Go Back   Team-BHP > Around the Corner > Shifting gears
Old 13th June 2006, 10:18   #1
DCEite's Avatar
Thanked: 528 Times
Default mIRC .. help required
I need to download the XBMC via IRC. Its not available thorugh http/ftp/torrents.
This is the first time i am using mIRC. I havent changed any settings, but whatever server i want to connect to, i get this message:
Unable to connect to server (No Route to Host)
Please help!
DCEite is offline   Reply With Quote
Old 13th June 2006, 10:51   #2
aZa
aZa's Avatar
Thanked: 17 Times
dceite : Check ur firewall and make sure mIRC is getting through it. next go to mIRC options and check "LOCAL INFO" in this dialog put it ur IP / HOST and set the "Look up method" to "Normal".
Now setup ur Nick, username , email and also the Ident field (some server use ident based authentication).
if know your server then type /server <servername>:<port> press enter it should connect now. If you need to download stuff and u have a firewall blocking ports then either u switch off ur firewall for a while or forward some ports.
mIRC would reject .EXE files so check the DCC Ignore settings.
cheers
for rest of the info check
mIRC firewall / router settings
General mIRC help
Old 15th June 2006, 06:07   #3
You can connect to DALnet Or Undernet.
Give some Nickname & Press connect, If you are not able to do then
type all these servers.
/server mesra.dal.net
/server jade.dal.net
/server speedtech.dal.net
Let me know if u need any help.
prakash2757 is offline   Reply With Quote
Help required for i10 ICE. Buget 25k fraser In-Car Entertainment 9 10th March 2011 00:18
urgent help required with spyware aadix Shifting gears 34 21st March 2007 20:38
Diesel car maintenance help required!!! Steeroid SUVs, MUVs & 4x4s 24 5th March 2007 09:28
Help required for making case against Dealer in Mumbai for delay in swift delivery AGP The Indian Car Scene 28 16th September 2005 20:58
Help required from fellow Bhp'ians to plan a trip Surprise Street Experiences 26 30th August 2005 16:37
