Go Back   Team-BHP > Around the Corner > Shifting gears
Old 6th May 2011, 14:24   #16
G-BoleroBoy's Avatar
Default Re: Home Construction/Makeover/Maintenance Thread
Originally Posted by black12rr View Post
Boleroboy , these can be used only in Non-load bearing walls only.So you are using RCC pillars and beams to support the structure ?
I think you are right. I am doing a RCC Pillars and beams based structure.
G-BoleroBoy is offline   Reply With Quote
Old 6th May 2011, 16:22   #17
A M
A M's Avatar
Thanked: 193 Times
The costs i mentioned were for construction of just the ground floor with basic amenities i.e. civil construction, marble flooring, and basic bath fittings. If you go overboard and spend on a modular kitchen, Italian marble or luxury bath fittings, there's no limit. Also my estimate does not include any wood work except the doors and windows.
A M is online now   Reply With Quote
Old 6th May 2011, 22:13   #18
Thanked: 145 Times
I am looking at laying concrete blocks (or whatever) in the car parking area. It is approx 500 sq. ft, and approx. square. Reason I am asking is that while most concrete blocks look fantastic and tantalising when newly laid; couple of years later, they look just so and so; with algae build up etc.
The trick seems to lie in the surface finishing. Any idea about what is available?
I do not want a full concrete layer with tiles on top - apart from costs, it does not allow water to seep through. What I have in mind is the kind of blocks which you simply lay over tightly packed sand / gravel / granite dust / granite "baby" metal.
For those looking at constructing houses - Costs is approx 0.75 to 0.9 K per square feet in KL for super structure alone - up to plastering stage. Once plastering is done, painting; tiling, shuttering, doors and window works, flooring etc. come in.
For example, you get floor tiles for as little as ₹ 11/- per sq. ft. to ₹ 300/- per sq. ft. tiles. You get taps for as little as ₹ 25/- for plastic taps to exotic brands costing upwards of ₹ 2500/-.
So, expect a "bare-bones" house at approx ₹ 950/- per sq. feet; and you are free to spend anything higher.
Old 8th May 2011, 15:48   #19
Thanked: 111 Times
In my opinion, this construction business is one area where you will always get cheated, no matter what precaution you take. The last heard prices in Bangalore for constructing ground floor building is between 1.1L to 1.4L for 1 square (i.e., 10x10 or 100sft) including everything from a contractor as one of my friend is contemplating the the options of his construction.
What is being said is
- you save upto 30% if you just give the labor contract and source the material yourself
- Only problem would be with the sand which you have to buy - where you are not sure of the quality & quantity.
- All other material can be sourced easily
- pain of co-ordinating with the various teams, civil work, plumber, flooring, electrical etc
- you can force them to what you exactly want, unlike an outsourced activity
- joy of you built your house
Working with these laborers is a real pain. They just disappear one day and work just stops. This is irrespective of whether you give a contract (less likely as you have someone to grab the neck) or you are getting it done on your own.
Entire industry works on commission with no respect what so ever to quality & timeliness. Even if you are willing to pay more, you get cheated here. This is what I experienced when we built our house about an year back.
null is offline   Reply With Quote
Old 12th May 2011, 10:58   #20
abn
abn's Avatar
I am planning to construct a new house in kerala,(cochin) .
Pls share the construction cost, bulding material used, labour contract charges and other spesific things whoever having a recent experience.
abn is offline   Reply With Quote
Old 29th August 2011, 17:18   #21
Latheesh's Avatar
Thanked: 2,841 Times
I am in the market for following items
Door locks: I am not looking for expensive electronic ones but solid mechanical locks. Went to Home Town at Marathahalli and checked few Godrej ones. They have very few collection and did not like any of those. I find their prices are inflated. Who is the best lock dealer in Bangalore?
Sanitary ware: Checked CERA, Hindware, Roca - I am not an expert but did a casual check. Which one is best reliable VFM brand?
Bathroom fittings: Again I am looking for reliable VFM - I do not know any other brand other than Jaguar.
Paint: Asian Paints - Emersion, Apex or Apex Ultima - Which one to go for? or any other brand?
(House is in Kerala-Kannur :- Summer temp (30-35 degree - humid) Monsoon - Heavy rainfall for few months)
Car porch and lawn - I am thinking of interlock floor tiles - What are the adv and dis adv of this? How expensive is this?. I need to do around 400-500sqft area. Or should I go for Chequered Tiles?
Latheesh is online now   Reply With Quote
Old 29th August 2011, 18:12   #22
bluevolt's Avatar
Thanked: 2,331 Times
Which one is better - floor tiles or katni marbles?
bluevolt is offline   Reply With Quote
Old 10th November 2011, 15:39   #23
Latheesh's Avatar
Door locks - Bought Godrej door locks, simple and reliable.
