Go Back   Team-BHP > Around the Corner > Shifting gears
Old 28th May 2013, 11:02   #91
Thanked: 187 Times
Default Re: Home Construction/Makeover/Maintenance Thread
Planning to remove the badly damaged RCC roof of our house in kerala which is more than 35 years old and replace with Tiled sloping roof (typical old style Kerala ottu veedu).
This way we believe we will get attic / storage area in the space between the tiled roof and the ceiling. Have two queries though:
1. Instead of wooden rafters used earlier, can non-wooden rafters be fabricated on which the tiles are placed? What material can those rafters be?
2. In the olden days ceilings used to be of wood, which is not practical today. What material should be used for the ceiling (beneath the tilded roof) so that it is weight bearing and also prevent heat radiation from the roof on to the room(s) below?
WindRide is offline   Reply With Quote
Old 3rd June 2013, 10:23   #92
motomaverick's Avatar
Thanked: 864 Times
Originally Posted by coolclouds View Post
Have been to Jigani (Bangalore) today looking for some granite. The rates starting at Rs. 55-60 for Madurai stone and Rs. 70-90 for good quality designs. All are 20mm thick, 3'x10' size and above.
Surprised to see too many shops came up in the last two years! They are sending granite to neighboring states and the approximate cost would be about Rs. 20 per sq.ft
Thanks for the information. I was wondering which is the best place to go and buy wall as well as floor vitrified tiles? We are looking at value for money and not necessarily premium ones.
Old 3rd June 2013, 14:00   #93
coolclouds's Avatar
Thanked: 514 Times
I'm also on same boat. Looking for tiles and bathroom fittings. A guy in Avenue road (Laxmi Sanitary) offered 16.5% off on Parryware MRP whereas Chabria offered 25% off on Hindware MRP sometime back.
Please update this thread, if you find some good dealers.
coolclouds is offline   Reply With Quote
Old 4th June 2013, 09:34   #94
Thanked: 864 Times
Who is this Chabria? Sorry I don't know anyone in this industry But 25% off on Hindware is a pretty good deal. Where is he located?
How about the paints, acrylic emulsion paints are good or your normal distemper would suffice? The interior paint surface would be around 700 sqft.
Old 4th June 2013, 11:15   #95
stormerider's Avatar
Thanked: 489 Times
Dear Motomaverick
I would recommend acrylic emulsion, because of the smooth finish, durability and washability and all this at not too high a cost since the area in consideration is small. Cost with application starts at around Rs.15 per sq.ft. of application.
On the other hand distemper is the low cost option here, gives decent enough finish and hence the choice of cost conscious people or builders. You can get it done if you are sure your walls don't get stains. Cost with application starts around Rs.9-10 per sq.ft.
stormerider is offline   Reply With Quote
Old 4th June 2013, 11:42   #96
Thanked: 69 Times
We did a tile roofing to our house in Kerala, but keeping the original RCC roof as it is. Our problem was slight water leakage and heat in summer in the bedrooms in first floor. Instead of wood, they used iron pipes(rectange ones) of different sizes to place the tiles.
ArunV is offline   Reply With Quote
Old 4th June 2013, 12:08   #97
Thanked: 32 Times
If you have a RCC slab as roof, Do not remove it and just put a Metal roof or tile roof above it. This you can do it by fixing angle purlins above the slab. The present RCC slab/roof will be your false ceiling helping insulate the roof.
Kiran
kiren is offline   Reply With Quote
Old 4th June 2013, 12:17   #98
Thanked: 69 Times
Kiran
On thing to add, make sure the walls are strong enough to support the weight of the new structure. The tiles and the iron frame will be heavy.
Old 4th June 2013, 12:19   #99
Thanked: 864 Times
Originally Posted by stormerider View Post
Dear Motomaverick
Thanks, so 15/sq ft is the overall cost which includes preparing the wall for painting after the plastering has been done? Or is it just the paint. I guess the rates will be more for Bangalore.
