Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 17th January 2010, 03:16   #46
Ram_NP's Avatar
Thanked: 21 Times
Congratulations on your new purchase.
The colour looks great. Hope you start a new ownership thread and share your initial driving experience.
Ram_NP is offline   Reply With Quote
Old 17th January 2010, 06:01   #47
tacho's Avatar
Originally Posted by irdevanand View Post
I know you've already made the purchase but help me understand this table.
How did you arrive at the return after x years value? Let me consider the Swift in your example. You initially saved 352,000 Rs and after 4 years, you got a return of 478,000? So, the 352,000 became 352,000 + 478000 = 830,000? That's some interest rate.
Or did you end up with a total of 478,000 after 4 years which includes the 352,000 (interest = 126,000). If this is the case, the calculations at the bottom are wrong. You don't end up with 673,000 more if you bought the Swift instead of the City
tacho is offline   Reply With Quote
Old 17th January 2010, 12:15   #48
khoj's Avatar
Thanked: 1,258 Times
Originally Posted by Guna View Post
I wonder why the ABS light is on in the picture. It (along with fe other signs) should come and go when you put the ignition to the 'On' position.
ABS Light: I need to check with the Sundaram Honda. Will do so in my first service on monday.
There is nothing wrong with the ABS light being on when the hand brake is engaged since the indicator is common to both. This must be the case when you clicked the pictures.
It is the airbag/SRS light (if car is equipped with airbags) which will come on when you turn the key. It will flash a few times and then go off. It is then that one should crank the engine - ideal case scenario.
Old 17th January 2010, 12:19   #49
Thanked: 544 Times
Of course ABS and handbrake signs are different. ABS sign appears and goes off and handbrake sign remains on till you relaese the handbrake.
Guna is offline   Reply With Quote
Old 18th January 2010, 10:59   #50
Delta Wing's Avatar
Thanked: 112 Times
Thanks for the USB clarification. One my acquaintances told me that his old iPod was not working on his car (iPod otherwise fine). A photo from the top maybe?
Delta Wing is offline   Reply With Quote
Old 19th January 2010, 12:51   #51
irdevanand's Avatar
Thanked: 26 Times
folks
the abs light was a display problem due to some wiring mis connect.
got the car from first service yesterday.
here are some pictures from the trip Picasa Web Albums - Dev - hondacity
ps - photo from top: i tried but it didn't come good ... will try again. sorry.
dev
irdevanand is offline   Reply With Quote
Nasikkar from heart...Mumbaikkar from the brain... Dieselritzer Introduce yourself 0 23rd July 2012 14:15
TakeThat: DipantS-BlueBeast-Aquarius-Fiesta1.6S DipantS Test-Drives & Initial Ownership Reports 17 26th July 2010 08:00
ANHC or Fiesta1.6S or SX4 aparth Sedans 94 6th June 2010 19:04
1.4 Fiesta EXI TDCi or Swift VDi EDIT - Booked Fiesta ZXi iamkapilb What Car? 28 6th March 2010 08:26
Aveo1.4/Fiesta1.4/Swift Diesel kvigneshbhasker Hatchbacks 21 8th March 2007 22:33
