Go Back   Team-BHP > BHP India > What Car? > Sedans
Old 15th November 2005, 10:55   #1
Default Used Baleno Help
Gurus,
I have never had a Baleno before, so a question for existing Baleno owners.
I am in process of buying a certified used Baleno VXi Oct 2003 23k KM in excellent condition. Everything is great except that I am finding that when I go to the 5th gear, it seems a little hard than the other gears. Is it normal or expected functionality or something is seriously wrong?
Thanks a lot in advance for your help.
sunmoon104 is offline   Reply With Quote
Old 15th November 2005, 11:03   #2
khaadu75's Avatar
Thanked: 11 Times
Hey, How much u shelling out for this car ? Even I'm looking for a used Baleno here in Delhi but there arn't too many out there in the second hand market.
cheers
khaadu75 is offline   Reply With Quote
Old 15th November 2005, 11:10   #3
msprabhakar's Avatar
Thanked: 73 Times
Originally Posted by sunmoon104
...when I go to the 5th gear, it seems a little hard than the other gears. Is it normal or expected functionality or something is seriously wrong?
Welcome (soon) to Big-B club! I found the 1st and reverse a bit stiff at start, but have started getting smooth now. Probably the previous owner didn't do the highway much. Why don't you check with the Maruti guys? Congrats, anyway, on your wise choice!
msprabhakar is offline   Reply With Quote
Old 15th November 2005, 11:16   #4
zenx's Avatar
Thanked: 75 Times
how much are good used Alturas - 2002/3 ?
zenx is offline   Reply With Quote
Old 15th November 2005, 13:32   #5
Smile
Msprabhakar,
Thanks for your update.
Anybody else with an update?
Khaadu75,
They are telling 4.3L but mostly will be able to get it at 4L. Will keep updated.
zenx,
There is one exactly same Altura as well. I will ask them and get back to you on price.
Old 15th November 2005, 14:45   #6
Dude try to close it quickly for arround 4l, used baleno deals are hard to come by that too a Vxi. Close the deal else it will vanish quickly..
solly is offline   Reply With Quote
Old 15th November 2005, 15:00   #7
I wouldn't call the 5th gear hard. It's just a little notchy. You sometimes don't get that feeling that the gear has been solidly engaged.
Having said that this problem gets better with time. For ex: in my car with 5000+ on the ODO it's noticeably better. The reverse gear prob is a standard for all Maruti's. But there is also a easy workaround for that.
Just check with any other Baleno before ure decision(to be sure that the model ure looking at does not have the gearbox screwed).The gear shifts should be roughly similar.
A Baleno Vxi -23K old only is a great buy IMO.
Good luck deciding.
imjimmy is offline   Reply With Quote
Old 15th November 2005, 15:17   #8
Thanked: 157 Times
GEarshifts are hard in Baleno...anyone who has driven other cars will vouch...and yes..the fifth can ba a pain to engage sometime....just ask for a test drive of a new car as well to dispel any doubts you have
Buffetfan is offline   Reply With Quote
Old 15th November 2005, 15:41   #9
Thanks guys.
zenx,
2003 Altura they said you can get around 4.5L.
Old 16th November 2005, 04:02   #10
Thanked: 44 Times
Gurus,
I have a Vxi for the last month. Yes the 5th gear does not fall in place easily, Have complained at the time of first service, but the dealers brushed it aside as a minor thing, and I was too busy to press on with this issue.
It is not a big problem. The car is great, go for it.
filcord is offline   Reply With Quote
Old 17th April 2006, 13:12   #11
triggercool's Avatar
Hi guys I am getting Lxi 2004 in good condition with 14000k on clock for 3.7L hows the deal.
Thanks in advance
triggercool is offline   Reply With Quote
Old 17th July 2006, 14:41   #12
rahulya007's Avatar
Thanked: 35 Times
Hi All...I am looking for a Baleno and have seen on e here in Mumbai..Its a 2000 model, company owned and dome some 35K kms. The dealer is offeing at 2.5L but I have heard that a 2000 model should cost somewhere aaround 1.9L -2.05L..
Pls. suggest since I am selling my Exteem Vx 1999 model with LPG for 1.6L and going for a Baleno..
Would that be a wise decision..Pls. suggest..
Thanks in advance..
rahulya007 is offline   Reply With Quote
Old 17th July 2006, 14:54   #13
Thanks in advance..
Hi Rahul,
A 2000 model having done ONLY 35k is a suspect.. but you will ofcourse get it checked from a maruti authorized person... the right price would be around 2.25... depends on the accessories and how much you can negotiate.. and yes--- though you have not asked- the baleno runs beautifully on LPG!
Cheers,
Samrat
Samrat Banerjee is offline   Reply With Quote
Old 17th July 2006, 16:14   #14
s.prashanth's Avatar
Thanked: 60 Times
The throw for the 5 Gear is long, so it seems difficult, its not a problem
s.prashanth is offline   Reply With Quote
Old 17th July 2006, 16:23   #15
freakyrahul's Avatar
Post
Gurus,
hey sunmoon.look for the gear oil leakage.it might help .LOOKS like the car must have been taken for a lot of offroading in the top gear.It may have damaged the gear shift pattern. the problem is serious and if you r not able to switch gears smoothly in case of emergency then it could result in an eventuality.Drive safe.Take care.
freakyrahul is offline   Reply With Quote
used Accent (petrol) or used Baleno (budget 3 lacs) gopz Sedans 33 5th September 2007 11:34
Baleno BS-III to Baleno BS-II BlackBull Technical Stuff 0 22nd September 2006 21:50
