Go Back   Team-BHP > Around the Corner > Shifting gears
Old 19th February 2015, 11:28   #76
Gansan's Avatar
Thanked: 914 Times
Default Re: Low Voltage Problem in Chennai
Originally Posted by carbhp View Post
I think they should install new transformer..
They already did, after taking some "baksheesh"!
Originally Posted by Gansan View Post
The transformer was replaced a few weeks ago, but the problem persists.
Originally Posted by diyguy View Post
I think the inverter does provide certain protection in low voltage scenarios as well.
It does, but if it kicks in and cuts off too many times, it will eat in to battery life. Moreover my two refirigerators and one TV are not connected to it.
Old 15th November 2015, 20:57   #77
Gansan's Avatar
Thanked: 914 Times
Guys, can someone suggest a good voltage stabilizer that can be connected to the mains for the whole home? For the past several months we are getting a very stable voltage of 250 V. Points that are connected show 230 V, but the others are 250. Even the digital meters they installed sometime ago confirm this. I am worried somthing or the other may get fried one of these days.
Barring the two Acs, I would like to connect everything - including the Luminous inverter - to it. Brand, cost suggestions are welcome.
Old 15th November 2015, 22:23   #78
Thanked: 4,149 Times
Get your Earth ( ground ) checked .
Turbanator is offline   Reply With Quote
Old 15th November 2015, 23:13   #79
Gansan's Avatar
Thanked: 914 Times
Earth can not be a problem for our entire complex and also the adjoining one.
Battery / Alternator / Voltage Regulator problem? babe_on_wheels Technical Stuff 109 10th June 2018 21:36
Capacitor? Need to stabilize voltage Ford Rocam Technical Stuff 38 7th May 2014 14:28
PS3 from US - do i need a voltage transformer?? jassi Gadgets, Computers & Software 85 15th January 2013 01:46
Low Voltage Woes in Coorg zenx Shifting gears 5 31st March 2010 12:31
Tata Indica alternator voltage query tsk1979 Technical Stuff 5 9th December 2006 12:45
