Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 1st June 2009, 14:58   #16
greenhorn's Avatar
Thanked: 1,516 Times
I thought it was fairly obvious. By indica, most people mean the older one. The newer one is referred to as the vista, to avoid confusion. Sorry if you misunderstood
The vista is generally considered the 2nd generation indica, and the older ones are all first generation. The differences between the others are trivial to call them new generations. Versions ? maybe.
If you want to be a stickler for versions, one should consider all the engine versions and bodystyles ( 1.4 carb, 1.4 mpfi, 1.2mpfi, 1.4mpfi DOHC petrols, 1.4 NA,1.4 TC, 1.4TCIC, 1.4dicor among the engines, the v1 and the v2 in the first ('98-2004) body style , then the '04-'06 look body style, the '07 onwards look for the indica's alone).
I'm comparing the indigo CS TDI with my '07 Indica DLG. Engine wise , ( and before the recent face lift) appearance wise they are quite similar
I think its the regular indigo which will be ramped down, not the CS. The vista sedan will be occupying the current indigo's price point. The CS competes with the vista hatch
Key decision points for Audi A4 versus Mercedes C220 versus BMW 320D ashishkashyap Luxury, Imports & Niche 40 30th April 2017 19:35
Ikon TDCI discontinued ? EDIT: Confirmed: Ford stops Ikon production greatmana2000 The Indian Car Scene 61 10th February 2011 19:20
Ford Ikon TDCi versus Figo quakerme Hatchbacks 28 11th January 2011 10:44
Figo TDCi EXi vs Indigo CS LX TDi. Update: Its the Indigo. vivekgk What Car? 32 22nd November 2010 21:59
Hyundai Accent Executive versus New Ford Ikon luvjascha Sedans 64 7th March 2009 17:21
