12:07
2004 Skoda Octavia. v12 The Indian Car Scene 4 24th February 2004 10:04
2004 Skoda Octavia. v12 The Indian Car Scene 0 21st February 2004 16:39
