Go Back   Team-BHP > Around the Corner > Shifting gears
Old 16th October 2006, 10:19   #1
LandSpeed's Avatar
Thumbs up Toyota Supra TWIN TURBO Engine / tranny
Hello
i have a Toyota Supra twin turbo engine and trannsmission (manual)FOR SALE !
THIS IS A COMPLETE ENGINE WITH THE TURBOS ECU WIERING HARNESS MANUAL TRANSMISSION CLUTCH WHATEVER U CAN THINK OF IS THERE !
I GURANTEE THE ENGINE IS WORKING PERFECTLY FINE OR MONEY BACK AS I WILL START THE ENGINE BEFORE DILIVERY !
the engine is located in Mumbai ! For those who know me my word should be good enough
This is perfect for any1 Who is into DRAG RACING or Just enjoys speed !
(rear wheel drive)
LandSpeed
Suren Joshi
LandSpeed is offline   Reply With Quote
Old 16th October 2006, 18:41   #2
v1p3r's Avatar
Thanked: 27 Times
Which model year is this? How much?
Old 16th October 2006, 22:13   #3
LandSpeed's Avatar
Its a 63k run engine 1991
1g-gteu 6 cyl (twin turbo) boost 14
everything stock not at all messed with
5 speed tranny
includes everything
2lakhs non neg
Old 17th October 2006, 17:44   #4
Thanked: 11 Times
Hey Landspeed,
I have PMed you. Check your PM.
Waiting for your reply.
Cheers,
Mugen_Power
Mugen_Power is offline   Reply With Quote
Old 18th October 2006, 05:16   #5
Thanked: 16 Times
I dunno. But for some reason, my earlier post went missing. So here's the question again.
It would be nice if you can list a few cars which can be fitted with this engine. As you know, there're very less cars sold here which comes with RWD.
Sorry for being a novice in this department.
Old 18th October 2006, 14:40   #6
v1p3r's Avatar
Thanked: 27 Times
HM Ambassador, PAL-Fiat Premier Padmini (maybe), HM Contessa, Standard Herald, off the top of my head.
Installation + braking + chassis + suspension, you're looking at an additional 50k, minimum.
Old 18th October 2006, 14:53   #7
Sideways's Avatar
Thanked: 18 Times
Akshay, it's a straight six. I doubt if the engine bay of any of the cars you have entioned will be able to hold the engine. Unless psycho comes up with a psycho way of dropping it into one of these.
One thing I can defineately say is that it aint gonna be a daily driver.
Sideways is offline   Reply With Quote
Old 18th October 2006, 16:32   #8
Psycho's Avatar
Thanked: 95 Times
Well if one could drop a v8 into a conti chassis an inline six would be kids play, however what happens to the chassis later would never be my problem
Personally I do not think any of the old indian rides would be able to take those kind of stresses.
Old 18th October 2006, 17:28   #9
Thanked: 11 Times
What is the engine capacity and output?
Boom Shiva is offline   Reply With Quote
Old 18th October 2006, 17:49   #10
Ford Rocam's Avatar
Thanked: 16 Times
I think its around 210-220 bhp stock (some body correct me if i am wrong)
I had read somewhere that engine is not that good for modification not much support for aftermarket parts rather get a 2JZ instead.
Ford Rocam is offline   Reply With Quote
Old 18th October 2006, 17:58   #11
v1p3r's Avatar
Thanked: 27 Times
Yeah, it's only off the JDM Supras. USDM got it on the Mark II etc. 210 bhp is about right for it.
Old 18th October 2006, 18:25   #12
Thanked: 11 Times
I think the stock car runs only 7 psi boost, not 14. Used to know someone in NZ who owned one...
Could someone please clarify?
Old 20th October 2006, 01:06   #13
LandSpeed's Avatar
K here to correct you all
its a 1g-gteu which was made in 1991 which was the gen 3 engine tht was the last of its kind and had 240 bhp stock RWD and it runs at 11 psi boost and u can push this to 14 which i am running in my car !
gen 1: Yellow ECU plugs and Yellow injectors. 0.50bar / 7psi.
gen 2: Yellow ECU plugs and pale Green injectors. 0.62bar / 9psi
gen 3: Grey ECU plugs and pale Green injectors. 0.75bar / 11psi
the above info is how u figure out the boost in this car
Old 20th October 2006, 13:52   #14
esteem_lover's Avatar
Thanked: 447 Times
guys, wouldn't this beast fit into the indian beast (read tata safari) ?
Old 22nd October 2006, 10:56   #15
adityapd's Avatar
same question from me too
~A
adityapd is offline   Reply With Quote
Twin Turbo GTO or Turbo MR2 spiff Luxury, Imports & Niche 32 29th September 2014 01:52
Hard/Engine Braking in Auto tranny ikoneer Technical Stuff 20 6th August 2012 21:30
Mahindra CJ4A - Toyota Twin Turbo Engine Over 300HP Nahal Modifications & Accessories 63 13th October 2009 18:31
Rolls Royce RR4 coming with 500+bhp turbo V12,8 speed tranny!!! AyAn! The International Automotive Scene 9 27th March 2009 16:46
Looking for a Twincam g13B engine & tranny bruce Shifting gears 1 13th November 2007 21:35
