Go Back   Team-BHP > Around the Corner > Shifting gears
Old 20th May 2015, 12:32   #241
DieselFan's Avatar
Thanked: 233 Times
Default Re: Home Construction/Makeover/Maintenance Thread
I am looking for a submersible water pump and a booster water pump. Any suggestion on which brand of the pumps available in india are reliable and have good service network and value for the money you pay. Appreciate your response.
DieselFan is offline   Reply With Quote
Old 20th May 2015, 13:48   #242
NPV
NPV's Avatar
Thanked: 4,877 Times
Submersible water pumps - Suguna is good and VFM. I have also heard Grundfos is good but quite expensive. Not sure about the service network.
If I remember correctly, Grundfos also has booster water pumps.
NPV is offline   Reply With Quote
Old 20th May 2015, 15:04   #243
drsingh's Avatar
Thanked: 468 Times
I have some leaky water supply plumbing at my native place. The house has been remodelled twice and there are no "blueprints"
I've decided to replace the entire plumbing with PVC.I need inputs from experienced members:
1.Do I have to paint the sun exposed PVC before installation.
2.Benefits drawbacks of using Threaded/solvent based joints.
3.Do I need to buy special Taps/faucets?
4.Are they totally leakproof?
5.What is the best option for plumbing/water supply in terms of materials?
drsingh is offline   Reply With Quote
Old 20th May 2015, 15:25   #244
DieselFan's Avatar
Thanked: 233 Times
1. No painting needed to PVC.
2. joints are longlasting and can take high pressure water. only disadvantage I can think of is you need to cut the pipe if you want to reroute or change and the joint would have to be replaced.
3. no, same taps /faucets will work.
4. yes they are supposed to handle higher pressure and are more durable than GI pipes.
5. Not sure on what you meant in the question.
Old 20th May 2015, 16:37   #245
JMaruru's Avatar
Thanked: 103 Times
Question Re: Window Mesh?
We have this situation, where in a rat is entering through a first floor window every nite and causing havoc. We can NOT keep the window closed due to TV cable routing. As there is a function coming up, there are lots of materials stored inside the house.
Any suggestions/solutions for temporarily closing the window?
JMaruru is offline   Reply With Quote
Old 20th May 2015, 17:05   #246
diyguy's Avatar
Thanked: 124 Times
Default Re: Window Mesh?
Close the window as much as possible and tape the remaining gap with thick transparent or brown packing tape. Rats are dangerous in terms of disease spread and if you have kids in the house, you should be drilling into the window frame and getting the cable in through that, at your earliest convenience...
diyguy is online now   Reply With Quote
Old 20th May 2015, 17:06   #247
drsingh's Avatar
Thanked: 468 Times
cut an opening for TV cable and seal it with silicone caulking or m seal.
or board up with thick cardboard/thin plyboard if you want to seal off the window.
Old 20th May 2015, 19:21   #248
hellmet's Avatar
Thanked: 637 Times
Anyone here who can help design a small green home in Vijayawada (outskirts)? We want something more than a box - something more elegant.
The dream/plan is to leave as much land vacant as possible for plants/trees(even OK to raise the house off the ground). Construction would be very basic (but best quality possible) and might include weird items such as external plumbing and electrical wiring, colored cement flooring for low maintenance.
The problem is that we already have a 20+ year old house on the plot (260sqyd) which is sinking ever so slightly into the ground every year. Can this be saved? If not, we're ok to re-construct.
hellmet is offline   Reply With Quote
Old 20th May 2015, 20:05   #249
Thanked: 454 Times
Drill a hole in the wall by the side of the window and route the cable from the hole.
Also, get a wire mesh fitted on the window. This will allow you to keep the window open for ventilation.
Rahul Bhalgat is offline   Reply With Quote
Old 20th May 2015, 20:11   #250
Thanked: 454 Times
I think you will get creative architect in Hyderabad. I can also get you one from Pune, if you need. PM me for details.
It is possible to save the present house from sinking, if you are otherwise ok with this. This is related to the soil quality and existing foundation. After studying this, proper technique can be suggested to stop the sinking. BTW, how much does it sink every year? Does the most of the sinking happen in mansoon?
Old 20th May 2015, 20:21   #251
Thanked: 33 Times
I have been using KSB pumps for the last 10 years. KSB is a German company listed in the stock market and operating in India for many years. Their products have outstanding quality and their distributor in Bangalore, Durga Traders, provides quick and impeccable service.
Out of the 2 borewell pumps, I replaced one in an exchange offer. The third is a submersible pump that I bought a few years ago.
When I initially went looking for a borewell pump at NR Road some 10 years ago, there were many local brands but all of them required 2HP whereas with KSB I could make do with a 1HP pump. Back then, I was advised not to go with a local brand as they require frequent servicing and heaving a pump out of a borewell is not something one wants to do everyday. Of course that was 10 years ago and I am not sure how much has changed by now.
PM me if you need contact information.
nowwhat? is offline   Reply With Quote
Old 21st May 2015, 09:48   #252
cooldude1988765's Avatar
Thanked: 106 Times
Can connect you to many architects in Hyderabad.
However I recommend Mr. Jagan Mohan. He specializes in projects witha lot of open space.
Here is a link to an article in inside outside. http://www.insideoutside.in/inside-o...ns-jagan-mohan
Let me know if you would like to meet him. I can make sure you are attended to properly.
He is currently engaged in a project with the TS government in Yadigiri Gutta spread over a few thousands of acres.
Something like the attached image would be beautiful IMO.
cooldude1988765 is offline   Reply With Quote
Old 21st May 2015, 10:18   #253
Thanked: 116 Times
Infractions: 0/1 (4)
If you travel abroad, buy trailer homes, used ones go for a song, sorry if reply is way off, .
But Indian Weather pattern can be a challenge.
ritz3645 is offline   Reply With Quote
Old 22nd May 2015, 11:34   #254
::CMS::'s Avatar
Thanked: 464 Times
Originally Posted by fine69 View Post
While I could spend more money and get the modular cabinets but I'm not going to use them in our new home.
If possible, please post a couple of pics of the shelves and the room.
As everyone suggested, modular cabinets will be a good choice. Since you wont be using it in your new home, you can reduce the cost and effort by just covering the shelves using the cabinet and using the shelves as inner partitions so that everything will be hidden. The shelf measurements will also help esp depth and thickness to reduce the wall damage for fixing the cabinet.
::CMS:: is offline   Reply With Quote
Old 24th May 2015, 17:19   #255
TorqueyTechie's Avatar
Thanked: 1,061 Times
I am right now big time in trying to maintain our home and cleaning up stuff. I need to set right or organize some of the basic stuffs like mails, cd's, keys which keeps lying around.
Does anybody know of a good place in bangalore for buying a quality letter and key holder. Also a CD organizer which can fit inside a cabinet below TV. I checked in the usual online shops but none of the ones shown interest me.
I am looking something trendy like the one in the link below.
http://www.notonthehighstreet.com/th...and-key-holder
TorqueyTechie is offline   Reply With Quote
"At Home" Maintenance, Repairs, Accessories etc. - WagenWerkz (Mumbai) cityvic Mumbai 46 4th December 2017 21:57
Taking up Home Makeover Project RVG Shifting gears 99 22nd November 2010 16:04
Home electronics makeover cooldude1988765 Gadgets, Computers & Software 4 2nd June 2006 11:35
Fiat India website is back.Currently under construction. merve_extreme The Indian Car Scene 60 5th May 2006 11:36
