Go Back   Team-BHP > Indian Cars > What Car? > Sedans
Sedans Indigo, City, Fiesta, Octavia etc.
View Poll Results: which one you would like to go for??
year 2000 car with less KMs in the odo 14 77.78%
year 2002 car with more KMs in the odo 4 22.22%
Voters: 18. You may not vote on this poll
Thread Tools
Old 22nd March 2005, 23:12   #1 (permalink)
Question used years or KMs ??
hey ppl
AS my search is going for a used baleno, i came across lots of cars, some were having less KMs in odometer but they were too old like year 2000 and some cars were new like year 2002 but they were having more KMs in the odo or u can say they were used more.
so the problem is which one should i go for?? should i go for the old one with less KMs in the odo or the new one with more KMs in the odo?? so tell me your choice and the reason behind it.
PF
Power Freak is online now   Reply With Quote
Old 22nd March 2005, 23:18   #2 (permalink)
drifter's Avatar
Odos can always be tampered with.
But i suggest you take an older car with less mileage than a newer car with more mileage.
But no matter what...decide only after a thorough testdrive and also do take a trusted mechanic along to check the car.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 22nd March 2005, 23:24   #3 (permalink)
Shan2nu's Avatar
Usually, it's the brake pads, clutch, bearings and tyres that sustain max wear and tear. A check on these things will tell you how the car has been used.
Never go by the odo reading, as i've seen people wear out their brake pads in 5-7K kms. That sort of harsh driving is bound to wear out the other parts as well.
I suggest you get the car checked for worn out parts irrespective of model year or kms done.
Tell the owners that you would like to get the cars checked and if they refuse, don't even bother taking a 2nd look at the car. Any owner who is confident that his car is in good shape will not refuse.
Shan2nu
Old 22nd March 2005, 23:37   #4 (permalink)
If you can trust the ODO, I would suggest a car with lower kms on it. Obviously you will have verify the odo readings with the state of the car, because the one with the lower odo reading should 'feel' tighter or else its either showing the wrong reading or its been thrashed around.
Older cars with low odo readings - check the muffler/silencer/exhaust. If they havent run around for long they should be rusting and would cost you a bit depending on the manufacturer. On the other hand, if you see rust on the exhaust you can also be reasonably sure that the car really hasnt run much - the cost fo the exhaust can then be negotiated in the cost. As an indicative figure, the one on my Accent cost me Rs.3,500/- to replace, but I believe its 5K + for other cars in that bracked.
Steer
__________________
It is no measure of health to be well adjusted to a profoundly sick society.
- J Krishnamurti
Steeroid is offline   Reply With Quote
Old 23rd March 2005, 08:56   #5 (permalink)
If you know a car that has a higher odo reading but is relatively young has been used on long highway trips - go for it. Incremental costs will be around tyres and wheel bearings. The engine would have has less dynamic loading (no city-stop-start wear andtear) and been working at optimum temperature
Old 23rd March 2005, 09:14   #6 (permalink)
There are just too many variables, and preferences would differ from situation to situation.
1. I would rather buy a car that has 40,000 carefully driven kilometers than one that has 20,000 rashly driven kilometers.
2. I was checking out some W124s recently, and 1996 cars that had run 40,000 kms were in much better shape (mechanically) than cars that had run barely 10,000 and had been sitting idle in the garage. Cars are made to run, not rest and rot in a place.
3. Model year would probably be more important in some cases and research is most important. When I was looking for a Vtec, I was dead keen only on those manufacturered after September 2002. Reason? The ones before had an ECM problem which makes them jerk intermittently over bumper-to-bumper traffic conditions.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 23rd March 2005, 09:15   #7 (permalink)
johnjacob's Avatar
Exactly. If you are sure the odo has not been tampered with (private sale from friend, say) then I suggest you go for the older but lower mileage car.
But of course, it depends on the car too. If the 2002 car is a VTEC, and the 2000 car is the older City 1.5 then, everything else being equal, I would go for the VTEC.
And of course, it also depends on the driver. If I was buying a used VTEC from a careful driver (like Team-BHPian Shan2nu ) then I would prefer that over an older but lower mileage VTEC driver by a careless driver.
Bottomline is, do a thorough inspection of BOTH cars with an experience mechanic. Then decide.
__________________
I have seen God... His name is Petter Solberg...
johnjacob is offline   Reply With Quote
Old 23rd March 2005, 09:25   #8 (permalink)
tabrez02's Avatar
I would like to add some info on the ODO as, its always better to check the service history of the vehicle from the service centre where it has been serviced, there you will be able to get a fair idea about the odo readings for each service. (if the service centre is computerised).
Once we had such problem where we went to buy a corsa of 2001 and the reading was 19K but actualy when we checked the service history in the Opel Garuda the last service was done at 29K. However we still picked up the corsa for 50K less after knowing this and bargained as the condition was ok except the odo.
So be careful about this.
__________________
Tabrez
tabrez02 is online now   Reply With Quote
Old 23rd March 2005, 09:53   #9 (permalink)
Vulken Auto's Avatar
Wink
If in US I might buy a second hand new year rather than old because they will be good to look at and you get extended warranties , so PEACE of mind.
But in india, First of all I will buy second hand if I have to do some crazy things to it, like souped ride. But for regular use no second hand, since I trust only first hand; if I cant afford it I will walk on the road or take a cab.
So india means I NO SECONDS RIDE unless I want to waste some doe.....................
__________________
One of the things we know is, It's not how stand by your car, its how you race your car.
--Jarule
Vulken Auto is offline   Reply With Quote
Old 23rd March 2005, 11:39   #10 (permalink)
Twice, I have gone looking for second hand but bought new - I keep an open mind though, there should be someone like us out there with a lovingly maintained car willin to sell
Old 23rd March 2005, 13:33   #11 (permalink)
Lightbulb
hey people
thanx for the important information,ill keep all these things in mind before putting my hand on one.
hey vulken
even i never got a second hand car before. this time im looking for it coz im gonna do some mods to it so first im looking out for a used one but if i dont find any good car then ill go for the brand new one.
PF
Thread Tools
24000 Kms, 2 years in my SX4 sumitmitra Long-Term Ownership Reviews 5 10th November 2009 10:32
Accent 1.6 P GLS - 75000 kms 5.5 years Highway Star Long-Term Ownership Reviews 12 5th November 2009 12:59
7 years, 1 faithful bike, more than 90,000 kms and still going... Sabareesh Motorbikes 33 26th November 2008 15:39
Baleno - 35K kms(in 2 1/2 years) madhukar_n Long-Term Ownership Reviews 3 11th January 2008 16:31
4 years and 50,000 Kms. She's just born. devarshi84 Long-Term Ownership Reviews 9 18th September 2007 00:05
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
