| LinkBack | Thread Tools | Search this Thread |
| | #16 |
| Senior - BHPian Join Date: Mar 2005 Location: N.A
Thanked: 237 Times
| Out of interest - is the original carb on the Conti 1.8 Isuzu (the one BEFORE FE-dictated lower power ratings) a Mikuni or a Hitachi? I have 2 carbs with me, one Mikuni and one Hitachi - which one is better for power delivery? |
| | #17 |
| BHPian Join Date: Sep 2008 Location: Bangalore
| Hi steeroid, As a thumb rule the glass window type nikki carb is better for performance since the venturi size is bigger.Also you can overhaul the carb and over size the jets for added performance. All this is without opening the head or pistons. Mikuni type is the maruthi type and is usually for better milage.Adjust the air screw in idle to a rough knock for performance in the glass carb and a smooth idle for milage simple settings. If your not confident of your carb my advice is not to filddle with the settings. |
| | #18 |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
Thanked: 804 Times
| use Hitachi they will give you better performance. Do a thorough clean up/overhaul before you install. |
| | #19 | |
| Dear Shekaran, Quote:
sure ..thanks a ton fr all your queries and will pitch in whenever possible to help. Last edited by Jaggu : 15th September 2008 at 16:14. Reason: Readability, please refrain from quoting very big post for a small reply | |
| | #20 |
| BHPian | Dear Mike, After all the cleaning, checking of my contessa, i have landed into a small problem. the car wobbles, the whole body wobbles, as though the tyres are not balanced. i checked the tyres balancing, and also the wheel alignment, but could not rectify the problem. i find that the vibrations stop only after 70 kmph speeds. from idle, till 10 kmph, i have no vibrations. after 10 kmph, the wobbling starts to make effect ... i am confused - about what to do ? i have some doubts, please clarify ... 1. will the tyres, or wheel rims can make such vibrations ? 2. do i need to check the rear propeller shaft ? 3. do the wheel rims make any such wobblings ? acc to the wheel alignment center, the alignment is spot on. the wheels are also balanced, but he says that some or one of the tyres could be the culprit. please advise. lastly, what is the standard tyres for the contessa ? 175-70R15 size ? will 185-70R15 make any speedometer reading errors ? thanks for all your advices. regards. |
| | #21 | |
| Hi KS.. I have responded to your other PM in detail.. Check the disk trueness. A bend could mean the wobble. Also check for proper tyre seating. Use some soap solution on the seating edge of the tyre while fitting the tyres so that they snap with a thud into the disk. Check all the wheels bearing play. reg mike Quote:
| | #22 |
| BHPian Join Date: Feb 2007 Location: delhi
Thanked: 50 Times
| I have a neighbor who's had his ride completely modified, it barely looks a contessa anymore, would you guys like some pictures ?(please pm me if u do want the pics to be put up) cheers. Last edited by sukrit7 : 10th November 2008 at 14:23. |
| | #23 |
| Team-BHP Support ![]() | |
| | #24 | |
| Newbie Join Date: Sep 2008 Location: Bangalore
| Quote:
it will have be trued on a lathe or something. i'd suggest getting a new one, as the dudes at the workshop can never get it as straight as an original... | |
| | #25 | |
| Quote:
Most contis will have this propeller shaft problem....it is the weak link in the transmission.If the thug..thug..thug noise is not big and bothering leave it. If the sound is bigger and bad it results in a catastrophic results.To start with ensure you bolt a U clamp below the longer piece of shaft just in case the star gives way and you have a dangling shaft. By the way it is a 4 piece shaft with a rubber flinger centre bearing and 3 universal joints. 1.The Clutch end slides into the gear box main shaft and has a felt seal for greasing. There is a Universal joint immediately and connects to the main shaft.So piece one identified you can replace this and check for the same problem. 2.Main shaft..check and look for balancing metal pieces on the shaft body if worn out missing or damaged and could cause all the effects of a unbalanced rotating mass. Check for truth..you could use a wheel alignment machine a laser guided one from tip to two on a fixed Jig to check for any warpage or bends (from the torque and from pitch) 3.Check the centre bearing and also the Univsal joint immediately and look for the wobble.If you place the shaft vertically and rotate the centre bearing it should ideally run without a wobble..if the bearing is well seated,however there could be a slight degree from the unproper moulding of the rubber flinger. 4.Main shaft differential end with one more joint on the end.Do the above checks and refit the shaft. The problem persists it could do some bit of a damage to the the gearbox main shaft and the oil seals at the end and the differential bearing and oilseal due to the wobble. Putting the shaft in a hydraulic press and straightening is a bad practise because it will not do any good and only worsen the condition unless done with some precision equipment and guages.The vertical load on the shaft will cause shear fractures compared to the tourque loading the shaft is actually designed to take.SO if any of the above checks dont work find a salvage shaft from an old conti and replace to see if ot works..many a times the rear axle or the engine-gearbox misalignmebt could also cause a shift in the alignment of the drivetrain and cause unnecessary NHV and such wobbling. Again checkall the links from the engine mounting to the rear suspension to rectify the problem. Do write again if you need any additional help or support. | |
| | #26 | |
| Quote:
out of my experience, i've realised that mostly the rubber gives problem. i have had about 7 contessas till now, out of which 2 have had a rubber problem; amongst those two one had a driveshaft bent during repairs due to a negligent mechanic. rest all did just fine.... | |
| | #27 | |
| Quote:
Kudos... Mike | |
| | #28 |
| Thanks Mike.... You seem to knows things in good detail, which makes reading your posts a pleasure. btw, do you also have a contessa? as of now, i have 2... the previous ones were company cars which came and went. these two are my personal contessas. |
| | #29 |
| BHPian | with JD and Miyer, i am rest assured that my contessa can live longer. thanks to you, both friends. i am in the process of ironing out all my problems, and will post an update soon. cheers. |
| | #30 | |
| Quote:
Similar Threads | ||||
| Advice needed on buying Chevy Beat | RacingHart | Hatchbacks | 27 | 3rd May 2011 13:42 |
| Advice needed on buying a Skoda VRS | sucka | Sedans | 4 | 23rd May 2010 23:06 |
| Advice needed on buying Ikon | syedhafeez | Sedans | 35 | 22nd May 2010 18:44 |