Sanitary ware - Got Parryware and RAK
Bathroom fittings - Was looking at Jaquar range but finally settled for mix of brands. Selected from Grohe, Johnson, Benleve and Parryware based on the location and usage.
Old 10th November 2011, 23:06   #24
A.R
A.R's Avatar
I have a query for my apartment complex @ Bangalore. We are in the process of figuring out the annual maintainance work to be done in our complex. In summary:
- Its a 24 flat, 4 floors, 6 flats per floor apartment complex
- Land area should be 150 by 200 feet
- Basement is concreted. Surrounding the basement - driveways i.e, from the pillar end to the compound wall has cement tiles laid on flattened sand/jelly mixture
Work to be done includes:
- Remove the cement tiles are concrete the area - this is because the tiles seep in and look odd over a period of time.
- Painting of exteriors of apartment complex along with common area walls (stairs, basement, corridors, ducts etc)
- Rain water harvesting - pipes laid from roof to basement; separate tank exists; filters to be installed and connected to tank
- Floor tiles in basement and corridors - replace/polish
I know I'll need to outsource each work to a contractor. Suggestions are welcome.
A.R is offline   Reply With Quote
Old 17th November 2011, 14:57   #25
SDP
SDP's Avatar
Thanked: 7,725 Times
I am based out of Mumbai. Planning to get the flooring changed in my flat with 2x2 vitrified tiles. Have got a quotation of 250Rs per sq ft inclusive of all material+labour (including breakage, disposal). The 250Rs per sq ft includes 50Rs per sq ft for 2x2 vitrified tiles.
My doubts:
1. Is the 250Rs rate reasonable?
2. What brand of vitrified tiles can I get for around 50 Rs per sq feet?
Experts and people who have recently remodelled their home, please advise.
SDP is offline   Reply With Quote
Old 17th November 2011, 15:06   #26
Latheesh's Avatar
I think 50 is too less for a good quality vitrified tile, I may be wrong.
You need to spend atleast 60 to get a good quality. There are many brands available; I found Johnson, Asian tiles and RAK very good. You may also check Kajaria and Somany.
Old 17th November 2011, 15:47   #27
coolclouds's Avatar
Thanked: 514 Times
My doubts:
I am not an expert but think the rate quoted is on the higher side. Labour expenses alone should be Rs. 10-15/sq.ft and remaining on material. You can easily get the work done using paste and without much material as the surface is already there.
Please ensure that you buy good quality tiles as the joints will not be proper in 2nd and 3rd quality tiles even for good brands.
BTW, I am looking for a 30X40 house plan in Bangalore (Panchayat area). Any suggestions on Bangalore architects?
coolclouds is offline   Reply With Quote
Old 17th November 2011, 21:27   #28
Thanked: 145 Times
Dude, for 250 INR per sq feet, you ougth to be able to get very high quality marble.
While dealing with flooring, please differentiate between rates per square feet (or unit area) and rates per tile. This can get very confusing. For some brands / price pointy, they quote price per tile; and for others, they quote per unit area.
"material" for fixing tiles is simple paste, and should not cost more than 1K per 1000 or 500 sq. feet. You may need gravel / sand and cement depending levelling of the the surface. And may be, A day's labour per 250 sq. feet. This should be inclusive of cutting for edges. My 15 x 15 feet bathroom took 6 mandays for flooring and 6 feet high tiling.
Old 13th December 2011, 14:21   #29
goandude's Avatar
Thanked: 453 Times
Hi all, I need some suggestions from members based in Bangalore for remodeling my flat in CV raman nagar. I need to get the following done:-
1. Bathrooms x 2 (40 sq ft each) : Tiling, change of fixtures and fittings, addition of glass shower enclosure
2. Woodwork: a large cupboard, writing table and one storage cabinet
3. Kitchen: few additions to the existing woodwork
Can anybody who has had similar work done in their apartment point me to a person who will undertake this work. Or how to go about locating a good contractor.
Also if someone has had something similar would appreciate the approx cost.
goandude is offline   Reply With Quote
Old 13th December 2011, 15:26   #30
rkg
Thanked: 543 Times
To get an approximate idea check ACC website
ACC Help - Calculators - Cost Calculator
rkg is offline   Reply With Quote
"At Home" Maintenance, Repairs, Accessories etc. - WagenWerkz (Mumbai) cityvic Mumbai 46 4th December 2017 21:57
Taking up Home Makeover Project RVG Shifting gears 99 22nd November 2010 16:04
Home electronics makeover cooldude1988765 Gadgets, Computers & Software 4 2nd June 2006 11:35
Fiat India website is back.Currently under construction. merve_extreme The Indian Car Scene 60 5th May 2006 11:36
