Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 11th November 2008, 17:54   #1
Shyamtanu's Avatar
Default Indigo rear wheels tend to sag ?
This is an observation that has been bothering me, one in every 3 indigo I have seen on road, and may be 2 in every 3 indica I have seen on road, the rear wheels look like they are bending outwards... as if the axle has got a sagging. Has anyone noticed it? First i thought it is due to independent suspension... but then indica does not have it, and this should not happen at the first place it will lead to uneven wear and tear of the tyres and even the bearings in the long run. Any inputs please?
Shyamtanu is offline   Reply With Quote
Old 11th November 2008, 18:32   #2
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Take a picture next time you see one. It'll be easier for all to understand.
Tejas@perioimpl is offline   Reply With Quote
Old 11th November 2008, 18:43   #3
Shyamtanu's Avatar
I am in Uk at the moment, so it will not be possible right now.. but trying to explain... if you see from behind, the wheel top seems to bend inwards slightly and the lower part protrudes out... may be alignment issue, but it has been too frequent to ignore, hence checking out why... is it because the car is too heavy for its suspensions?
Old 11th November 2008, 18:43   #4
greenhorn's Avatar
Thanked: 1,518 Times
http://www.team-bhp.com/forum/intern...tml#post208283 (Indica DICOR)
an unfortunate combination of Independent rear suspension, no maintenance and overloading
Old 11th November 2008, 19:48   #5
Shyamtanu's Avatar
Thanks for pointing to the thread, however, does anyone know if this issue is going to be rectified/being taken up with TATA in the next version of Indigo... I personally feel they should launch stop using the Indica and Indigo names, and launch brand new names.. e.g. the VISTA could be given a new name other than Indica.. the name is just too old now, like the Amby
Old 11th November 2008, 20:54   #6
greenhorn's Avatar
the new indica vista uses a more conventional rear suspension, so this issue should not arise
Old 11th November 2008, 22:19   #7
aaggoswami's Avatar
Thanked: 1,542 Times
This is because of MacPherson strut Independent rear suspension.
When the car is overloaded most of the time plus not maintained properly, this problem of camber angle occurs.
The first generation Indica has got independent suspension all round.
Moreover this problem is also seen in Baleno if 10kg CNG storing capacity cylinder is fitted in the boot.
So this is because of strut suspension. So citing this reason that Indica has problem with camber angle ( because most of the Indica taxis are not maintained proprely ), in Vista they have sorted the issue ( as per TATA ) by giving it a torsion beam/twist beam ( very less difference between the two ).
aaggoswami is offline   Reply With Quote
Old 12th November 2008, 01:41   #8
Mpower's Avatar
Thanked: 1,687 Times
Indigo and Indica have completely different rear suspension
Old 12th November 2008, 06:37   #9
greenhorn's Avatar
but both have independent rear suspension
only the indica lacks the anti roll bar
Old 12th November 2008, 08:13   #10
phamilyman's Avatar
Thanked: 3,526 Times
^ due to the limited overhang
Old 12th November 2008, 17:51   #11
Shyamtanu's Avatar
That said, Indigo definitely has got the best suspension in its class, how many will give you anti roll bar in both front and rear suspension setup in a C segment car? Only if they gave a tie rod in the back it would have sorted the issue it seems? BTW, is Torsion Beam better than independent one ? I guess it is not? Also, how can one rectify camber angle error... is it a costly affair?
Old 12th November 2008, 18:05   #12
vikram_d's Avatar
Thanked: 940 Times
If it is fully independent system then just aligning the rear wheels will solve the camber problems. It is similar to aligning the front wheels. My esteem used to 4 wheel aligning as opposed to my swift which was 2 wheel aligning. So it will not be a costly affair.
Old 12th November 2008, 18:35   #13
sridhga's Avatar
Thanked: 13 Times
Heard that Marina's suspension is an improvement over Indigo. Is it because of the gas filled dampers? Anyone please confirm.
sridhga is offline   Reply With Quote
Old 14th November 2008, 05:25   #14
Mpower's Avatar
Hmm...that's like saying they both have 4 wheels! The Indica is a pure trailing arm whereas the Indigo is a tri-link strut. There is no camber gain with the trailing arm.
Old 14th November 2008, 06:05   #15
kuttapan's Avatar
Thanked: 12 Times
Indigo - Independent, 3-link, McPherson strut, with anti-roll bar and gas filled dampers
Indica - Independent, Semi trailing arm with coil spring mounted on hydraulic shock absorbers
WHen McPherson struts are used at the rear, they are usually called Chapman struts. See Wikipedia.
@Vikram - When you align front wheels, usually, you only change the toe settings. How do you change the camber settings for a MacPherson strut type suspension? Could you explain?
kuttapan is offline   Reply With Quote
Figo TDCi EXi vs Indigo CS LX TDi. Update: Its the Indigo. vivekgk What Car? 32 22nd November 2010 21:59
Renault Logan 1.4 with CNG or Indigo LS (diesel) EDIT: Bought Indigo! panky12345 Sedans 28 29th February 2008 14:18
Indigo LX or Indigo Marina LX windsurfer Sedans 10 23rd January 2007 14:03
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