I was looking at Dulux website and we found quite a few color options we loved. So in the end considering Vaastu and our choice (every time they don't go hand in hand ) we arrived at the following:
(Also shown below is the drawing for the house. The plan is to construct half right now due to emergency and half after 1.5 years.)
1. 1 color for the Kitchen & Dinning area (Sun Yellow) with B&W checkered tiles near the cooking area.
2. Light Pastel yellow shade for 2 walls in Kid bedroom & master bedroom.
3. The remaining 2 walls in the Kid room to get a green shade, that same color we were planning to use in the Bathroom
4. A warm shade of yellow in the remaining 2 walls of the master bedroom.
Do the above color scheme workout well, I know we would have to buy 4 color shades which will increase the cost.
Old 4th June 2013, 12:29   #100
Thanked: 32 Times
If its a very old structure with a RCC slab, the walls must be strong enough. Most of the old sturctures are over engineering design . Further, with 4/5mm angles as purlins and metal roof, the weight will increase by only max 15kgs/sqm. Please check. These is all assuming its an RCC roof.
Kiran
Old 4th June 2013, 12:31   #101
Guite's Avatar
Thanked: 182 Times
I will comment on something you have not asked. Where is the living room? Is it the 22' x 5' space? Maybe it is not shown here? Just curious.
Edit: My question is posed to motomaverick.
Guite is offline   Reply With Quote
Old 4th June 2013, 13:29   #102
Thanked: 489 Times
Assuming that its an old structure, walls will be sufficiently thick and strong and the compression load is nothing to worry about. As it is slabs and other structural components are designed with 'Factor of Safety' at multiple levels which helps in such scenarios, so I don't think its going to have any ill effect.
No idea about those rates in south India, but this is the rate we get the work done in rajasthan, U.P., Haryana, it starts around Rs. 18 in Delhi. Hope that helps.
Base preparation has two/three methods. First is Cement base wall putty, goes around Rs.3-4 per sq.ft.. Second is POP punning, depending upon the way of doing (with phatta, or in plumb) and also depending upon the undulation in plaster, this can start from Rs.8-9 per sq.ft. and can go on to Rs. 20 odd. The other methods of base preperations are not generally available in every area so wont comment.
As colours are concerned, would say that its a matter of choice. Would recommend that you ask the person to aplly small samples first which you guys can see and approve.
Old 4th June 2013, 14:26   #103
Thanked: 864 Times
Good question and my bad for not putting it in my initial post. There is no living room right now as this is only the half portion of the house we are constructing to move in from a rented house. We have a kid coming along and the current rented house is too small, plus going for a 2BHK rented house here in our area of Bangalore will cost not less than 15k, so it made sense for us to construct, 2 rooms, kitchen, dining, and bath and pay the bank <15k emi Slowly once more funds are there we will construct the rest.
If Delhi rates are close to 18 then I am sure in Bangalore it will cross 20, anyways, thanks for your inputs, the idea of asking the question on color choice was to get a semblance on aesthetics considering that you are into construction business.
Old 4th June 2013, 14:32   #104
Thanked: 489 Times
Good thought. A small suggestion on that front would be to increase the length of toilet to 8' approximately from 7', by reducing this 5' wide passage. Length of toilets is most important in terms of layout.
Old 4th June 2013, 14:49   #105
Thanked: 187 Times
^ Thanks to all for responding to my previous query.
Metal roof over existing RCC slab is ruled out due to the heat-generation factor. Terracotta tiles (mangalore tiles) is preferred.
Yes the walls are strong. IIRC, they are 9-inch width red brick structure.
"At Home" Maintenance, Repairs, Accessories etc. - WagenWerkz (Mumbai) cityvic Mumbai 46 4th December 2017 21:57
Taking up Home Makeover Project RVG Shifting gears 99 22nd November 2010 16:04
Home electronics makeover cooldude1988765 Gadgets, Computers & Software 4 2nd June 2006 11:35
Fiat India website is back.Currently under construction. merve_extreme The Indian Car Scene 60 5th May 2006 11:36
